lc 80le632u - Lamp error - TV working after counter reset via buttons
  • lafilipczyk
    • Dec 2022
    • 7
    Hello everyone, I just got my hands on a Sharp lc 80le632u TV that initially had the 1 short, 1 long blink sequence. That indicates a lamp error, however if I follow the isntructions to reset the error counter, the TV starts correctly: no missing LEDs everything lods just fine.
    I went through the process to get to the diagnostic screen, and got this ( attached).
    Since all LEDs are working correctly, and the TV seems to load fine after reset, that tells me that the power board and the LED strips are working correctly. Could this be a main board issue?
    Any thoughts?
    Thank you for your time!!!
  • nomoresonys
    • 12331
    • U.S.
    Trying to remember these, If I recall these sharps can throw lamp errors rather easily from even small variations over time. If it's working fine now, think I would do a firmware update and use it, if it errors out again right away then you probably have a led circuit problem, of course you can always check after a while to see how many if any lamp errors there may be.
    • nomoresonys
      • 12331
      • U.S.
      Being that it's from around 2012, I would not be surprised if it had some bad/weak leds tho.
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4543
        • Italy - Milan
        My preview the error will come back.. especially in hottest temperature time or due to tv warm up..
        • nomoresonys
          • 12331
          • U.S.
          Wondering where I can get myself one of those CRYSTAL BALLS, so I too can see all the "previews"
          • lafilipczyk
            • Dec 2022
            • 7
            Thanks everyone for your replies!
            Trying to reset the lamp errors, but having issues with that. I followed the guides I could find online describing the process:
            Turn the LCD on and then unplug the power cable.
            While pressing and holding the {INPUT} & {VOL -} buttons on the remote, plug the power cable back into the outlet.
            When it powers up you will see a little "k" appear in brackets.Then on the TV, press the {VOL -} & {CH -} buttons at the same time.
            The Service Menu will be displayed.
            {CH +} & {CH -} buttons navigate through options.
            I am locating the Lamp reset option,
            {VOL+} & {VOL-} buttons to change the option from false, to true.
            To exit, turn the power off.
            But when I try to turn it back on, same lamp error led signals are present, And if I follow the above process, the counter is still 5 ( as if the reset didnt worked, or didnt save).
            Any ideas?
            Thank you!!!​
            • nomoresonys
              • 12331
              • U.S.
              As always BE VERY careful what you do in service menu, now go back and reset the lamp errors, then go up to Industry Init and set it to on, hit ok/select then when the screen changes and says success, turn tv off, for good measure unplug it wait a minute and try it. Make sure it's that one because there may also be a industry init (public) leave that one alone.
              • lafilipczyk
                • Dec 2022
                • 7
                Hello nomoresonys, thank you for the reply! The problem is that I dont have a save dialog
                I can only flip the flags from off to on, but I dont seem to have a save button, and no indication of the changes being saved.
                I went through all 26 pages of options and the only one that loops promising as a "Save" option, is EEP save on page 26 (last page). Do you know if that is the option for saving the settings?
                Thank you!
                • nomoresonys
                  • 12331
                  • U.S.
                  Check again, it might be on page 2 at the top.
                  • nomoresonys
                    • 12331
                    • U.S.
                    I don't know what the EEP is but I don't think it's for industry init.
                    • lafilipczyk
                      • Dec 2022
                      • 7
                      Hello nomoresonys, thanks again for your time! Unfortunately, no dice. On page 2 I do see the Industry init and the lamp error reset, but even if I change tthem to "ON" and wait a while it looks like the settings are not being saved.
                      Remote control is not working either so that is not helping with the navigation, but I can power through.
                      I was also able to get the TV to connect to internet, and check if updates were available but they were not ( I did that after I turned on with the input and vol- key combination).
                      Any other ideas on how to get the reset to be saved?
                      Thank you!
                      • lafilipczyk
                        • Dec 2022
                        • 7
                        • nomoresonys
                          • 12331
                          • U.S.
                          Ok, that's probably the problem, maybe clean the remote or get a new one, I believe it's reset lamp error, move to industry init, so with both on and industry init highlighted, then push ok/select on remote.
