55” Micromax Led TV Half screen red
  • Aljahwari
    • Jan 2019
    • 4
    • Oman
    Hi
    My tv ( Micromac MM-5517 ) 55” half screen has vertical red lines when there is no display on the screen as you can see from the attached photos.
    I tried replacing the ribbon cables from tcon to panel but nothing was changed. Any suggestions please?
  • maxvalutech
    • 804
    • australia
    Re: 55” Micromax Led TV Half screen red
    Ribbon to tcon top left seated correctly ? Connections all carefully cleaned ?
    • Aljahwari
      • Jan 2019
      • 4
      • Oman
      Yes I’ve cleaned all connectors. Ive tried also pushing, knocking them but nothing changed
      • CapLeaker
        Leaking Member
        • 8173
        try squeezing the plastic frame around the affected areas around the LCD hard.
        • Aljahwari
          • Jan 2019
          • 4
          • Oman
          Tried that too but didn't help !
          • maxvalutech
            • 804
            • australia
            The half screen affected must either be from output (tcon) or input to screen on that side (long thin board bonded to screen). If that board is at bottom of screen bad bonding connection could also be the cause. Check small caps on that board. A tcon replace may be worthwhile??
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4333
              • Italy - Milan
              No good pictures, take some new ones with the whole screen and a input source, it seems cracked screen to me..
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • valvashon
                LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                by valvashon
                The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                11-24-2024, 12:08 PM
              • Raulnn
                TD Systems K50DLG12US half black and half white screen
                by Raulnn
                good night! I have this screen that looks half black and half white. the tcon gives a low vgh value (5-6v). the rest seem fine. I first removed the flex from one half of the panel and then the other. Removing the left, vgh increases it to 25-26v. I think the problem is in that area, but there are not many elements on the integrated controller board. there are no shorted capacitors. could they be a cof? Some help?
                By the way, now the entire screen is black. Maybe some flex was not connected correctly... I have exchanged the flex and there are no variations, I don't think they are the...
                01-20-2024, 04:49 PM
              • reformatt
                by reformatt
                07-31-2025, 08:37 PM
