Sony KD49X8005C Assistance Required Please.
  • Stevie406
    • 59
    #81
    Re: Sony KD49X8005C Assistance Required Please.
    Originally posted by Diah
    could you show us the data printed on the led strip
    This is the only text on the strip.
    Found this small sticker with a QR code on it.
    Share your knowledge with others,
    And the gesture will be returned tenfold.
    • Diah
      • Feb 2013
      • 6374
      maybe not sure LUXEON FlipChip White smd led chip. 1.4 x 1.4
      the first on on the list
      • Stevie406
        • 59
        #83
        They look like the ones on the strips and are the same size. But I don't know if there is any way to know what the correct current handling and the forward Voltage is for the ones on the strips is.
        I will order some Just in case they are the correct ones, and in the meantime, I will keep looking to see if I can find out the data for the ones on the strips.
        Thank you once again for your invaluable help guys.
        • nomoresonys
          • 12196
          • U.S.
          #84
          Wonder if those universal led strips from china would work, was some discussion on here the other day about them.
          • Stevie406
            • 59
            #85
            It's trying to find what size of chips they are using..... Very hard....
            Sorry for giving you guys a headache, But on a plus side, I have learned so much from your advice and guidance, My knowledge is improving with each and every step .... Thanks...
            I have a lot of larger LEDs, I was wondering if I stripped back some of the solder mask, I could fit all 36, so they were the same.
            Would that work??, or would it do any harm if I tried??
            • Diah
              • Feb 2013
              • 6374
              how may LED failed at your TV?
              • Stevie406
                • 59
                #87
                7 in total, I don't know what happened,
                I copied the existing wiring but soldered the wires instead of using the plugs and sockets.
                After installing all the strips, I began testing each strip one at a time, and that's when I found out 7 of the LEDs were blown.
                I don't know if it was by disturbing them, or the number of times I tested them with my DMMs.
                • Diah
                  • Feb 2013
                  • 6374
                  this is complex.. and make you lost.. 7 never failed a time. are they ar same string or on other too
                  • Stevie406
                    • 59
                    #89
                    They are 1 on one, 2 on another and 4 on another.
                    Very strange, as they are not next to each other on the 4 one, and it's on the ends on the other 2.
                    I find it so strange as they were all lighting up with both my DMM and LED tester before I slid the units out of the chassis.
                    • Diah
                      • Feb 2013
                      • 6374
                      what kind of solder iron you use.. can you show us ?
                      • Stevie406
                        • 59
                        #91
                        I had to increase my temp to 330c due to the large contacts
                        • zomi
                          • Nov 2011
                          • 505
                          #92
                          can you post a pic of how you have jumpered the strips.
                          • Stevie406
                            • 59
                            #93
                            I have dismantled them for testing at the moment, but I will do a sketch of how I wired them up.
                            2 Minutes while I find a drawing package...
                              LCD panel model number: SYV4942.
                              I would replace all the strips: https://www.aliexpress.com/item/LED-...924937829.html
                              • Stevie406
                                • 59
                                #95
                                Thanks, budm, I'll order them now.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  • uk
                                  #96
                                  thats a good price for all 8 strips
                                  • Stevie406
                                    • 59
                                    #97
                                    That's the LED strips ordered. "Thanks to budn for the link."
                                    I'll keep reading thru the forum posts to help further my knowledge, and understanding of TV repairs while I wait on the parts to arrive.
                                    Thanks again guys for sharing your knowledge and for taking the time to help me repair my first TV.
                                    I will notify the minute the strips arrive.
                                    Thanks again....
                                    • Diah
                                      • Feb 2013
                                      • 6374
                                      hold on... they are 8 string each had in and out of +-
                                      also it should be so
                                      PSU LED Socket + ----> to first strip+ (IN ) .. first strip - (out ) go to second strig + in , 2S - out go to 3S + in ......and so one untill the 8 string - out should go to PSU socket -
                                      • Stevie406
                                        • 59
                                        #99
                                        Yes, The 2nd string is just an extension of the 1st, same for 4th to 3rd, 6th to 5th and 8th to 4th.
                                        This leaves just 1st + IN from +PSU, 1st -OUT to 3rd +IN, 3rd -OUT to 5th +IN, 5th -OUT to 7th +IN, and 7th -OUT back to -PSU.
                                        • Diah
                                          • Feb 2013
                                          • 6374
                                          also at end it should be so as this photo
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
                                          • dkneyle
                                            Sony KDL-46HX850 Can't upgrade/update firmware
                                            by dkneyle
                                            Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                            Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                            09-25-2024, 10:44 PM
                                            Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                            This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                            09-06-2024, 05:27 AM
                                            Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                            This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                            09-06-2024, 05:30 AM
                                            Sony VAIO VGN-SR29VN/S S Specification for Upgrade or Repair
                                            This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
