Samsung DLP LED Driver Issue BP96-01803A
  • richr69
    • Jul 2010
    • 58
    Anybody have experience fixing the Samsung DLP TV (HLT6187) LED Driver board BP96-01803A?
    I have replaced all the bad caps on the Sub-SMPS. The screen eventually turns off. All 3 LEDS (RGB) appear to be good i.e. all 3 colors are displayed on the screen, when the screen is on.
    Eventually the 3 leds on the TV panel all flash, after the TV attempts to power up. From the service manual, that appears to indicate a bad Sub-SMPS or LED Driver.
    When the screen goes blank, I did confirm I was getting +12V and +16V from Sub-SMPS to LED Driver.
    Something is causing the LED Driver to turn off the RGB LEDs.
    Any thought? Thanks for any suggestions.
  • Diah
    • Feb 2013
    • 6440
    Re: Samsung DLP LED Driver Issue BP96-01803A
    i tell you from my way to deal with DLP devices such projector which are the same principle as your TV
    the way i check disconnected the 3 LED from the driver board and feed them with 12 V. to see if they are working stable or flaking or one off. when they are good. i fo to next step to foul the LED driver board to sent signal o main board that LED are on. to check if the DLP had issue by feed the RGB LED one by one with external 12V if the DLP turn off mean the issue not at LED driver.
    • richr69
      • Jul 2010
      • 58
      Hi Diah,
      Thanks for the reply.
      I had some difficulty understanding.. Are you suggesting that I power the individual RGB LEDs (one at a time) by an independent power source, and then turn the TV on to see if get the blank screen?
      Thanks.
      • Diah
        • Feb 2013
        • 6440
        Originally posted by richr69
        Hi Diah,
        Thanks.
        No Not exactly what meant. you cant do this.. let me explain it in other way
        1- disconnect the RGB LED from the driver board
        2- Poser them each one with external power supply 12 Volts. at this stage you can see with your eyes not on the screen but where the LED case mounted that they turn on in good way, not Flecking or one turn off after 1-10 second
        all above steps doing them with out turn on the TV at all.
        second there are SMPS on LED driver board which are responsible to send signal to MB Thant LEDs are ON. so the DLP circuit starting. this we can foul it by short contact to let it switched the MB ON. if you find this then you can turn on the TV .. and keep the LED feeds from external PSU. one by one. now you can watch on the screen if the DLP will turn off or keep on. if it turn off as you have before then the fault not with LED or driver.. much easy i cant explain more with out clear photos of the LED driver Board from both side
        • richr69
          • Jul 2010
          • 58
          Well, I tested the 3 LEDs with a 9v battery, and all 3 LEDs stay on without any issue. The Primary SMPS has the Sam-Wha caps (which I replaced on the Secondary SMPS which were bad), but I did not replace any of them, given none of them appeared bad or puffy. I guess I can go ahead and replace those caps (cheaper than replacing the LED Driver). If that does not fix the issue, I guess this project will come to a conclusion.
          • budwich
            • Jul 2015
            • 3097
            are you able to power up the system with onlly one of the leds disconnected at a time... I thought that was possible but perhaps not. IF you are able to do that, then you can cycle thru this to see if one of the units is the problem or not.
            • richr69
              • Jul 2010
              • 58
              I do not believe I actually have tried that. Thanks for the suggestion. I'll give it a shot.
              • budwich
                • Jul 2015
                • 3097
                If it potentially starts and works, especially with any "2 configuration", that would may point you to a common supply issue that is overloading when all 3 are connected. If a certain "2 configuration" works better than others, then that might isolate to a given led driver.
                Note: i believe that the leds are "switched" (ie pulsed) at 60hz... is that the flashing rate that you are seeing... faster , slower ?
                • richr69
                  • Jul 2010
                  • 58
                  Unfortunately the LED driver is a single board, which all 3 LEDs connect to. So if it turns out to be an issue with the LED driver, I will have to replace it. But, maybe this may isolate the circuit on the driver, causing the issue.
                  • richr69
                    • Jul 2010
                    • 58
                    The flashing LEDs I was referring to are the ones
                    indicating the power status on the front of the TV.
                    the RGB LEDs inside the TV appear to be fine. I disconnected 1 and had 2 always connected.The issue with tv screen turning off still ocurred.
                    This may be a lost cause.
                    • budwich
                      • Jul 2015
                      • 3097
                      :-( thanks for the clarification as my reading was poor on your first description.
                      So you are saying that it doesn't matter which LED output is disconnected, the set responds the same with shut down? The dlp sets "normally" lose the red led as it gets the hots. I have the next series of samsung dlp which has had the dlp chip replaced.
                      Depending on how much time you want to invest, you might try searching the avsforum in the rear display area / subforum. There use to be a poster there that rebuilt drives and salvage leds. If you get lucky, you might find some of the posts and perhap PM for ideas on what to look for or perhaps find more information therein.
                      I have to see if I can find my SM to see if there is anything more defined for the "newer" set.
                      • budwich
                        • Jul 2015
                        • 3097
                        Another suggestion trying locate the faulty part, you try some "light heating" of the caps that you "questioned" in your first post to see if they impact starting or not. Similarly, you could try cooling.
