So far on this unit I have replaced the chip shopjimmy.com said would fix this problem. It did not do so. I have purchased another main board that matches up to the original in every way and it still does the same thing. It powers on and then the screen starts cycling thu different colors nothing more. I've checked all connections for proper connection. Has anyone else seen this issue and can offer some advice. Thanks.. Ps I've looked for a service manual and can't find one freely available.
Sanyo FW55D25F stuck in color test mode
Tags: None
Re: Sanyo FW55D25F stuck in color test mode
No I looked into that as well. Numbers do match even the first parts of the serial number.Comment
Ugh... well that stinks... I've got one more idea, since there is an MSD chip on there. A while back I've read out the firmware on my monitors with a programmer through the VGA port. Well that produced the same color cycling. I wonder if you can push firmware to the board?Comment
I've never done that before... bit beyond what i can do at this time.. I have tired two different boards in this TV and both are doing the same thing. How could both of them be corrupt. I thought they might be in some sort of testing mode i could get out of but i have tried every button combination i can think of to get it out of this mode and nothing has worked so far.Comment
Maybe try this to get back into service menu, don't choose that test mode, just see if you can do a factory reset or exit if it goes away just turn tv off:
1 Unplug the power cable.
2 Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
Use the {CH+} {CH-} buttons to select menus.
Use the {VOL+} {VOL -} buttons to change settings.Last edited by nomoresonys; 03-09-2019, 10:53 PM.Comment
Have to be VERY CAREFUL what you do in service mode, always make note of settings in case you need to change them back, have read many nightmares about people messing their tvs up and not knowing how or just not being able to recover.Comment
I have already tried that and it didnt work. I have tried about ever key combination i can think of. SN# wise it is a ds9 version. The standby light does flash 5 times before the tv turns on. The it starts flashing colors like is seen in the video. The video posted is mine. https://youtu.be/pDfnEWaIC1g
I cant seem to figure out why it is doing this. It also does it when i put in a replacement board that matches the original in every way.Comment
May be a firmware mismatch, had a sony that did that with every board also, did a firmware update and fixed it.Comment
can not find any firmware for this tv. ive been looking all over the place and have had not luck. I cant even find what the 5 standby light flashes mean. Sanyo's website does not have any firmware for this tv and i cant find any where or anyone that has it. this is like beating a dead horse....Comment
Not sure that sanyo has any blink codes, my kdl sony didn't have a blink code. That's what's nice about panosonic, some sonys and sharp, the blink codes.Last edited by nomoresonys; 03-10-2019, 05:40 PM.Comment
ive not been able to find any. If they do they are keeping it to themselves. Freaking non repair throw away society... would be nice to have free or cheap schematics and information to make it easier to repair things. Come on we are keeping things from going into the landfill and giving items new life again.Comment
Maybe try calling them, I've heard on rare occasions that some of them, not sure about sanyo tho, have sent people firmware or directed them where to find it, a bit of a longshot but how else to find it? http://www.sanyo-av.com/us/support/contac-f.phpComment
Maybe the issue is power on some line going from the power board to the main board that is not getting power and causing this issue. the line going from the power to the main is one of those flat cables that are pushed it to the connector. they( the boards) dont really have it marked what line is what. but maybe there is a line that is not feeding power somewhere it is suppose to and it is putting both boards into this mode and keeping it from coming out of it.
both boards have this problem. the tv does not have a tcon board. its the only thing that makes sense.
There is a long narrow board that is attached to the screen like all lcd tvs have and the main board is connected to it by a cable. This tv is a ds9 sn# so I'm guessing it is a version 9 setup. My guess was that the tcon board was built into the main board.Comment
I will post some pictures when I get the opportunity to do so. There are a few places that has voltage listed next to them and they are getting those voltage or are within a volt of it. The TV does have a standby light and it flashes 5 times before the tv powers on. Once the TV turns o. The whole screen switches from one color to the next, then it cycles again. After about 10mi minutes the tv will shut itself off.Comment
Did this just start happening on its own?
Or did you repair this TV, and this happened during your fix?
Tell us more about your panel? Manufacturer? Part number?
Or include photos of the rear of the TV.
I have a 24" Samsung LCD TV that I repaired because the insulation on the ccfl high voltage wires was bad and arcing to the back of the panel. I disassembled the panel to wrap the wires with new tape and insulation. But during testing, something on the long narrow board attached to the top of the LCD panel contacted the metal panel frame, and shorted out or something...
Long story short, my panel does the color test regardless of which mainboard is installed... Something on the narrow Panel circuit board may be damaged.Comment
It was doing this before i got it. I replaced the ic that shopjimmy said would fix it but it did the same with the new chip. I then purchased s replacement main board that matched in every way. All the numbers on the board match the original. But it still does the exact same thing with the replacement main board. I have one of those magnifying lights and I've looked over the board at the bottom of the tv that attaches to the screen and I have not seen any issues. I will try to get some pictures of the back of the tv and all the boards this weekend when I can find the time.Comment
by YellowJacketHi friends,
TV has stuck at - as I googled the term - color test mode. Slowly flashing colors white, red, green, blue, black, over and over again. I tried some hints from internet, like pressing some remote buttons, but nothing worked. I also tried factory reset for Sharp TVs => "while holding vol– & input buttons on tv plug in set when “k” appears push vol– & chan- " , but TV doesn't even start during buttons pressed.
So I decided to flash new firmware to SPI ROM. What do you say, would it help? If so, where can I find some dump? I was unable to find... -
by gordesky1So 2 years ago a surge hit this monitor:/ which years before i got it going again replacing the 2 16v caps on the main board C80 and C83.
After the surge all i had was a black screen with a blue led than it goes orange after secs.
So i took it apart to check it which i didint find no issues.. But my dam luck a screw driver drop on the psu and big spark happen and it blew the small 250v box fuse.
So it sat for a year till i ordered new fuses on amazon 2 days ago and got them in yesterday.
So i took it apart replaced the fuse...-
by StuntHi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
screen that's it and stuck there. I left it until the following day and i still...09-02-2025, 01:51 PM -
by kiko1This is my third or fourth SHARP AQUOS with this symptoms....
I did it every time...but this one is driving me crazy...there is no buttons on the TV...only remote control (OMG....RF one, not IR)
Can someone post a solution for this one please?? -
This specification for the HP EliteBook 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support boardview and 840 G5 + Color LaserJet Pro MFP M477fdw + 3 year NBD HW Support schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...09-06-2024, 08:23 AM
- Loading...
