Samsung UHD UN50JU6500
    Re: Samsung UHD UN50JU6500
    Originally posted by lfhlaw
    Ok I didn't realize I had the black lead on pin 2 (which I thought was pin 1). I tested it briefly this morning and got much better numbers similar to post#3. I will post the voltages and variance when I get back from work and if not too tired lol.
    Ground pins are pin 10, 11, and 12.
    Pin 1 is not GND pin anyway.
    • lfhlaw
      • Mar 2014
      • 102
      okay finally got time to post.
      PS-on is 3-4 Volts
      pins 3,5,7,9 fluctuate from 8 v to 13 v
      pins 4,6,8 still show about 3-4 volts.
      the A13v and the 8V standby both fluctuate from 9 v to 13 v.
      with main board disconnected.
      Testing the pullup resistor with ground gives me a fluctuation of 8v to 13 v as well
      • lfhlaw
        • Mar 2014
        • 102
        Well. I did buy a new Power Supply board and that fixed the whole problem. still not sure what caused it to fail though...so a bit concerned that it might happen again after fixing it, but will see what happens.
        • nomoresonys
          • 12200
          • U.S.
          #44
          Have seen bad voltage regulating diodes on psu make voltages fluctuate like that.
          • Asraf Atb
            Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
            by Asraf Atb
            Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
            Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
            I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
            01-27-2025, 05:02 PM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • Lee M.
            Samsung UN75RU8000FXZA bad main board?
            by Lee M.
            When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
            11-08-2023, 07:46 PM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
