Samsung un65eh600f power problem
+ More Options
Posts
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    I checked this unit out which is actually my own tv and the only voltages on cnm803 is 5vdc on 13 and 3.4 on 14.The power supply is new or as far as i know its new.Cant get lamps to fire up but i did do a tear down and all lamps tested ok.All around 58-59vdc on my lamp tester.The power supply did come with an apparent crack around the screw hole but no trace damage.
    UN65EH6000f
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    Re: Samsung un65eh600f power problem
    pics
    • neilc6
      • Nov 2015
      • 1550
      Does the backlight come on with the cable from the main board disconnected?
      • sputnikoff
        • Feb 2016
        • 203
        • canada
        no the backlights dont come on with cable removed.Cnm803 that is.
        • captainKKK
          • Sep 2018
          • 287
          I think you should plug an active HDMI or VGA to the rear port and power up again, test the voltages now with the active input selected by pressing the input button one time wait ten seconds, press it again........just from my experience.........
          • sputnikoff
            • Feb 2016
            • 203
            • canada
            Ok will give that a try.Further info....The light blinks once every 8-10 sec.I did some checks and found Diode 801 shorted which later was icm801 as regulator was shorted.I switched them to no avail but further checks tomorrow.
              Power supply/LED driver board BN44-00560A.
              BTW, the TV is Samsung un65eh6000F, correct? not 600.
              1) There is nothing wrong with that SMPS ICM801 because it drives the power transformer TM801S and you are getting the Swiched 5V (PIN 13 B5VDC) which mans the PS-ON is present.
              2) What is the exact designator of Diode 801? The designator for the Diode is Dx####. Location?
              3) What Voltage do you have on BLU_ON/OFF?
              4)What Voltages do you have on all the pins (except GND) of that CNM803? You MUST out down the pin name and follow by the Voltage reading for each pin so we can easily see from the reports as to what it has on each pin.
              4) The LED drive Voltage is rated at 242V @185mA, So with the TV off, all cables back in place, set meter so it can read higher than 300V range. Leave Black probe on the chassis, red probe on D1+ then turn the TV on while watching the meter to see how high the Voltage jumps up to then wait 10 seconds to see how low it goes down to, repeat the same thing on rest of the pin of the LED connector.
              • mrtek
                Samsung UN43NU6950FXZA No power
                by mrtek
                Hi
                Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                Main fuse = OK
                Back light LED = OK. Power them with aux power source
                LED output = OK 156V
                I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                07-20-2025, 08:06 PM
              • theone111
                by theone111
                3. Problem: TV shuts down
                07-22-2024, 10:36 AM
              • Duranitron
                Asus x512dk rev 2.1 power on problem
                by Duranitron
                When I reflash again the bios of hoaca388 the unit powers on and the unit lives!!! Hooray!! All voltage in the coil 3.3v, 5v and 6.7v indicate charging are all present. including the cpu voltage , EEPROM and GPU voltage the unit is now alive, normal screen booting to windows and log in screen until I power it off. Then the unit never goes on even when pressing the power button in the keyboard.. Voltage reading 19v main , 3.3v VCC in IT8225E-128 and EEPROM VCC 0 volt and the charging voltage 0 volt.
                Try to trace the power switch button goin to the power switch IC PU8803 (APL3533AQBI-TRG)...
                11-26-2024, 10:22 PM
              • EazyBone
                LG OLED55C9PUA power problem
                by EazyBone
                Hello, trying to fix C9 55 inch. I have pulled the back and all looks completely normal with nothing burnt so far. This is first time attempting to fix a tv so any help is appreciated.
                Problem. I hit power button, red light on TV turns off and tries to turn on, no picture shows up and then shuts off. This occurred after house power turned on and off, not from a storm.
                I have tested the power going from power supply to main board, all 12v and 20 volt readings are proper when I hit power button.
                The power supply to t con is different story.
                This...
                06-23-2023, 07:43 AM
              • bcstedt
                Samsung PN50C540G3FXZA 50" Plasma, power cycling, Y-Main problem, Canada
                by bcstedt
                Just starting to crack into this one and wanted to get the ball rolling.
                At power on (plug in), power light on, relays click, repeat (sometimes)
                After disconnecting Y-Main from SMPS power stays on and boot up jingle is heard from speakers
                Removed Y-Main for inspection and testing
                This pic from:
                PN50C540G3FXZA Fast Track Troubleshooting Manual - Rev 1/10/12
                12-15-2023, 10:30 AM
