Sony KD49X8005C Assistance Required Please.
  • Stevie406
    • 59
    • United Kingdom
    #101
    Re: Sony KD49X8005C Assistance Required Please.
    Originally posted by Diah
    also at end it should be so as this photo
    This was how the original wiring was, and all LEDs were working when I connected my LED tester to the plug from the PSU.
    I still can't understand how some of the LEDs blew when they were all working fine.
    Share your knowledge with others,
    And the gesture will be returned tenfold.
    • Diah
      • Feb 2013
      • 6439
      here is the wrong you failed on.. i will draw it for you how your string are
      • Diah
        • Feb 2013
        • 6439
        little hard to draw,, but let me explain on your photo and comment you wrote
        take first string forexample
        on the right side you have + and - on the left side the end of the string extention of 4 led you wrote no input no out put.. actually the end of The last LED are - and it contact line on the string which go back to the first string as -
        look on it and put in mind the photo i posted before to be clear for you
        • Stevie406
          • 59
          • United Kingdom
          #104
          Yes I understand what you are saying, and also agree with your explanation, but there are no wires which can come from the ends of the LED strings. (the extensions).
          All plugs come from the wires on the right-hand side of the strings, and can only connect to one place as in the example of the picture I uploaded.
          It is like there are only 4 strings each with 9 LEDs on them.
          So the 4 strings are connected in a loop from + to - daisy chain loop.
          • Diah
            • Feb 2013
            • 6439
            correct... then only your soldering IRON had current leak. so LED damaged or maybe cold contact at them. when you removed out the string they became open. you ordered strings, you can play now with them to find the reason. for example turn each one string alone and if there off try press the one are off.
            • Stevie406
              • 59
              • United Kingdom
              #106
              Yes, I will use the old ones to learn more.
              I hope the new ones will arrive quickly and allow me to continue with this repair.
              Once again Thanks to all for the help and knowledge to have given me....
              • Stevie406
                • 59
                • United Kingdom
                #107
                Hi Guys, Just an update on the purchase of the LED strips.
                I received all the strips today, But unfortunately, one of the strips of 5 led's is defective. I have contacted the supplier, But it is the Chinese New Year Holiday, so nothing will be done to rectify this problem until they return to work after the holiday.
                I will update the status of this repair when I have more information.
                Thanks again for all the assistance I have received so far.
                • birchy7
                  • Mar 2018
                  • 25
                  • United Kingdom
                  #108
                  hi, just wondering if you went any further with this tv & fault?
                  i have kinda same problem with a X8509C TV
                  Cheers
                  • magicstore
                    • Nov 2019
                    • austria
                    #109
                    same for me - i have exact the same Symptoms on an KDL-65W855C.
                    Not the defect Leds - all LEDS are ok, all Voltages seem ok, but Poweroff/Restart About 10 s after turning on the BL, during the animated Android Balls.
                    Then after a few seconds starting again, White led on again, BL on, Android start .. and again.
                    Tried hard reset_ (Power & Vol-):
                    White LED -> after About 10 sec: green led -> still Pressing keys -> after 5 Seconds: Led off. same game, restarting.
                    Any Ideas ? Is it Bricked, and some Kind of watchdog restarting after 15-20 sec ?
                    Is there anywhere a Serial Console pin on the BMX to "see" Android boot Messages ?
                    • Diah
                      • Feb 2013
                      • 6439
                      this is wrong.. as soon after the led change from white to green you need to release power&volume -
                      try one more time till the set remain on even the screen black..when you reach the point it remain on... play firmware.
                      UART to trace boot... you can try at many places.. you need only one pin from yours TTL to GND and the RX of it try it on many point such USB or VGA socket. TTL TX you don't need right now just track the TX of the set with TTL RX
                      • magicstore
                        • Nov 2019
                        • austria
                        #111
                        Hi Diah,
                        yes thats what i did ..
                        Still no success.
                        The only difference, when i press Power/Vol- is, the white Led is getting green without a picture on the screen.
                        If I dont Press any keys:
                        Plug to power, 5 secs later white led, 5 secs later Screen comes with android balls, animation begins, 10 secs later (the yellow dot gets oval..) -> Power off, restart.
                        With pressed keys: same timing .. led goes to green (without screen on), some seconds later puff, restart.
                        Will try to find a TX signal now ...
                        • matyka
                          • Jan 2015
                          • 179
                          • Uk
                          #112
                          Hi I have same KD-49x8005C sony and My problem is stuck in reboot cycle ,will start and android logo on for 5 sec and tv will restart again . The white LED light turns on for a few seconds then turns back off and repeats this infinitely. I have tried pressing up arrow and power button together but nothing happens, I have also pressed volume down - and power button , reboot cycle again. I have also tried downloading the firmware on a USB and inserting it into both USB ports and power cycling the TV and it had no effect whatsoever. Anyone know how to write the firmware directly to the main board ?
                          • eugenuk
                            • Jan 2020
                            • united kingdom
                            #113
                            hi, I have the same problem with a Sony KD-43X8309C the same reboot cycle problem.
                            I have tried the same steps but lo luck. hey needed
                            • eugenuk
                              • Jan 2020
                              • united kingdom
                              #114
                              Hi again,
                              I have found on eBay two guys that repairs the pub for this tv type. One in UK for £150 the other in France for about £100.
                              But here is my question, does anybody knows if I can use a different PCB from a different model from the same class 4k, 43". Tv is ok apart from that stuck.
                              I am thinking if I can rebuild another tv, not on Android with a pc board from a different model or eventually replace another part that is necessary.
                              Because so many TV like mine, have this issue, they are expensive. for the same size on different models are two or three time cheaper.
                              Just a Thought. please let me know. best regards
                              • jrcobo
                                • Apr 2014
                                • 7
                                Hi
                                I have a similar problem with the 1-980-310-11 power board of the Sony TV Model XBR-55XB810C, but the difference is that the TV doesn't power on and there's nothing sign or light on (like it stay turned off).
                                In the Connector CN6401, the values are similar.
                                In the Connector CN6801, + LED = 90.30v (a little slow value) and - LED = 0.0v
                                The Q6802 (K8A50D, Mosfet N)=0v
                                I need help about it, and I want to know where to find the datasheet of the power and T-con boards
                                • jrcobo
                                  • Apr 2014
                                  • 7
                                  Sony XBR-55XB810C Assistance Required Please.
                                  Hi
                                  • jrcobo
                                    • Apr 2014
                                    • 7
                                    Re: Sony XBR-55XB810C Assistance Required Please.
                                    (Not linked)
                                    • jrcobo
                                      • Apr 2014
                                      • 7
                                      I have one picture of the power board with the values of the voltage, but I don't know how to insert here
                                      • jrcobo
                                        • Apr 2014
                                        • 7
                                        • jrcobo
                                          • Apr 2014
                                          • 7
                                          Sony TV Model XBR-55XB810C (Assistance Required Please).
                                          Hi
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
