philips 43HFL2849T/12
  • lanada
    • Oct 2013
    • 50
    • Malta
    I need to enter in the service menu of Philips 43HFL2849T/12
    Any help please ?
    LCD LED TV Service Menu Codes
    TCL LED TV Service Menu Code
    LG LED TV Service Menu Code
    10-31-2024, 03:58 AM
  • tusiime
    How to access Vizio m652i-b2 service menu
    by tusiime
    The current main board on my Vizio m652i-b2 only has 1 of 4 HDMI ports working. Also, the coaxial port is not working.
    So I ordered a replacement board. It boots up the tv, but the display is dark in areas, colors are off, etc. I have seen information online that a setting in the service menu may need to be adjusted. Have tried many ways to access the service menu using remote codes, but none work.
    Can someone here provide the confirmed method for accessing the service menu on this tv? Thanks in advance!
    09-15-2023, 09:57 AM
  • sohail5307
    I need how to open this Dell service menu option in dell latitude e6420
    by sohail5307
    I need to open service menu of Dell laptops like image in attachment
    Ignore my English
    I want beacause i flashed mec5055 using rt809h now it's does not have service tag, but when I install service using F2 in bios setup after save service tag and press disable manufacturing mode using alt+f then battery chagring is permanently disabled. I want to resolve this problem...
    01-13-2023, 05:56 AM
  • yoritomo
    Philips 40PFK4100/12 CI key fail error
    by yoritomo
    TV Philips 40PFK4100/12
    Chassis TPN15.E LA
    Hello everyone.
    I am facing a red message above the screen permanently, also the image is greyed and the TV is unusable as is in any sources.
    Of course I tried everything basic or a bit advanced, so I updated the firmware to version 2.550 which did not resolve the problem.
    Accessing the secret menu by I have access to 3 interesting parameters regarding this issue
    -DRM Warning
    -CIPlus Query
    -CIPlus update
    Obviously I tried to set DRM warning to OFF but this don't...
    08-17-2025, 12:27 PM
  • Storyteller12
    QN55Q60R Service Menu Panel Help
    by Storyteller12
    I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
    I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
    I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
    the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
    01-13-2024, 01:57 PM
