Sharp Roku lc-50lb481u
  • Gdog215
    • Mar 2018
    • 29
    • Usa
    Bought completely dead screen. Just replaced all led strips. I'm getting a thick vertical line right side of screen . Bad display or t-comm issues?
    You live and you learn right?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Sharp Roku lc-50lb481u
    That looks like a tab bond issue at the buffer board. I got one with a vertical bar like that and found the tab ripped off the buffer right there.
    They call me......."threadkiller"
    • budwich
      • Jul 2015
      • 3097
      rather "funny" as you are still getting a picture thru the black area unlike the usual totally black vertical strip which usually indicates a tab problem at the bottom of the panel. I think you might have a smd component issue on the bottom edge board.
      • Gdog215
        • Mar 2018
        • 29
        • Usa
        Is this fixable? Or time to part out?
          • 12331
          • U.S.
          Strip it to the buffer board, inspect/test components there.
          • nicholas1110
            • Aug 2012
            • 127
            • usa
            Make sure you reseat the ribbon cable from tcon to panel first
            • ninja_zx11
              Sharp LC-70LE650U vertical black and red bars
              by ninja_zx11
              70" LED TV is Sharp LC-70LE650U.
              Initial problem was horizontal lines and slow motion lurrs on the bottom left of the screen. So I removed both the left and right ribbon cables from the T-con board and tried to clean it with alcohol and when I put it back, this issue appeared. I tried carefully reinserting the ribbon bon cables but same thing. I checked the traces of the ribbon cables with magnifying glass and everything looks good. I cleaned the small jumper ribbon cable on the left side of the screen which cured the horizontal line and slow motion blurs...
              07-07-2023, 11:27 PM
            • valvashon
              Sharp LC19SB24U; red vertical line comes and goes
              by valvashon
              Yes, this is a very old Sharp 19" but I would like to fix it if possible. As you can see from the attached picture there is a single red vertical line.
              Yesterday when I turned the set on, it was there for about 30 minutes then disappeared and did not show up again (set was on for another 3 hours or so).
              Today it was not there when I powered the set on, then appeared after about 15 minutes. Set has been on for about an hour and it's still there.
              From what I have read I'm guessing that this might be the t-con board and not the display itself as it does come and go.
              02-03-2023, 10:02 AM
            • mikebentley2
              JVC / sharp Roku 43"
              by mikebentley2
              Hi All
              Newbie here so be gentle.
              I've used the sticky tape trick and covered one of the pins between the T-con board (T43FHD-CLM3) and display board (ST4251B05-2-XC-4)and I get the attached video, without this pin covered I get blue screen.
              Is there a fix for this? Maybe to stop the blue screen (because of a fault on the disply board I presume)?
              Many thanks
              Mike
              11-10-2024, 09:35 AM
            • mopenstein
              Looking for Vertical IC for RCA Chassis CTC159L CRT
              by mopenstein
              I'm working on my 27" RCA console TV built in 1990. It had some vertical rollover for a few months that went away after being powered on for a few minutes. I had been meaning to open it up and check it out but it had total vertical collapse before I could get to it.
              Now that I have the time I opened it up and found a couple leaky capacitors around the vertical ic. So I figured the caps went bad and cooked the vertical IC.
              I got the caps out and replacements on order. But when I took out the Vertical IC I saw that the chip numbers have been almost completely wiped...
              09-24-2023, 10:41 AM
            • pni
              LG 49uf695v vertical coloured lines
              by pni
              Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
              11-14-2025, 03:15 AM
