Sinotec 51" Plasma Model STP-51HD20 No buttons and remote working
  • angelos
    • Dec 2012
    • 573
    • South Africa
    I ordered this sets power supply since it was blown, installed the new second hand PSU, set started up with a no signal message but now no keypad button does anything and the remote also has no effect.
    I have checked the following,
    1. Remote transmits using a remote tester but cant prove that its transmitting correct data. Scoped on IR on main and have got pulses.
    2. When pressing the keypad you see a voltage change on the relevant K0 or K1 input (check photos) going from 5V to 3.8V to 2,3V etc
    3. I warmed up the board to help any electrolytics but no change.
    4. 5Vs on the keypad connector on the main has got 5.2V
    5. I felt the temperature on the TSUMV59XES-Z1 and within 5 minutes was a roasty 58 degrees celsius or 136.6 Fahrenheit (Dont know if its normal). Is it not that IC that is generating the "No signal" banner? So then it's partly working.
    All that i am left in doing is measuring the IR, K0, K1 inputs to ground to see if there is any low resistance and replace all caps on the main
    Any help any suggestions would be sooooo appreciated.
  • angelos
    • Dec 2012
    • 573
    • South Africa
    Re: Sinotec 51" Plasma Model STP-51HD20 No buttons and remote working
    Could it be a corrupt eprom?
    • angelos
      • Dec 2012
      • 573
      • South Africa
      Any help??
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        Just a thought but have you checked that the keyboard cable is firmly seated at both ends. Maybe worth checking the solder joints of the keyboard connector on the mainboard are all good and have not loosened due to the connector being disconnected/connected.
        • angelos
          • Dec 2012
          • 573
          • South Africa
          Hi Dick,
          I have checked with my multi meter on the plug on the side of the keyboard and i get my +5V supply. I see pulses on the multi meter when i press on the remote and aim it at the sensor. I also have observed different voltage levels on K0 and K1 keyboard inputs as i press one of 6 buttons on the keyboard. Both keyboard and remote do not respond at all.
          To measure this entering the CPU would be difficult as the chip pins are so close to each other. Anything else i can do?
          I will re seat the cable going from the keyboard to the main board
          • budwich
            • Jul 2015
            • 3097
            without power on, use resistance measurements to trace and check tracks running to the appropriate devices/pins... then there is no reason to worry about track spacing. This will at least check that you have path continuity.
            • angelos
              • Dec 2012
              • 573
              • South Africa
              Yes, i will also look for the Controller chip pin outs. This will make it much easier.
              I am on the verge of buying another board. Tell me, can a corrupt eprom cause such a symptom?
              • R_J
                • 9623
                Yes a corrupt eeprom can cause that, it all depends on where in the program the corruption is. If it does'nt loo at the switch input status, pushing the buttons will have no effect. or if it does see the switch status it might not know what to do next, like output the power on signal to the power supply.
                Sometimes, you can freeze the eeprom and it will start to work, unplug the tv, then freeze the eeprom, plug in the tv and try turning it on, sometimes that works indicating a bad eeprom chip, which in some cases can be read and programed to a new ic. But not allways, but usually worth a try.
                • angelos
                  • Dec 2012
                  • 573
                  • South Africa
                  I am gonna try that, Thanks. Will revert.
                  • lafilipczyk
                    lc 80le632u - Lamp error - TV working after counter reset via buttons
                    by lafilipczyk
                    Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
                    I went through the process to get to the diagnostic screen, and got this ( attached).
                    Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
                    Any...
                    07-29-2024, 11:00 AM
                  • TyMercer
                    Can I flash a working BIOS from one computer to another of the same make, model, etc?
                    by TyMercer
                    Apologies if this is the wrong forum, but I'm not looking for a specific BIOS file, I'm trying to understand how one makes a clean BIOS file. So here's the background. I have 2 HP EliteDesk 800 g2 mini 35w pcs. One is working fine; the other doesn't have display out or working USB's nor does it have any flashing error lights. The CPU does get worm enough to cause the fan to spin up, so I think it's posting, but I just don't know. I had it working at one point but trouble started when I tried to put in a drive caddy that had a cooling fan on it. I thought it would be compatible but wasn't...
                    11-13-2025, 09:39 PM
                  • wattage
                    AOC AG493UCX 49-inch monitor - Firmware request
                    by wattage
                    Hello Badcaps Community,
                    The problem is that it will not display a picture on any of its inputs. And the on-screen menu does not appear. The power button works properly. It powers on with the remote as well. But the on-screen menu does not appear, even when not connected to any...
                    07-13-2025, 04:41 PM
                  • cstout
                    DeLonghi AC Remote only accepts 3V
                    by cstout
                    Hello all, I've been looking into this portable air conditioner's remote control and can't find what could be causing the problem - or possibly this remote is just terribly designed.
                    The remote only works at exactly 3V - if I drop it any lower, using my bench power supply, to say, 2.9V then the remote will not flash the display and turn off. I don't have any AAA batteries that are exactly 1.5V each so I'm not sure if this remote is designed this way - to only use the freshest possible batteries, or if there's a failed component in the mix.
                    I can't find any schematics...
                    06-03-2024, 03:53 PM
                  • MMH3
                    Dell Optiplex 5050 SFF - strange behavior and service_mode jumper not working anymore
                    by MMH3
                    i have many 5050sff. all of them, and how i experienced over many years for all about 250 DELLs goin through my hands, are fully flashable and can be serviced in any way when the service_mode jumper is set.
                    Never ever i experienced problems with that.
                    Now i have one 5050sff machine, where this jumper isnt working at all.
                    I do not get the normal messge that the jumper is set when booting and a short test with FPT just confirms this. Everything is locked -->> EVEN for reading !?
                    The history of the machine is that i used it in my office...
                    03-23-2025, 09:28 PM
