Weird smeary failure mode with Westinghouse LCD
  • staze
    • Mar 2008
    • 41
    Hi All,
    Have a weird failure mode that I would love some insight on. I figure it's gotta be the FRC or T-Con board, but I'm at a loss of how to actually fix without just randomly buying and replacing one of the two.
    Here's a video of the issue. I've checked voltages, done visual inspections, reseated connections, tightened screws (incase of poor ground), tapped around on boards, connections, BGAs, etc.
    Model is a Westinghouse WD55UB4530.
    Any insight/assistance would be great. For reference, owner was just using the TV normally and when he went to the menu it did this. First stuff is the power on of the TV, then moving camera is me hitting the menu button.
    https://www.dropbox.com/s/lc58pd0xt1...0Mode.mov?dl=0
  • staze
    • Mar 2008
    • 41
    Re: Weird smeary failure mode with Westinghouse LCD
    btw. Unplugging (either) half the connection from the t-con board to the panel results in no video at all. No idea if that's normal behavior... seemed odd to me. But then, I also don't see a horizontal drive connection at all... just vertical connections.
    • aaronwt6
      • Apr 2013
      • 855
      • US
      That looks almost certainly like a panel failure to me.
      • staze
        • Mar 2008
        • 41
        damn. =(
        • arizanotlari
          • Nov 2014
          • 158
          • Turkiye
          Hello.
          I repair this fault before. Change T-Con.
          https://www.arizanotlari.com/2019/03...97-17mb98.html look first image
          https://www.badcaps.net
          • CapLeaker
            Leaking Member
            • 8146
            press around on the tab bonds see if these lines change or go away.
            • staze
              • Mar 2008
              • 41
              They do not. At least not flexing the intermediary pcb's between tcon and tab bonds.
              • staze
                • Mar 2008
                • 41
                Poked around the tabs and nothing. removed tcon and gave it some flexing. No change.
                Any other input before I buy a t-con to test with?
                • arizanotlari
                  • Nov 2014
                  • 158
                  • Turkiye
                  Dont buy t-con. i watch video again this is panel fault not t-con. Sorry for wrong advice.
                  • CapLeaker
                    Leaking Member
                    • 8146
                    nah... it's junk. There was a chance for bad tab bonds, but if that didn't do anything, I'd part it out.
                    • staze
                      • Mar 2008
                      • 41
                      Should I check the tab bonds on the panel itself? I haven't taken the whole back off since it's a nightmare of screws...
                      • budwich
                        • Jul 2015
                        • 3097
                        when you say you checked voltages... what voltages are you referring to? There are a number of voltages associated with the tcon that can be check and traced towards the edge board of the panel. Your posted picture doesn't give one a warm feeling but it is strange that disconnecting either side of the tcon doesn't give you any display... what does that mean? the display is total blank or there is still white portions?
                        • staze
                          • Mar 2008
                          • 41
                          Display is totally blank when disconnecting either "half" of the tcon->tab breakout boards (there's a single cable between FRC to t-con, then two cables out of t-con to long tab PCBs to each half of the panel). I too thought it was odd whole display is dead with half disconnected, but figured maybe the t-con was shutting down due to sensing a fault.
                          I've checked the primary voltages off the powersupply and traced them to the FRC board (12V, 5V, stb, etc).
                          I haven't broken out the scope and looked at them on the tcon. I don't see any obvious marked voltages on the t-con board. Attached are images of each of the boards...
                          • budwich
                            • Jul 2015
                            • 3097
                            hmmm... I see lots of voltages listed on the tcon card. You don't necessarily need a scope. They should be checked and listed with their label and value if you want the forum to help you get further. It may be fruitless but again it may give life back to 55in set.
                            the 125v / 5a fuse looks "scary"... was that checked?
                            • staze
                              • Mar 2008
                              • 41
                              okay, I do see that on the connectors down to panel, is that what you mean? biggest issue is deciphering the labeling.
                              Will give it a look tonight.
                              • budwich
                                • Jul 2015
                                • 3097
                                NOTE: when you are tracing or trying to find where things travel, ensure that the set is unplugged and use your meter in resistance mode to check / trace tracks thru various "known" points in the board to areas of interest... you may not be able to see the exact tracking but are more interested in "end result"... ie. the same electrical connection.
                                Once you have determine them, then power up and meter the voltages at "standby" and at "turn on". Further, since you have "no display" when one or the other tcon to edge panel board cable is disconnected... also measure those same voltages then to see if you can spot some differences in the various "states". I am not thinking that your panel is bad at this point.
