Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
  • DamneD2000
    • Oct 2021
    • Russia
    #121
    Re: Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
    My solution for the QFU platform (42PFL6907T) was the reballing of CPU with active heatsing cooling, made from my old PC VGA card. Some pics of the final improvement
    • DamneD2000
      • Oct 2021
      • Russia
      #122
      My solution to make my 42PFL6907T work was the reballing of the CPU and making active cooling with heatsink taken from my old VGA card.
      Here is how it looks like
      • Maalobs
        • Jun 2016
        • 120
        • Sweden
        #123
        Nicely done!
        Although, that small fan looks like it could become a little loud and whiny on permanent max speed while the TV is running.
        I bought a 75" Philips 75PUS6754/12 a couple of years ago and as a pre-emptive measure, I opened it up to inspect the state of the planned obsolescence in the device.
        When I removed the heatsink assembly from the main processor I noticed that whatever they had used as thermal paste underneath it, could easily have been mistaken for a seagull's watery diarrhea.
        I cleaned that mess out and replaced it with some Thermal Grizzly Kryonaut instead.
        The heatsink still got very hot though and the entire system was clearly baking inside the chassis under prolonged use, so that wasn't going to be enough.
        Then on further investigation I noticed how the USB-ports on this system actually power down properly when the TV enters the standby-state.
        That's useful, so I bought a PWM-controlled 12cm PC-fan, and made a hole for it in the TV's plastic back case right above the heatsink, leaving the corners in place so I could drill holes there for the fan.
        Then I mounted the fan into the chassis with the usual self-tapping screws that are included with the fan.
        It worked out quite nicely, and I have open space behind the TV as well since it's standing on the feet.
        I got a quiet Noctua fan, and they also sell a small separate fan controller device which has a dial on it to control the fan speed.
        I already had a small USB-to-12V step-up adapter from somewhere, similar to this thing, which I opened up so I could solder the input of the fan controller directly to the output-pads on the converter's PCB:
ID:	2075181 Click image for larger version
ID:	2075182 Click image for larger version
        Then I dialed the fan speed down to a tolerable noise level on the controller, which with the quiet and stable Noctua meant just reducing the woosh of the air blowing.
        The fan also has rubber bumpers in the corners so there is no vibration carried into the big, wobbly back case either.
        It has worked flawlessly for the past two years, and the fan turns off as expected when the TV goes into standby.
        The point is; you also have to get the hot air out of the device, so make a hole above that fan as well.
        You'll find that the plastic is surprisingly easy to work, even with crude tools!
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4367
          • Italy - Milan
          #124
          For anybody that comes here in the discussion and wants to make a reflowing job, it's important to slowly cook the chip for a day before attempting a reflow, this is to prevent the famous popcorn effect that destroys the chip in fact, for this purpose you can use an oven at about 100 celsius degrees connected to an external timer for mains interruption after 24h. So the reflow preferably mostly from the bottom or both..
          • Zano64
            • Jun 2021
            • France
            #125
            Some months ago I posted concerning the revival of my 47pfl7108h_12 TV set by blowing hot air to the SSB CPU.
            Unfortunately after some time it began stopping and restarting without reason, till it completely stopped with the well known LED blinking.
            I did not read the last post about a day cooking (sorry Davi.p), so I applied another method (inspired from another blog post) which I will call the "Kitchen oven reflow".
            You will see on attachment the SSB PCB in the oven, set on bolts and nuts high enough to obtain more or less equal temperatures above and below the board.
            I achieved the temperature curve (measured by a thermocouple) similar (I hope) to a pro reflux process. The most difficult part was that the oven thermostat is not at all accurate.
            In addition to that kitchen reflow I replaced the heatsink by an aluminum one, see photos which this time I managed to post.
            And the set is revived for the second time.
            How long will it last ? No idea at all
            See you later folks.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4367
              • Italy - Milan
              #126
              Let us know how it goes... and tell me if the board watched from long profile is bent
              • Zano64
                • Jun 2021
                • France
                #127
                The TV has worked fine in my house during a rew days. Then it traveled a hundred+ km to my daughter's house. And there it started well but is beginning to stop working after some minutes. I will recover it later and I will tell you if the PCB is bent.
                What I plan to do is to reflow it again in the oven, then reinstall the foam pad below the SSD board to keep it as flat and stable as possible. And finally install some kind of clips on the heatsink to apply it as tight as possible to the SSB IC.
                • William1967
                  • Nov 2017
                  • 214
                  • Netherlands
                  #128
                  Reballing is the only solution, the solder used in the factory is not good anymore. Heating it up in an oven might work but usually not for long.
                  • Davi.p
                    Hobbist Tech
                    • Sep 2009
                    • 4367
                    • Italy - Milan
                    #129
                    My suspect is that by some manufacturers a tin with short life is carefully tested to shorten device life, so new solder must be put in, maybe also in the die if possible...
                    • Maalobs
                      • Jun 2016
                      • 120
                      • Sweden
                      #130
                      Did you tap the corner of the chip while it was heated, as I described in this earlier comment?
                      Looks like your model doesn't have the 54.6mm diagonal mounting holes, unless the heatsink covers the holes in your photo?
                      I think you are fine if you are using a thermal adhesive underneath the heatsink already, but if you find a way to push down the heatsink with mechanical force, please share it with us with pictures.