                          • R_J
                            • Jun 2012
                            • 9625
                            In service mode, change the Lamp Error and Industry init to ON then unplug the tv from the ac receptacle, wait about 10 sec. then plug in the tv You can use the tv buttons for this you don't need the remote
                            • nomoresonys
                              • 12331
                              • U.S.
                              True you can use the buttons, the remote just makes it much easier to program, especially with those big blinding screens.
                              • nomoresonys
                                • 12331
                                • U.S.
                                My instructions may not have been for that exact model, try both hopefully one will work.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  This usually does the trick for my remotes, specially when some buttons are not working, remember to never pry or push towards your hands or any body part, always AWAY from. So if it slips it goes into the air not you, gloves are a good idea for the disassembly, I put a little screwdriver thru my palm a while back doing that wrong https://www.youtube.com/watch?v=0HUEIVHSkTs
                                  • nomoresonys
                                    • 12331
                                    • U.S.
                                    Any luck?
                                    • lafilipczyk
                                      • Dec 2022
                                      • 7
                                      Hello guys, I have updates!
                                      First, you guys are awesome, thank you for all the replies and help troubleshooting the issue.
                                      Second, I am not very smart, and didnt realized the remote receptors were blocked by a ton of styrofoam. Once I removed it, the remote sure started working!
                                      Third, just unpluging the TV after making the changes did NOT work for me. Once the remote entered the chat, and I was able to hit "ENTER" via the remote, changes started saving correctly.
                                      TV now starts correctly, no error at the beginning. Will keep the error counter checked to see if it increases, and if it does I might open a new ticket.
                                      Thank you!!
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        Glad to hear it, thanks for the update.
                                        • steamboat
                                          Toner counter reset for Samsung M2825ND
                                          by steamboat
                                          Hi there, I was hoping I could find the firmware to reset the toner counter of
                                          Model: Samsung M2825ND
                                          Serial number: ZD4EB8GF3B0033P
                                          Firmware version: V3.00.01.20
                                          Toner CRUM serial: CRUM-14030352356
                                          10-06-2025, 12:02 PM
                                        • barry wilkins
                                          4017 counter reset problem
                                          by barry wilkins
                                          I have been trying to make a counter for my vehicle alarm .I need to reduce the pulses that operate the hazard warning lights.
                                          Because of the ECU you cannot connect directly to the lamps ,so I fitted a relay across the hazard switch. This works ,but because the number of pulses are odd this causes the lamps stay on ,and you have to switch them off by pushing the switch once.
                                          I had a couple of ideas ,one was to use a couple of 74121 monostable ICs to give me 2 pulses.
                                          The circuit I came up with is a Decade counter that uses counts 0 and 3 summing these together gives me the...
                                          01-10-2021, 07:05 AM
                                        • ictc
                                          Philips MDP 3380/12 Blu-ray Player – No Power, Reset Signal Always High
                                          by ictc
                                          I'm troubleshooting a Philips MDP 3380/12 Blu-ray player that shows no signs of life. The display remains off, and no buttons respond.
                                          Inside, the power supply is working correctly, and all expected voltages on the mainboard match the service manual specifications. The CPU warms up slightly (checked with a thermal camera), the crystal oscillator is functioning, but the reset signal remains high at all times.
                                          The reset circuit appears to consist of two NPN transistors, one driven by 5V VCC and the other by 3.3V STBY, as shown in the attached schematic. Should the reset...
                                          02-25-2025, 12:15 PM
                                        • sheffieldyorky
                                          ZAB/ZAB A,B/ZYJA BLOCK DIAGRAM Acer Aspire
                                          by sheffieldyorky
                                          Hey there people
                                          While working on my Acer Aspire with the OS failing to load, I encountered a motherboard number of DA0ZHQMB6E 0 REV: E. I was getting nowhere fast or slow, for that matter.
                                          This is what I tried, but not in any order.
                                          Google
                                          YouTube
                                          BIOS
                                          Command Prompt (administrator privileges)
                                          On Google AND YouTube, I was getting mixed messages, try this and try that, but when you cross reference the advice it is either the wrong model (even though you enter the correct search term) a YouTube case in point, with the search term "how to...
                                          10-25-2025, 02:22 AM
                                        • wattage
                                          by wattage
                                          Hello Badcaps Community,
                                          07-13-2025, 04:41 PM
