panasonic tx48cx400 difusser order
  • daphney
    • Feb 2014
    • 93
    • uk
    so i pulled tv apart to fix dead led & that is done now i can see leds shine threw the picture i was a dumbass & moved diffusers so at moment is hard plastic above leds then shiny then white have tried a few different ways & always same
    theres only 3 how hard can it be
    please help
  • Diah
    • Feb 2013
    • 6558
    Re: panasonic tx48cx400 difusser order
    the hard plastic one, it had 2 surfaces one hard and other fine. the fine surface should be on the top
    • R_J
      • Jun 2012
      • 9623
      The hard plastic should be the first, If it has small bumps on one side I believe that goes toward the led's, the other sheets I'm not sure of but you may have them in backwards, the shinny one should be a fresnel, (circle pattern on one side) That side goes toward the leds
      • signal.quest
        Panasonic LED TV TC-40A420U - Replaced Backlight LEDs but now no image/display or garbled
        by signal.quest
        I have a Panasonic LED TV TC-40A420U. The TV was given to me as an attempt to fix or throw out. I replaced the Backlight LEDs and now the screen lights up, but there is no image/display. If I play with the up/down buttons I can get the display to change from black to garbled. I can't get sound from HDMI but not sure of what input is selected. I have no remote control. When I connect a laptop to the HDMI ports it recognizes a Panasonic TV for display and sound output but I can't see or hear anything through the TV. This makes me think the mainboard is OK, but not sure if mainboard can...
        03-17-2024, 10:14 AM
      • federalhouse
        **Need Help Unlocking BIOS and Hard Drive on Dell Precision 5820 Tower**
        by federalhouse
        I'm in need of assistance with a Dell Precision 5820 Tower. The BIOS is locked with "Dell Security Manager," preventing access to the HDD-1 hard drive.
        **Background:**
        I recently purchased this Dell Precision 5820 Tower from a recycler who salvages equipment from abandoned office spaces. The computer was left behind by its previous owner and was password locked. Given that it can run Windows 11, I saw this as an opportunity to upgrade my setup.
        **What I've Tried So Far:**
        1. I accessed
        08-01-2024, 07:03 PM
      • jasakl
        Panasonic Toughbook HDDs with hard drive encryption - how to reuse them?
        by jasakl
        Dear community,
        i have searched the internet but i dont found a working solution for my problem:
        I have about 150 hard drives (mostely from hitachi 160gb HTS543216L9SA00) from Pansasonic CF-19 MK3 Notebooks.
        All devices had a BIOS Password and HDD encryption enabled.
        Now i try to reuse the HDDs, but i cant format them. I already tried windows Diskpart with argument "attributes disk clear readonly" but it says "cant delete" and i tryed several partition and low level formatters (like partition wizard, AOMEI and Easus).
        But all of...
        05-01-2024, 02:41 AM
      • howardc64
        by howardc64
        Problem
        08-04-2024, 10:36 PM
      • BigPete
        Panasonic Heatpump Dryer Repair
        by BigPete
        I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
        The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
        In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
        Unfortunately the whole machine has to come apart to fix it.
        I have...
        11-01-2025, 06:40 PM