                                • staze
                                  • Mar 2008
                                  • 41
                                  Hey All,
                                  I didn't forget. I went out and measured voltages, and everything seemed normal. Then a day or so later I went back out to give one last try and put pressure on the edges of the panel to see if maybe it was a loose bond. When I moved the TV out to be able to do the work, I turned it on and it came right up.
                                  So, either sitting face down for weeks, or me just moving it caused the connection to come good.
                                  I've told the client to be aware it'll likely fail again. But it does seem like it's probably a bad/poor bond to the panel itself rather than to the t-con or to the pcb's that link the tcon to the panel (not sure what those are called). =/
                                  • RDC55
                                    • Dec 2017
                                    • 180
                                    I have a similar TV Model No.WE55UDT108 that has virtually the same failure as displayed in post 1 of this thread:
                                    His failure eventually just went away, so before scrapping / parting I wanted to ask about some of the components on the panel CCA.
                                    A flash memory (datasheet attached) - why might it be there and how would it be checked?
                                    DK1, DK2, and DK3 6 pins device marked E5 any idea what they are?
                                    • RDC55
                                      • Dec 2017
                                      • 180
                                      So no guesses on what these components are - DK1, DK2, and DK3 in attached pic?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4325
                                        • Italy - Milan
                                        pack TVS diodes i think.. i think them are 1,8v or 3,3v depends on which tension you haven on tcon.. can you post a picture of the defect? i can't see the video through the telephone..
                                        • madcrow
                                          Tearing-like display artifacts on Philips BDM4065UC
                                          by madcrow
                                          Hi There,
                                          Anyone familiar with this kind of display artifact?
                                          Gallery: https://imgur.com/a/tYc2dWK
                                          At a superficial glance, it sort of looks like screen-tearing. But that square-wavy boundary is weird...
                                          The phenomenon was detected on
                                          • 3 screen <=> PC combos consisting of
                                          • 2 different screens (same model: Philips BDM4065UC)
                                          • driven by 2 different PCs via
                                          • 2 different Nvidia GPU models (one desktop, one mobile) multiple generations apart,
                                          • running on 3 different Nvidia drivers, each with siginficant age-gap,
                                          • under Win10 Pro 22H2.
                                          Connections...
                                          10-26-2024, 01:38 AM
                                        • Sus256
                                          HISENSE 65E7KQ PRO - no boot
                                          by Sus256
                                          Hi all!
                                          HISENSE 65E7KQ PRO
                                          RSAG7.820.13512 - chassis
                                          MT9618BAATAB - cpu
                                          RSAG7.820.12059 - power
                                          HD650Y3U77 - panel
                                          KLM8G1GETF - emmc
                                          The TV does not turn on, the standby indicator is on. All voltages are present.
                                          Emms is dead. Not readable, not detected.
                                          Replaced emmc.
                                          But with another dump there is no launch
                                          Terminal log
                                          UART
                                          AC_ON
                                          RPMB key is not yet programmed
                                          HASH1_VERSION=0x00000000 64bit
                                          E-B
                                          FDE enabled
                                          layout pattern onebin by SAR7,0...
                                          06-01-2025, 02:11 AM
                                        • mmartell
                                          Westinghouse WD55UDR101 4k LED TV Control Board Failure
                                          by mmartell
                                          Well it looks like it to me except it's not a plasma so there is no control board
                                          This has a combined Main/PS board and the tcon appears housed on the panel boards. I had just mounted this tv 24 hours earlier and was watching it when it shut off and wouldn't turn back on. Red standby and that's it.
                                          Took it down and took the back off. After measuring some voltages the set finally turned on as shown in the first pic. Sometimes it displays the logo and other times blank screen but either way within 30 seconds it reboots itself.
                                          The CSOT ic on the panel driver...
                                          12-07-2020, 08:05 PM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • aaronwt6
                                          Weird Screen Failure Samsung UN55KU6300F
                                          by aaronwt6
                                          Just posting this out of curiosity of who else has seen similar failures on this or other similar models. I picked this up yesterday and was told by the owner that they were watching the TV one evening. Zero issues. Next morning it looked like the attached. The spot is almost a perfect circle and there is no visible impact damage. She said that it was not hit with anything and there were no kids in the house. I personally haven't seen a failure quite like this....
                                          10-14-2020, 06:09 AM
