TV:LG55LB630V ZA,no backlight
  • JRade
    • Nov 2013
    • 28
    • Serbia
    Respect
    Please, can you write a backlight label for this TV?
    Thanks!
  • ahmedtou
    HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
    by ahmedtou
    help me please
    I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
    When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
    I will share all the details with you, including the disc information.
    Code:
    HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
    Current Profile: BD-R
    Disc Information:
    Status: Empty
    State of Last Session: Empty
    Erasable: No
    Free Sectors: 12,219,392
    Free Space: 25,025,314,816 bytes
    Free Time: 2715:27:17 (MM:SS:FF)
    Next
    08-27-2025, 08:49 AM
  • DanPoka
    by DanPoka
    02-15-2025, 05:05 AM
  • Comp_Pro
    No Backlight Macbook A1990 820-01041
    by Comp_Pro
    Hello all,
    Am trying to figure out this backlight issue with this A1990 Macbook Pro.
    Tests performed:
    There is no backlight even with a good screen.
    Backlight IC is receiving the correct support voltages.
    Fuse F8400 ok
    Current sense resistor R8400 ok
    Backlight IC is receiving 3.3V on enable pin.
    Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
    Backlight IC receiving 5V from PP5V_G3S
    Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
    I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
    05-06-2024, 10:23 PM
  • cheebster
    iPad Pro 12.9 5th Gen Backlight Issue
    by cheebster
    Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
    Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
    Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
    The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
    Anyone...
    05-20-2025, 09:17 AM
    DYMO Rhino 5200 Industrial Label Maker that the backlight does not work any ideas
    I just bought a used one for a decent price for a used device it prints very nicely and clean and clearly so I am not going to complain about it but I would like to get it working again anyone have any suggestions on how to repair this back light
    If I can not get the controller to work properly then I will probably have an external power supply for the backlight because it is difficult to see the screen without out it
    One —>the LEDs might be bad
    Two —> the buck converter or regular might be bad
    Three —> the controller might not...
    08-08-2023, 05:12 PM
