Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
Re: Philips 60PFL8708S/12 - QFU1.2E LA - Error code 53
I cannot wait for the stencil to arrive to know which is the balls size to order and wait another month or two to begin the job.. i think i will spend half an hour or less to place the balls by hand so maybe i can do it so..Comment
https://www.ebay.co.uk/itm/9x9-FNP10...-/273592452088
0.6mm balls.Comment
While I was at it, I also took a backup of the EDID config in the TV.
The EDID is stored in this chip:
Apparently it's a huge hassle to get access to the datasheet for it from Lattice, who nowadays owns Silicon Image.
But it's not needed, there is just one detail there that is important to know; this particular chip does not support writing to EDID via HDMI, it must be done through the I2C-bus.
Once you know that, you can handle writing any corrupt bytes in the register with a BusPirate or a Raspberry Pi.
Reading the EDID works through HDMI of course, here is how it's done from a computer with Linux that has the HDMI-output connected to one of the inputs on the TV:
Here are some references about reading the EDID:Code:knoppix@Microknoppix:~$ su - root@Microknoppix:~# modprobe i2c-dev root@Microknoppix:~# apt-get update root@Microknoppix:~# apt-get install i2c-tools # List the available I2C-buses on your computer: root@Microknoppix:~# i2cdetect -l | sort i2c-0 smbus SMBus I801 adapter at 3040 SMBus adapter i2c-1 i2c i915 gmbus ssc I2C adapter i2c-2 i2c i915 gmbus vga I2C adapter i2c-3 i2c i915 gmbus panel I2C adapter i2c-4 i2c i915 gmbus dpc I2C adapter i2c-5 i2c i915 gmbus dpb I2C adapter i2c-6 i2c i915 gmbus dpd I2C adapter i2c-7 i2c DPDDC-A I2C adapter # List all available device addresses on each I2C-bus, then look for any device address 0x50 in the output: root@Microknoppix:~# perl -we 'system("i2cdetect -y $_") for 0..7' 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- 08 -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- 44 -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- 3a -- -- -- -- -- 40: 40 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: 50 -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- <- 0x50 here 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: -- -- -- -- -- -- -- -- -- -- -- -- -- 10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 30: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- 0 1 2 3 4 5 6 7 8 9 a b c d e f 00: 03 04 05 06 07 08 09 0a 0b 0c 0d 0e 0f 10: 10 11 12 13 14 15 16 17 18 19 1a 1b 1c 1d 1e 1f 20: 20 21 22 23 24 25 26 27 28 29 2a 2b 2c 2d 2e 2f 30: -- -- -- -- -- -- -- -- 38 39 3a 3b 3c 3d 3e 3f 40: 40 41 42 43 44 45 46 47 48 49 4a 4b 4c 4d 4e 4f 50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- 70: -- -- -- -- -- -- -- -- # Only one instance of address 0x50 on this computer, on the 5th I2C-bus, so dump the values of that device on that bus: root@Microknoppix:~# i2cdump -y 5 0x50 0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef 00: 00 ff ff ff ff ff ff 00 41 0c 00 00 01 01 01 01 ........A?..???? 10: 2a 16 01 03 80 84 4a 78 0a e6 92 a3 54 4a 99 26 *?????Jx????TJ?& 20: 0f 4a 4c 21 08 00 b3 00 95 00 a9 40 90 40 81 00 ?JL!?.?.?.?@?@?. 30: 81 80 81 40 01 01 02 3a 80 18 71 38 2d 40 58 2c ???@???:??q8-@X, 40: 45 00 00 d0 52 00 00 1e 02 3a 80 d0 72 38 2d 40 E..?R..??:??r8-@ 50: 10 2c 45 80 00 d0 52 00 00 1e 00 00 00 fc 00 50 ?,E?.?R..?...?.P 60: 68 69 6c 69 70 73 20 46 54 56 0a 20 00 00 00 fd hilips FTV? ...? 70: 00 30 3e 0f 46 11 00 0a 20 20 20 20 20 20 01 93 .0>?F?.? ?? 80: 02 03 3a f1 52 10 1f 20 22 21 05 14 04 13 12 03 ??:?R?? "!?????? 90: 11 02 16 07 15 06 01 26 09 1f 07 15 07 50 83 01 ???????