Samsung UN40B6000VM - Black Screen, Rebooting
  • paulo_lima
    • Feb 2019
    • Brazil
    I am just trying to find which board is the corrupted:
    TV Model: UN40B6000VM
    PSU: PSLF171B01A
    Main board: BN41-01184B
    The problem: TV is able to power on, plays the melody, but the screen stays black and no backlight, 10 seconds later i hear the relay clicking, she reboots and try to start over and over again. If i disconnect main board backlight works.
    The power supply looks nice and measures steady in all voltages the only pins i am not sure are:
    DET 5V--------4.9v
    E-PWM--------0.5v
    BL ON---------0
    Vamp 12.8----12.7
    POWER ON----0.6
    *Power on pin gets voltage spikes (~1.4v in DMM) when relay is clicking -Is it the Main Board telling the PSU to turn off?
    *Power on stays 0.6 even with Main Board disconnected.
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8352
    Re: Samsung UN40B6000VM - Black Screen, Rebooting
    BLon= 0
    your main board isn't turning your backlight's on. So your problem is on the main board.
    • paulo_lima
      • Feb 2019
      • Brazil
      Thank you, i already suspected, but needed to make sure as those boards are expensive in here.
      I know the chances of getting this board fixed are very low, but i'm giving a try, starting at looking every buck converter output and regulators.
      Any tips are welcome.
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8352
        PSon and BLon are generated on the main boards main IC. I suppose you could try to trace the BLon backwards to the main IC.
        I never had much success with finding a little faulty part, as it was always the main IC's fault not generating BLon.
        You could disconnect the BLon pin from the connector that goes from the main board to the PSU. Try jumping PSon to BLon on the PSU (remember to disconnect that BLon coming from the main board, we don't want to back feed power). See what that does. Alternatively you could take any switched 2V to 5V source, put a 1k ohm resistor in series and put that to the BLon pin on the PSU.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • JDC
          by JDC
          ONN 100012588
          Long answer:
          07-15-2022, 07:39 AM
        • Asraf Atb
          Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
          by Asraf Atb
          Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
          Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
          I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
          01-27-2025, 05:02 PM
        • mrautom8
          Samsung TV UN75H6350AFXZC main board schematics?
          by mrautom8
          Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
          Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
          While relay is on, all voltage rails are present and steady (scoped) on main board.
          I love a good logic puzzle but getting lost without any schematics.
          No shorts on ANY capacitor main board.
          Thermal camera shows 3.3V inductor getting warm instantly but...
          10-19-2025, 06:32 PM
        • ygorsan
          by ygorsan
          🧩 Problem Summary:
          • I
          07-28-2025, 08:34 AM
