Sceptre E55 no power no led light. Help!!!
  • Shibbybag
    • Nov 2018
    • 13
    Ok so I have a 55 inch Sceptre E55 that the person said they were watch then it just shut off and never came back on. What should I check and how to go about it. I have a multimeter so I can follow any direction you give. Thx
    Also says sceptre version # on case A1AV93BA
    Re: Sceptre E55 no power no led light. Help!!!
    Look at the power supply board connectors to see if there are pin labels printed on the top or the bottom side of the board or not.
    • petehall347
      • Jan 2015
      • 4426
      • United Kingdom
      first check fuses .
        first check fuses .
        I hope OP at least did the fuse check without giving instruction.
        • petehall347
          • Jan 2015
          • 4426
          • United Kingdom
          multi-meter set to 200 ohms setting for fuses .
          • Shibbybag
            • Nov 2018
            • 13
            Ok so here's the pics I haven't checked the fuse I'm assuming the last picture is the fuse.how do I test that?
              • 12181
              • U.S.
              Not seeing a fuse?
              • R_J
                • 9535
                The fuse (red square) will check like a short with meter in ohms test (same as meter leads shoted together)
                If the fuse is ok, connect it back into the tv and check if you have 5VSB. 5 volts dc standby voltage
                • Shibbybag
                  • Nov 2018
                  • 13
                  So I just check it from underneath the board right? If so when I test it nothing happens my meter just stays on OL
                    • 12181
                    • U.S.
                    Test in diode mode, if you have a meter that beeps when you touch the probes together, if fuse beeps it should be ok, probe on each end of fuse, make sure you have the proper two points on bottom of board.
                    • R_J
                      • 9535
                      A common failure seems to be D10 & D11, check them in diode mode to see if they are shorted or not.
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • ipatch
                        troubleshooting microsoft surface pro 4 no power no led charge light
                        by ipatch
                        hello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
                        10-05-2023, 11:59 AM
                      • russpall
                        LG 39ln540v - red light flashes twice, no power to LED driver?
                        by russpall
                        Hi there,
                        I've got a 39" LG 39LN540V that's just spontaneously stopped working! The symptoms are - when I plug it in, the red light will flash on twice, then go out, there's no visible picture, and I couldn't see anything using a torch on the panel either. If I press the power button (either remote or on TV), the red light comes on continuously. If I press power again, the red light flashes twice.
                        The TV is using a power board EAX64905301. I've attached a diagram of the power output, I've tested the voltages with a multimeter and I'm getting the following:
                        08-27-2024, 01:07 PM
                        by sam_sam_sam
                        03-31-2024, 02:12 PM
                        Laptop computer that went completely dead no boot no power light no hard drive light
                        by sam_sam_sam
                        See pictures for type of laptop computer
                        I checked switching power supply brick 19.2 volts multi meter only
                        No booting without switching power supply connected
                        Checked switching power supply with an (28 volt ) incandescent light bulb it lights then hooked up the switching power supply again now the laptop and boots like normal
                        What the heck is going on here...
                        04-04-2025, 04:58 AM