&?????P?? a0: 00 00 70 03 0c 00 10 00 38 2d af 4c 4c d0 04 01 ..p??.?.8-?LL??? b0: 40 01 ff e3 05 03 01 e2 00 49 01 1d 80 3e 73 38 @?.?????.I???>s8 c0: 2d 40 7e 2c 45 80 00 d0 52 00 00 1e 01 1d 80 d0 -@~,E?.?R..????? d0: 72 1c 16 20 10 2c 25 80 00 d0 52 00 00 9e 01 1d r?? ?,%?.?R..??? e0: 00 bc 52 d0 1e 20 b8 28 55 40 00 d0 52 00 00 1e .?R?? ?(U@.?R..? f0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 4a ...............J # Save the results: root@Microknoppix:~# i2cdump -y 5 0x50 > dump.txt root@Microknoppix:~# mv dump.txt /home/knoppix/ root@Microknoppix:~# chown knoppix:knoppix /home/knoppix/dump.txt root@Microknoppix:~# logout knoppix@Microknoppix:~$ logout
https://www.youtube.com/watch?v=IGg1nyTY6oc
https://www.youtube.com/watch?v=8IMkGdeXcS4
https://en.wikipedia.org/wiki/Extend...ification_DataLast edited by Maalobs; 01-23-2024, 05:02 PM.Comment
I'm finished with everything on the TV now, hopefully it will have many more good years left in it.
The new heatsink is in place:
I also put a small heatsink on the NAND-chip, but it's on the underside of the board so it's not visible here.
The chassis got a classic redneck solution:
Say hello to my little friend:
Thanks for all your help guys!
I have squirreled away all the firmware images from this model, so let me know if you need a copy of anything.Last edited by Maalobs; 01-23-2024, 05:04 PM.Comment
Sure, if you want to pay money for something that's free.
I don't normally use Linux but it's something I have needed to learn to be able to get things done.
In this case, I booted my laptop from a USB-stick with Knoppix, one of many different bootable live systems with Linux.
It's quite handy to have ready for occasions like this.Comment
I forgot to mention; I have posted the contents of the SPI Flash and I2C EEPROM in this sticky thread, in case anyone has use for them:
https://www.badcaps.net/forum/showpo...&postcount=533Comment
Hello folks, Herr Alpengeist speaking :-)
I found this thread while going through the visitor stats of my blog. Thanks for stopping by!
I gave up on the QFU boards. It is pure luck whether the CPU will wake up or not. I had reflowed and reballed the heck out of these things and never got any repeatable results. The QFU1.1 boards are so thin that they warp terribly. The QFU1.2 are a bit better in that respect. I am pretty sure that the CPU is to blame and not some balls. The infamous "K" error appears in both QFU1.1 and 1.2 models. Their board layout is different. It would be a big coincidence if the same balls broke. No, I think the CPU is to blame.
Only the case when the device is totally dead with a scrambled boot SPI has a 100% repair success rate. Alas, I only had that once. All others were CPU-related.
There are P120 CPUs (QFU1.1 and QFU1.2 6008 models) on eBay from Poland. They look legit. Unfortunately, the P240 CPU for the higher QFU1.2 models (7008, 8008) are not available.
I suggest that one reheat attempt (without full reflow because that's not the issue) at about 225°C can be done and if that doesn't fix it: dump it. Sad but true. A terrible TV series that was.Comment
Salve , ho lo stesso problema codice errore 53 con Philips 55PFL8007K12
Telaio / Versione : QFU1.1E LA
Power Supply : FSP197-4FS01 2722 171 90676 REV : 01
Pannello : LTA550HQ19
Main board : 3104 308 98314
Il televisore si presenta completamente spento .
Le tensioni che leggo sono la 3v3s = 3v3 e la STB= 3v1
Ho riprogrammato la spiflash 7CT3 (M25P10) ,
sul pin 2 del connettore 1M95 la alimentazione
è passata a livello logico basso , da 3v1 a 0 volts .
La 12 volts , ora , è presente ,
come le altre alimentazioni sulla main -board .
Ma ottengo codice errore 53 .
