Re: Telefunken TE32182B29C10
What you can do is put some alcohol on that area of the board, then apply 1 to 3 volts to the 5V_VCC point, momentarily. the part that is shorted will get hot very fast and the alcohol on the component will evaporate fast.
You could also just put your finger on U49 and use a 1.5 volt battery to apply 1.5 volts to +5V_VCC, if it gets hot you found the shorted part.
