Panasonic TC-P65GT50 - Panel or Board Issue
  • pxg013
    • Feb 2019
    • 3
    Hello! My Panasonic plasma recently developed a problem where the far right portion of the screen has developed a black bar with just a few red and blue pixels. It's hard to see in the attached picture because I don't have any sources connected - but the far right side of the screen is black - from the group of red pixels to the right edge.
    I took the back off to take a look at and clean the connections. Everything seems secure but I cleaned and reseated anyway. Without the ribbon cable plugged in that section of the screen shows a white / static bar that moves with the default screensaver.
    My question is, would replacing the corresponding C board possibly correct this issue? Or is it the panel itself?
  • R_J
    • 9628
    Re: Panasonic TC-P65GT50 - Panel or Board Issue
    It is very likely the cof ic is defective, and that is part of the panel. sometimes if you look at the ic through a magnifier you can see that it is burnt.
    • pxg013
      • Feb 2019
      • 3
      Thanks for the quick reply. I went ahead and bought a new C1 board off of eBay because they're cheap. I guess I'll try it out when it arrives - but are you thinking based on what you saw in my photos that it probably is the panel itself? In other words, unrepairable?
      • howardc64
        by howardc64
        07-24-2025, 05:17 PM
      • Soulzink
        Samsug washing machine. Power supply DC41-00189a board issue
        by Soulzink
        I am trying to fix a samsung washinmachine power supply main board.
        I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
        Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
        The power supply board reference is the following: DC41-00189a
        I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
        04-19-2025, 06:26 AM
        by sam_sam_sam
        After all of...
        07-13-2024, 08:14 PM
      • Asraf Atb
        by Asraf Atb
        01-27-2025, 05:02 PM
      • Stephen
        A2991 Logic Board issue, 20volts 0 amps help!
        by Stephen
        Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
        09-10-2025, 03:16 PM
