Samsung UN40B6000VM - Black Screen, Rebooting
  • paulo_lima
    • Feb 2019
    • 4
    • Brazil
    I am just trying to find which board is the corrupted:
    TV Model: UN40B6000VM
    PSU: PSLF171B01A
    Main board: BN41-01184B
    The problem: TV is able to power on, plays the melody, but the screen stays black and no backlight, 10 seconds later i hear the relay clicking, she reboots and try to start over and over again. If i disconnect main board backlight works.
    The power supply looks nice and measures steady in all voltages the only pins i am not sure are:
    DET 5V--------4.9v
    E-PWM--------0.5v
    BL ON---------0
    Vamp 12.8----12.7
    POWER ON----0.6
    *Power on pin gets voltage spikes (~1.4v in DMM) when relay is clicking -Is it the Main Board telling the PSU to turn off?
    *Power on stays 0.6 even with Main Board disconnected.
  • CapLeaker
    Leaking Member
    • 8146
    Re: Samsung UN40B6000VM - Black Screen, Rebooting
    BLon= 0
    your main board isn't turning your backlight's on. So your problem is on the main board.
    • paulo_lima
      • Feb 2019
      • 4
      • Brazil
      Thank you, i already suspected, but needed to make sure as those boards are expensive in here.
      I know the chances of getting this board fixed are very low, but i'm giving a try, starting at looking every buck converter output and regulators.
      Any tips are welcome.
      • CapLeaker
        Leaking Member
        • 8146
        PSon and BLon are generated on the main boards main IC. I suppose you could try to trace the BLon backwards to the main IC.
        I never had much success with finding a little faulty part, as it was always the main IC's fault not generating BLon.
        You could disconnect the BLon pin from the connector that goes from the main board to the PSU. Try jumping PSon to BLon on the PSU (remember to disconnect that BLon coming from the main board, we don't want to back feed power). See what that does. Alternatively you could take any switched 2V to 5V source, put a 1k ohm resistor in series and put that to the BLon pin on the PSU.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • JDC
          (SOLVED) - ONN 100012588 No Power, Then Rebooting After Main Board Change
          by JDC
          ONN 100012588
          Issue: No Power, Then Rebooting After Main Board Change
          Short answer: replace main board and power board
          Technical answer: replace main board and Q306 & Q307 on power board.
          Long answer:
          TV wouldn't turn on. Power switch was fine which means the main board isn't processing the power on signal. Replaced main board. TV turns on now but randomly reboots. Bad main board? EEPROM? Tried to pull main board and got a shock touching the corner of the board. That's weird. C334 (450V 10uf) capacitor is still holding a high charge....
          07-15-2022, 07:39 AM
        • Asraf Atb
          by Asraf Atb
          01-27-2025, 05:02 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
        • Lee M.
          Samsung UN75RU8000FXZA bad main board?
          by Lee M.
          When plugged in it will click and cycle the BL on and off, no pic and does not respond to remote. When I disconnect the cable from the PS board to the main board and then plug it in the BL will come on and stay on. There are only two boards in this set, the LVDS cables from the panel driver boards connect directly to the main board. Since the BL comes on and stays on I'm thinking the PS board is ok and the problem is on the main board. Should I order another main board or do I need to do more testing? thanks, Lee
          11-08-2023, 07:46 PM
