Hisense LHD32D50TUK
  • LEEDASH
    • Dec 2012
    • 481
    • Bedfordshire
    Hisense LHD32D50TUK
    Hello all,I'm having an issue, I need to do the first installation and it asking for a four pin code, also asks for the pin to reset the tv.
    or alternatively is there a factory reset I can perform to sort out this issue.
  • nomoresonys
    • 12330
    • U.S.
    Re: Hisense LHD32D50TUK
    One here to try:
    Hit menu on the remote
    Tap right to enter the full menu
    Scroll down to sound
    Tap right and select Advanced Audio Settings
    Scroll down and highlight the Balance slider, make sure it is on 0
    Enter 1969 on your remote
    The menu will disappear and a green "M" will appear at the top left
    Hit menu on the remote, this time a service menu will appear. PS, may have to enter 1969 twice quickly.
    • nomoresonys
      • 12330
      • U.S.
      Resetting the TV You can choose to reset only the TV picture and audio settings to their original values, or perform a full factory reset to return the TV to the state it was in when you first unpacked and turned it on.Reset audio/video settingsTo reset only the TV picture and audio settings to their original values, navigate to Settings > System > Advanced system settings > Factory reset, and then highlight Reset TV audio/video settings. Read the information on the screen to make sure you understand what the reset operation does.To proceed with the reset operation, press [PLAY/PAUSE] three times in a row.Factory reset everythingA full factory reset returns the TV’s settings to their original state and removes all personally identifiable information from the TV. When finished, you must repeat Guided Setup, reconnecting to the Internet, re-linking your Roku account, and reloading any streaming channels. You also must repeat Antenna TV setup and input configuration. Factory reset is the recommended choice if you want to transfer the TV to another owner, and it is the only choice if you want to switch from store mode to home mode (if you inadvertently selected store mode during Guided Setup).To perform a factory reset, navigate to Settings > System > Advanced system settings > Factory reset, and then highlight Factory reset everything. Read the information on the screen to make sure you understand what this reset operation does.To proceed with the full factory reset, use the arrow buttons to enter the code displayed on the screen, and then select [OK] to proceed. When the factory reset operation completes, the TV restarts and displays the first Guided Setup screen.
      • Diah
        • Feb 2013
        • 6563
        you have child lock on the set, go to service menu under category Factory scroll down to clean chip then his okay
        TV will restart with nothing on screen, the green M still on screen. put the TV in stand by for 5 second then turn it on again, the M will disaprat
        go to menu now ... system and do factory setting. the tv will restart for first installation menu
        • nomoresonys
          • 12330
          • U.S.
          Use 0532 for the parental lockout, then 1969 once or twice quickly if needed for factory reset, should do the trick.
          • sheffieldyorky
            ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
            by sheffieldyorky
            Hey there people
            While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
            This is what I tried, but not in any order.
            Google
            YouTube
            BIOS
            Command Prompt (administrator privileges)
            On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
            10-25-2025, 02:22 AM
          • masterm
            JVC LT-43C888 (manufactured by Vestel) does not start after trying factory reset, details below
            by masterm
            TV: JVC LT-43C888 (purchased in 2018). This is a smart TV with Netflix, Youtube, Freeview and other applications via 'Viewd' app store
            Problem with TV:
            - Netflix stopped working so i tried to do factory reset from the TV menu.
            - I confirmed on-screen but the factory reset did not happen even. It did not take me to 'first-time installation' screen as mentioned in the manual.
            - After waiting for some time, the TV went into a boot loop.
            - JVC logo comes on the screen and LED light flashes for some seconds, then it reboots again and the same thing happens
            04-30-2024, 03:03 AM
          • YG007
            Asus BIOS How To Reset To Default Settings?
            by YG007
            Hello... Where do I start. I have 2 questions/scenarios that might bring this laptop back to life, so here it goes!
            I have this laptop (Asus UX52VS) where I was flashing the BIOS to it and it froze during the process. I didn't have a reliable BIOS chip programmer at the time (It was a CH341A USB Programmer from Amazon where it took hours just to get the clamp on the chip and then every time I read, it gave me different results/corruption, and never would pass the verify test as no 2 reads were the same data), so I brought it to a shop. They had it for almost 2 months, but during...
            06-05-2023, 08:22 PM
          • RetroComputingGrotto
            New Toy UNI-T UTi260B - What Settings?
            by RetroComputingGrotto
            I've literally just received in the post a UNI-T UTi260B (it's currently on charge).
            After quickly scanning the user manual I see there are all sorts of configurable settings (Measurement settings, Palette settings, Point temperature settings and Image Mode). As this is my first Thermal Imaging Camera I have no idea what all these settings are nor if I need to change/configure any of them.
            I intend/hope to use this to help me diagnose issues with laptop motherboards so should I just leave the settings as the default or is there someone out there with a UNI-T thermal...
            09-02-2025, 08:36 AM
          • Shpic
            DELL Inspiron 7567, Brick, BIOS restore to Factory settings issue
            by Shpic
            Hello everyone!
            I have a weird situation. I'll try to explain. I bought my laptop with Linux. After half a year I decided to install Windows 10 Pro x64 (I bought it). So, I wiped everything on my HHD drive and installed W10 without any problems. For 3 years the laptop worked well, but I decided to give it to another person. I started preparation to a new user. Firstly I restored Windows to default settings with wiping all user's data, it went well with no issues. And the last point was wrong for me, I decided to restore also BIOS (1.15.0) to factory default. After I pressed the...
            11-22-2021, 01:45 AM