                        Lastly, if you get the set to run for a bit, you might try to look into the service menu, there is a trouble log (on newer ones) that might help.
                        • Diah
                          • Feb 2013
                          • 6440
                          common budwich the RGB LED are in part of LED driver circuit, any one of the 3 fail to turn on the driver will give error to shut down the DLP..
                          • richr69
                            • Jul 2010
                            • 58
                            Small recap...
                            In all the searching I have done, it appears this TV appears to suffer from the 'white dots' issue (fixed 3 years ago), Secondary SMPS caps, and the RED LED burning out.
                            I fixed the Secondary SMPS and as I indicated i.e. input voltage 300V (coming from the Primary SMPS) and output 12V and 16V voltage (going to the LED Driver). All measure fine.
                            All 3 LEDs appear to be working
                            How do you test the LED?
                            All 3 LEDs appear to light up, so I assume they are fine. When I get into the Service Menu I see all the colors/patterns when I cycle through the various tests.
                            When,
                            I have all 3 LEDS connected - TV screen eventually turns off.
                            I have Blue/Green LEDs connected and Red LED disconnected - TV screen eventually turns off.
                            I have Red/Green LEDs connected and Blue LED disconnected - TV screen eventually turns off.
                            I have Red/Blue LEDs connected and Green LED disconnected - TV screen eventually turns off.
                            In all the 4 cases the screen stays on for awhile. There is no pattern how long it stays on.
                            Each LED has a thermister on it going to the LED Driver Board. I disconnected them to see if that made a difference, but it did not. I thought maybe one of the thermisters went bad, causing a false indication the LED was bad (apparently not the case).
                            Unfortunately the Service Manual does not have a schematic for the LED Driver board.
                            Yeah, poked around the service menu several times. Could not find anything that would indicate anything is at fault. The only time I came across anything, was when I purposely disconnected a LED. I found the entry in the service menu which clearly indicated the led I had disconnected as bad.
                            I did not think about the hot/cold exercise. I'll try that next when I get a chance.
                            Thanks.
                            • budwich
                              • Jul 2015
                              • 3097
                              The other test is a standard "doide check" with a meter.... I think I have seen bias voltage stated somewhere... maybe in avsforum. They are not all the same as the colors are different "substrates".
                              Like others "design features", most things tend to monitor current as opposed to voltage. It is probably more likely a current (over) condition that is setting the code.
                              Can you restate / provide more detail on the failure... sorry I am slow.... :-) but does your set shut down with the code / led flashing or you only the led flashing on startup thereafter?
                              • budwich
                                • Jul 2015
                                • 3097
                                ok.... here is the best hope.... at least with an expert that seems to know about alll thing samsung dlp....... :-) This s the one that I was thinking of... he goes by the handle stanman2242 in the avsforum.com. My bet is that he can give you some tips about how to trouble shooting this further and / or even get you parts (ie. LED's). Anyway, it costs nothing to try.
                                • R_J
                                  • Jun 2012
                                  • 9588
                                  Have you checked the error led on the driver board? is it blinking? have you tried changinng the switch from int to ext mode?
                                  If you can get into the service menu, that would tell me most of the set is working,
                                  Have you checked the connections on the driver board for the led's? also do the led plugs look ok or are they burnt or discolored?
                                  I have worked on a few of these back in the stone age but only a few, they were not very common and I do remember replacing the odd led and seem to recall over heated connections due to the higher current.
                                  • budwich
                                    • Jul 2015
                                    • 3097
                                    this is the thread that I see good work in and around these sets.
                                    https://www.avsforum.com/forum/63-re...7-89s-502.html
                                    • ScHAmPi
                                      Samsung UE48JU7000 screen issue after backlight replacement
                                      by ScHAmPi
                                      Because of two bright spots and a couple of dark spots I decided to replace the backlights in my Samsung UE48JU7000. See attached photos:
                                      I thought all went well, but after full assembly and testing it out it turns out not all is fine. The backlights are completely fine but I have some weird issues on the right half of the screen. Since I didn't really touch the T-CON board (apart from taking out the ribbons of the display and reconnecting them on assembly) it would be weird that the issue is with the T-CON board... But based on the behavior of the service...
                                      07-15-2024, 05:41 AM
                                    • Chrissygizmo
                                      by Chrissygizmo
                                      02-10-2025, 12:33 AM
                                    • Chrissygizmo
                                      samsung galaxy ao2s very temperamental after screen replaced
                                      by Chrissygizmo
                                      Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                      Ive eventually managed to get it on and working but it's very temperamental...
                                      The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                      05-26-2024, 12:05 AM
                                    • wizard13
                                      Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                                      by wizard13
                                      I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                                      I have checked the forum and the available documentation but could not find a solution specific to my issue.
                                      • Brand & Model: Dynabook Satellite Pro C50D-B-100
                                      • Part Number (P/N): PYU13E-00C00PFR
                                      • Serial Number (S/N): 22028896H
                                      • System Configuration (SC): A1PYU13E1127
                                      • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                                      • Power Input: DC 19V –
                                      02-28-2025, 02:43 AM
                                    • JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                      by JunkmanJimbo
                                      Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                      No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                      Please help. Thanks in advance!
                                      08-12-2025, 11:45 AM
