Samsung UE480H6400AK
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Morning all, I have a Samsung UE480H6400 which had BL failure, have replaced all faulty BL's, tested and now BL comes on.
    Problem i'm seeing is when you power the TV on with TCON connected there is no picture no BL's but the TV is still powered on, You can hear it working when pressing volume up or down on remote or side Toggle.
    If I disconnect either ribbon going from TCON to Panel the backlights come on Still nothing on the screen though. Could one or more of the ribbons on the panel be damaged or could the drivers in the ribbons be shorted causing this NO PICTURE NO BL fail when all connected up??
    Hope this make sense, and thanks for any help in advance.
    S.
    • 12129
    • U.S.
    Re: Samsung UE480H6400AK
    Test all pins on connector from mainboard to powerbard on powerboard side, all boards connected. Test in standby/plugged in but off, then apply power report both conditions, example: pin 1 bl-on=0 volts standby and 3.3 powered on, report results for every pin. How to video in my signature below.
    • vinceroger69
      • Mar 2012
      • 6714
      is the lcd panel pcb on the top or bottom of the screen i wonder if its water damaged from people cleaning the screen
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        PCBS are on the bottom of this model. Thanks
        • vinceroger69
          • Mar 2012
          • 6714
          have you checked them over for any sign of liquid damage and corrosion
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            Thanks for the reply I will do this tonight when home and report back the findings.
            • StephenU
              • Dec 2013
              • 230
              • United Kingdom
              Here are my findings >>
                • 12129
                • U.S.
                Not sure, maybe something on tcon or panel, causing the no psu-on voltage?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Is this a 3D smart tv. Do you have any photo's of the circuit boards and the interconnections between them.
                    We need to see the pictures of what we are dealing with.
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Yes Dick I do believe this is the 3D smart TV - I will get pictures of all boards and upload tonight.
                      The pictures below are of the exact same model if any good until I get home later on tonight.
                      S.
                      • StephenU
                        • Dec 2013
                        • 230
                        • United Kingdom
                        Budm I have attached pics of the exact same boards within my set above, tonight I will upload my own and showing all interconnections etc.
                        TIA
                        S.
                          "If I disconnect either ribbon going from TCON to Panel the backlights come on Still nothing on the screen though. " So if all cables in place, do you get 12V at the T-CON fuse?
                          • StephenU
                            • Dec 2013
                            • 230
                            • United Kingdom
                            Hi budm I get 12v at the fuse both sides with the ribbon connected and disconnected.
                            S.
                            • gabiz_ro
                              • Mar 2011
                              • 167
                              • Romania
                              I think is same T-CON
                              Check other voltages.
                              https://www.badcaps.net/forum/showthread.php?t=73506
                              • budwich
                                • Jul 2015
                                • 3097
                                ok... provide some more detail about these. "tcon disconnected"... what does that mean.... totally or "one side".
                                back up abit, you indicated, with either tcon to panel disconnected, get BL but no display... but is the display blank or white. can you provide a picture of display of these two "scenarios"?
                                  Yep, shows us the screenshot when having just one ribbon cable between TCON and panel connected one at a time.
                                  • StephenU
                                    • Dec 2013
                                    • 230
                                    • United Kingdom
                                    Tcon disconnected totally, and tcon to panel either or both side BL comes on.
                                    The display is blank. As soon as I get a minute to get back to the TV I will grab more pics and also more voltage measurements.
                                    TIA for your reply.
                                    S.
                                      09-07-2024, 05:50 AM
                                      09-06-2024, 11:40 PM
                                      09-06-2024, 08:40 PM
                                      Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook Specification for Upgrade or Repair
                                      This specification for the Samsung Galaxy Book Ion NP950XCJ-X01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950XCJ-X01DE boardview and NP950XCJ-X01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-06-2024, 06:20 PM
