Telefunken TE32182B29C10
  • R_J
    • Jun 2012
    • 9546
    Re: Telefunken TE32182B29C10
    What you can do is put some alcohol on that area of the board, then apply 1 to 3 volts to the 5V_VCC point, momentarily. the part that is shorted will get hot very fast and the alcohol on the component will evaporate fast.
    You could also just put your finger on U49 and use a 1.5 volt battery to apply 1.5 volts to +5V_VCC, if it gets hot you found the shorted part.
    • Bobo360
      • Sep 2018
      • 36
      • Italy
      Thanks for your suggestions. I just removed U49 and the short circuit between 5vcc and gnd is gone. But the pins of U49, 2 and 4 are always in Gnd. What do I do? Ps: I hope to remember where the capacitors were placed. Ps2: so I found that U49 was broken since now 5vcc is not at Gnd?
      • R_J
        • Jun 2012
        • 9546
        With U49 you no longer have a short on 5V_VCC, that is good.
        Can you check the pins of U49 to se if the internal fets are shorted?
        With U49 removed, Do you stll have a short on the board where pins 2 and 4 were connected? Is 3V3_VCC still shorted to ground?
        • Bobo360
          • Sep 2018
          • 36
          • Italy
          Without U49 I no longer have the 5V_CC short circuit.
          someone yes, between the right and the left.
          Yes, without U49 I have the two pins 2 and 4 towards GND.
          • arizanotlari
            • Nov 2014
            • 158
            • Turkiye
            i think cpu is die.
            https://www.badcaps.net
            • Bobo360
              • Sep 2018
              • 36
              • Italy
              #26
              Originally posted by arizanotlari
              i think cpu is die.
              MT5820LUNU,
              Pin 120, 121 are connected to GND.
              I guess it's not normal.
              What are you saying?
              • Bobo360
                • Sep 2018
                • 36
                • Italy
                #27
                how can i verify that is the CPU?
                • arizanotlari
                  • Nov 2014
                  • 158
                  • Turkiye
                  #28
                  pin120 and 121 connected to gnd : cpu shorted : cpu die : replace cpu or change mainboard.
                  • Bobo360
                    • Sep 2018
                    • 36
                    • Italy
                    #29
                    OK thanks.
                    you made me understand.
                    CPU is U14. right?
                    • Bobo360
                      • Sep 2018
                      • 36
                      • Italy
                      #30
                      Thanks for all of your help.
                      I decided to change the mainboard. Now the TV works fine.
                      Thanks again.
                      • cheeky2
                        by cheeky2
                        05-25-2024, 03:27 AM
                      • Dani_2024
                        by Dani_2024
                        10-28-2024, 05:06 PM
                      • ygorsan
                        by ygorsan
                        🧩 Problem Summary:
                        • I
                        07-28-2025, 08:34 AM
                      • Asraf Atb
                        Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                        by Asraf Atb
                        Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                        Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                        I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                        01-27-2025, 05:02 PM
                      • JSin21
                        Compatibility of main boards between different variations of samsung MU6100
                        by JSin21
                        Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
                        I have Samsung Smart TV UA65MU6100WXXY version DA01
                        Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...
                        11-27-2023, 04:54 AM
