Panasonic Viera TX-26LMD70 Powers off after a minute....
  • reessi
    • Jan 2016
    • 334
    When plugging in it powers on for around a minute or 2 depending how it feels, everything is working during that time, picture looks good. Then powers off with green led continuously flashing fast.
    I have replaced the 3 filter caps on the PSU and the 2 filter caps on each Inverter board to no avail.
    I was thinking could be tired backlight CFL's? But unplugging the signal cable to the Inverter and the backlight will stay on fine (I had to jump the MOSFET that turns on power to the inverter on the PSU as the set will not turn it on with the signal cable removed from inverter.
    Any thoughts? I have schematic for the PSU, I think this is working since all it does is output 24V.
    When plugged in the 24v for the main boards is always on, the inverter power turns back off when the set turns off but I jumpered the MOSfet so is always on to inverter, makes no difference.
    On the PSu to next small power board along the top (see pic), there is 3 wires apart from 24v:
    GND,
    24V,
    24v Det - 2.96v when on leads to missing components on PSU (missing from factory).
    Sub_on - 3.22v when on then pulses on/off when set switchs off but strangly the PSU keeps the 24v on unless I remove the whole connector.
    Inv_On - 3.22v is on when set is on and off after it goes off.
    I have schematic for the PSU board, I have schematic for another chassis that contains the MAIN 2 boards called DG board but not service manual for whole TV and not include second Power board along the top.
    The inverter has following data lines:
    Err out on - I dont understand it - 3.15v when on, is generated from Main board, dis-connecting and backlight does not come on, does it mean error???
    ext_pwm - 3.13v, what is this?
    on/off - 3.24v - I assume from mainboard to turn on inverter but disconnecting whole cable and inverter is on all the time!
    VBR-a - 3.14v - is it variable brightness?
    Many thanks.
  • reessi
    • Jan 2016
    • 334
    Re: Panasonic Viera TX-26LMD70 Powers off after a minute....
    Actually the green flashing is not continuous its like 8 or 10 very fast blinks too fast to count and then a brief pause. Leaving it on and occasionally it will try to fire up again and backlight briefly come on. Needs unplugging for a few minutes to work again presumably when the caps have dis-charged.
    • CapLeaker
      Leaking Member
      • 8328
      to me it sounds like you have a problem with the inverter board. You can try to turn down the backlights as far as they go and see if your TV stays on longer.
      Also the problem could be with one of the transformers that go bad, bad solder joints or bad HV cap (blue) on the inverter board.
      You can try to compare the output winding of each transformer with your DMM in Ohm setting. They have to be within 3%.
      A bad transformer will run hotter than good one. Watch for discolouring of the PCB underneath the transformers.
      • reessi
        • Jan 2016
        • 334
        Thanks, I will do some more testing. I was trying to find a way for the tv to stay on without the backlight to see if it is a problem with backlight but also to dupe the tv since the backlight works fine on its own without being connected to the main board if I remove all the signal cables, it will stay on all day!
        So does not that infer the inverter is working correctly? Or will it stay on but still report that the bulbs are out of spec?
        Which signal is going back to the mainboard saying all is ok?
        Cheers
        • CapLeaker
          Leaking Member
          • 8328
          sounds like you are losing the BLon from the main board. PSon and BLon are generated on the main board.
          • reessi
            • Jan 2016
            • 334
            Hello again, after a year I decided to look at this again now we all have infinite time available..
            After some more testing I have found that if I disconnect the power to the left inverter (Main one connected to mainboard) then the set boots up all be it without a backlight but no SOS 1 Blink REd any more.
            I checked the ohm readings across the transformers as a previous suggested, both boards read 0.4 ohms on the input and output windings. I do not know if this is correct.
            If I disconnect one tube from one board then it will stay on for a few seconds and vice versa with left side. If they are both connected they just flash for a second.
            I can get them to stay as mentioned earlier in the thread but not with the TV booting.
            I cannot understand the signals. Anyone suggest if I can dupe the tv to staying on? It will only boot without power to the inverter so no backlight or I can have backlight by dis-connecting the data wires to the TV but then the TV errors out.
            I have tried alll combinations of the data lines. I thought maybe I can do something with the ERR out line, but what signal does it expect?
            Cheers.
            • reessi
              • Jan 2016
              • 334
              also i used a torch and turned brightness down to minimum but it did not help. is that affecting the backlight though or just the image sent to the lcd?
              I read online the backlight cannot be controlled even in service menu as these tvs alter brightness to simulate better contrast ratio!
              if its the bulbs are tired can there be a mod on the inverter board to not check this, how is it checking? by measuring current?
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  I would think that Error_Out is a signal to the mainboard signaling an error with the inverter which then switches off the inverters.
                  When you power up with everything connected and the backlights on, what is the voltage at Error_Out and also when it fails and the backlight go off?
                  Also what happens to the voltage at ON/Off when you initially switch on and the backlights come on and then when the backlights switch off
                  • reessi
                    • Jan 2016
                    • 334
                    Hi, sorry for the delay.