                      Something that would be convenient in this case is if there was a USB-fan product with an actuated arm like the Arctic Breeze Mobile, but also with a built-in fan-control:
                      I bought one of these to investigate the sound level of it.
                      It turned out that it runs at full speed and just the wind noise was too much, but the worst part was that having the fan out on the end of the actuated arm creates a mechanical vibration that reverberates into the SSB and chassis, which created a noise that was far too loud for this fan to be useful.
                      If only it had a way to dial the fan speed, it would had been a cheap and very simple solution for our particular problem.
                      That's why I went with the arguably overkill solution of a controlled PC-fan instead, which works very well but costs more.
                      • dominik0801
                        • Feb 2018
                        • 98
                        • Hungary
                        #131
                        It's that time of the year again.
                        I have already blown the Fusion chip in my TV with hot air 10+ times, but the double blink always came back, so last time (2021 september 22) I did a proper reflow under the BGA machine.
                        I told to myself, that now we will see how long it will work, but the next time it fails I'm going to reball the chip.
                        Well.. today morning I woke up, wanted to watch some TV, but aww no, double blink..
                        I didn't even order stencil yet, and my gf comes to my place for a week, so I will need the TV fast. So I was like, okay.. reflow it once again, and next time I WILL reball it.
                        So I did the reflow today, which in fact made the TV come alive, so I put it together, but when I tried to switch to my TV BOX via HDMI, it wouldn't work..
                        I tried all 5 of the HDMI ports, but nothing.
                        It did recognize, that I plugged in a HDMI, but it would simply say "No video input" or something. Tried it with a laptop too, without any success.
                        Meh.. I really didn't want to wait for that stencil I ordered today, so I desoldered the CPU and reballed it without stencil - I did it already with GPUs, I knew it will be long and frustrating, but it is what it is..
                        I did the reballing, soldered it back and yes.. the TV works now, even the HDMI ports are functioning.
                        I didn't have 0.65mm balls, on other forums they said that it is the right size, I used 0.6mm, hopefully they won't fail.
                        If I was already there, fixed some loose-looking SMD caps and resistors, oiled my CPU fan, put a fuse on the +12V TCON jumper wire as it didn't have any when I soldered it in.
                        Let's see, how long it will go.
                        • Maalobs
                          • Jun 2016
                          • 120
                          • Sweden
                          #132
                          Hopefully you fixed it for the final time now with the proper reballing.
                          The original TV from this thread is still the daily driver of my friend and it's working flawlessly.
                          • kazbayadum
                            • Aug 2021
                            • Spain
                            #133
                            Hello, I am going to share my experience with you.
                            A year and a half ago (2021 August) I got the famous error 53. I disassembled the TV and tried to reflow it without success on my own. As it seems to me something that requires some previous experience, I took the green motherboard to a store in the neighborhood, where they repair video game consoles. There they did a reflow.
                            The sales clerk did not charge me because he had no way of checking that he had done the job properly. I took it home and it has been working until last month. I don't use the TV much, to be honest, but it held up pretty well. The only thing I changed was the thermal paste. I used the same ceramic heatsink it comes with.
                            Now I am going to repeat the feat (2023 January). This time I will try to find a 54.6mm heatsink to replace the previous one, with two diagonal holes and some mechanical system that presses the heatsink against the board. I'm hoping that with that and a custom drill hole in the back cover, it will be enough. I don't like fans, I'm quite a fan of fanless systems.
                            On the other hand, while I'm here, I've never been entirely happy with this TV. The controls seem stilted to me, the smartTV is slow (and with a proprietary OS) and the keypad signals from the remote, don't transmit over HDMI as I expected would happen. Do you know of any hacked firmware updates that would improve these aspects? Maybe AndroidTV?
                            Best regards and if I remember I will send you pictures of the result!
                            • ngml
                              Repair of an LG split AC system indoor unit PCB
                              by ngml
                              I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
                              This indicates an error in the communication between the outdoor and the indoor unit.
                              The outdoor unit is fine, so the problem is the indoor PCB.
                              The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
                              I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
                              Does anybody have the schematics of this board,...
                              02-01-2025, 12:55 PM
                            • nobbnobb1
                              Bose Companion 5 - Unit Powers On then Cuts Off Shortly After
                              by nobbnobb1
                              Hi guys,
                              Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
                              When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...
                              02-03-2022, 11:14 AM
                            • BC_TechForum_drb
                              Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                              by BC_TechForum_drb
                              Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
                              Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
                              Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
                              2/ Figure 1 Gfx-D500-B Front Facing
                              3/ Figure 2 +5v supply (zoom-in)
                              Intro:
                              While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...
                              12-07-2023, 09:55 PM
                            • Gjackson
                              Air-conditioning unit power supply failing to power up
                              by Gjackson
                              Hi all, I managed to narrow down which PCB was causing my Haier AC to throw out an E7 error code (E7 indicates that the indoor unit and outdoor unit cannot communicate). I found that the outdoor unit power board which gives 5v and 15v to the outdoor unit module board fails to fully power up.. The power Led starts to fade in incredibly slowly and the 5v and 15v power buses jump around like crazy and never reach their required voltage. I unplugged the module board from the power board and the power board powered up fine! It had a steady 5v and 15v out and the power LED came on instantly and Bright....
                              01-08-2022, 09:24 AM
                            • Duranitron
                              Asus x512dk rev 2.1 power on problem
                              by Duranitron
                              When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                              Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                              11-26-2024, 10:22 PM