Ho provato a collegarmi con Hyperterminal al jack di servizio ,
ottengo queste informazioni (vedi allegato )
Allego anche lettura della Spi 7CT3 prima della programmazione .
Il bin, che ho riprogrammato per la SPI è per un processore Fusion 77
Mentre il processore sulla main è un Fusion P240 FNP202-B1E32 .
Può essere questo il problema ?
Una altra domanda , perche con Hyperterminal ottengo questo log ?Attached Filesif you find these attachements useful please consider making a small donation to the site
Hi, I have the same problem with error code 53 with Philips 55PFL8007K12
Chassis / Version: QFU1.1E LA
Power supply: FSP197-4FS01 2722 171 90676 REV: 01
Panel: LTA550HQ19 Card
mother: 3104 308 98314
The TV is completely turned off.
The voltages I read are 3v3s = 3v3 and STB = 3v1
I reprogrammed the spiflash 7CT3 (M25P10),
on pin 2 of connector 1M95 the power supply
it has gone to a low logic level, from 3v1 to 0 volts.
The 12 volt, now, is present,
like the other feeds on the mainboard.
But I get error code 53.
I tried connecting to Hyperterminal at the service jack,
I get this information (see attachment)
I also enclose the Spi 7CT3 reading before programming.
The trash, which I reprogrammed for SPI is for a processor,
is a Fusion P240 FNP202-B1E32.
Can this be the problem?
Another question, why do I get this log with Hyperterminal?Comment
Hello
I was wondering if someone encountered a blank SPI ?
I have a 46pfl8008, it has 2 blinks on level1 and 53 on level 2.
Recovery isn’t working.
I’ve suspected the SPI (25p10) and because it’s the easiest chip to check.
I’ve used this programmer
https://www.ebay.com/itm/CH341A-Seri...53.m1438.l2649
with a clip
https://www.ebay.com/itm/Soic8-Sop8-...53.m2749.l2649
To my surprise, the chip was totally blank – all FFs.
Any ideas?Last edited by maki; 08-08-2019, 02:29 AM.Comment
by ngmlI am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
This indicates an error in the communication between the outdoor and the indoor unit.
The outdoor unit is fine, so the problem is the indoor PCB.
The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
Does anybody have the schematics of this board,...2 Photos02-01-2025, 12:55 PM -
by CoinCoin88Hello everyone,
I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver... -
by DrDosI have finished my work. The new lights come on except the one for stereo, I reversed the bulbs to no affect, anyway, the unit powers on, relay clicks. I have no DC voltage in speaker outputs, I also do not have any AC in the speaker outputs. There is some faint crackling in the speaker. This unit cranks up loud so I had the volume on very low. Everything seems to be fine but I can't really check the switch until I can get sound out of the outputs. I was going to do caps for the power supplys and the tone board but thought if it was cranking loud at one time maybe just leave it alone until it...1 Photo
by nobbnobb1Hi guys,
Trying to salvage a Bose Companion 5 computer speaker system that powers off shortly after powering on. It's got a primary USB input (built in DAC) and an aux 3.5mm input. The USB appears to be the primarily source that tells the unit to power on (control pod LED goes green) as the unit has no power switch.
When I first connect power to the unit, plug in the USB, it will play audio nicely for a minute before it drops out and the unit appears to go into standby (control pod LED goes red). It stays in standby and I cannot seem to power it back on without physically...-
02-03-2022, 11:14 AM -
Sub: Missing enable on +5v sec pwr rail AMD Firepro D500-B/Mac Pro late 2013
Ref: 1/ MacPro6,1 Late 2013/A1481 MD878LL/A (3.5 GHz 6 Core Xeon E5-1650v2)
Gfx-B: APN: 661-7548 PPN: 820-3533-A AMD FirePro D500-B 3GB Vmem
2/ Figure 1 Gfx-D500-B Front Facing
3/ Figure 2 +5v supply (zoom-in)
Intro:
While troubleshooting a Mac Pro(6,1) referenced above I discovered the +5v secondary supply did not stand up on the D500-B graphics card as a result of a missing enable signal. The +3.3v secondary rail was the only rail that did standup. I tried to perform...12-07-2023, 09:55 PM - Loading...