                    I am totally baffled by the Error out signal. I have 2 schematics using these boards. On one it shows the direction of signals so error out from invertor to mainboard but when testing it does not make sense:
                    When connected the error out goes to 2.78v when the inverter is turned on and then to 0v when it turns off.
                    So I dis-connected just that wire and the invertor gives no output at all. But the mainboard is producing the 2.78v? But why, it clearly states on the schematic the signal should come from the invertor. Can it be that the invertor pulls the 2.78v low to ground to tell the mainboard there is a problem? But if so then leaving it dis-connected would have solved that?? Even when dis-connected the tv turns off with invertor SOS. How can it know there is a problem if nothing comes from the invertor?
                    Cheers.
                    • reessi
                      • Jan 2016
                      • 334
                      The on/off goes to 3.15v when turned on! When disconnected there is a voltage coming from the invertor which again is confusing to me. When dis-connected there is 1.8v on the invertor side! If you short that to ground the invertor turns on so seams like it turns on if pulled high or low from 1.8v... It only has to be done momentarily and then it stays on or goes off, just changes state.
                      • reessi
                        • Jan 2016
                        • 334
                        So I can choose to have tv boot but no invertor or invertor on but tv not boot. The tv boots if 24v is removed from invertor but data cable is left connected.
                        • reessi
                          • Jan 2016
                          • 334
                          A new problem has surfaced just yesterday, sometimes when I plug in tv it flashes the green led to start booting then can hear tiny pulse noise from power supply and it turns off and then starts booting again! Not sure if related or new? It behaves as before once booting commences. It does not do it everytime and never did it last year when I was testing many times.
                          • simwalsh
                            Philips 47PFL4606 Powers on, works normal then powers off after a minute
                            by simwalsh
                            I am new to this forum and have searched for some answers with problems similar to mine.
                            Philips TV powers on as normal for about a minute or less then click and no power at all not even standby light. If i disconnect from mains and reconnect it will power on again but for a shorter time. Once i leave it disconnected from main for a longer time it will power on for a longer period the next time.
                            It sounds like a power supply issue?
                            I have the board out and want to run some tests. Not sure what i should be doing but i put a 1k resistor across SB and +5v...
                            12-04-2023, 04:03 AM
                          • nobbnobb1
                            Panasonic TC-P50U50 Powers Off - 8 blinks
                            by nobbnobb1
                            I have a Panasonic TC-P50U50 plasma TV which powers on briefly, then powers off and flashes the power light with 8 blinks. This TV is infamous for this, of which the suggestion that the SS board has failed due to loose grounding screws and requires a replacement of the following components on the SS board:
                            2x DG302 (Q16051)
                            2x RF2001 (D16041)
                            2x 5.6 ohm SMD resistor
                            1x BD8694 IC
                            I have already gone ahead and replaced these components, as well as cleaning off the ground connections on the SS board as well as the associated...
                            03-21-2023, 08:33 PM
                          • mostachio
                            Looking for help diagnosing a 65" Panasonic Viera TV - TH-65DX700Z (Turns on - Clicks - Turns off)
                            by mostachio
                            Hi Badcaps,
                            I've had a friend discard a TH-65DX700Z Pansonic Viera Television and I've decided to have a go at repairing it. If possible could I please get some advice in terms of diagnosing the problem so I can purchase the appropriate parts for repair whether it be components, a repair kit or a replacement board. I am happy to post pictures if required.
                            TV Details:
                            Model # - TH-65DX700Z
                            Symptoms:
                            The television turns on and displays a picture then makes a clicking sound and turns off.
                            I haven't opened it up yet but...
                            09-04-2024, 02:32 AM
                          • Ama Chur
                            Panasonic Viera LC470EUN (SE)(M2) T-Con issue?
                            by Ama Chur
                            After watching some youtube videos and checking some forums, I'm at a loss. With both ribbon cables connected, we have no image. With the left one pulled out, the screen is black and white, split down the middle. With the right cable removed, it is all black. Backlight is working fine and we have sound and can open applications. We are strapped for money right now and are hoping to repair whatever the issue may be. I think the TV was manufactured in 2012, so I'm aware that may not be possible. Edit: Found a single vertical line of blue pixels on the left side of the screen with one of the ribbon...
                            02-21-2025, 08:12 PM
                          • badcappo
                            Dead Panasonic Viera TX-P65STW50 Plasma TV
                            by badcappo
                            Hello, got a ST50 plasma TV for repair. No signs of life, not even blink codes. Opened it up to check the power supply, type MPF6914. Apparent issues from visual detection and measuring for shorts:
                            Diode type G972s6 - D101 with a short
                            Mosfet 06N90E - Q301 shorted
                            Fuse T5AH 250V - F103 blown
                            Diode D301 shorted
                            Relay DG1U-17VDC II - RL001 blown
                            I have not found a circuit diagram. Maybe someone here already dealt with a similar issue? Thanks for tips where else to check 😀...
                            11-24-2024, 11:27 AM
