Samsung LN40A550P3F 40" HDTV, slow to turn on
  • sualeh
    • Oct 2020
    • South Korea
    #41
    Re: Samsung LN40A550P3F 40" HDTV, slow to turn on
    Originally posted by aaronwt6
    It appears that you have the capacitor on correctly. I offer a repair service on these and have fixed 100s of them. I have run into cases where the boards were used for so long that the original issue caused something else to fail and the end result is just an indefinitely flashing light even after swapping the cap. Not saying if that's the case or not with yours but in that instance, I've never been able to get one going again.
    Hello!
    I got hold of a LN40550A with flashing red issue. power board and caps are doing good and so are the back lights (when tested). The issue is with its main board BN94-01709k (The caps C131 and C102 were replaced with 25v 1000uF by someone)
    I replaced these caps and tv worked for a good 30 minutes and then turned off.
    Then I replaced MP2363 ic and stock smd caps, TV turned on for a little while and went back to slow red led blinking state.
    all voltages of main board keep cycling with the blinking led.
    Is there anything else that I can try?
    • nomoresonys
      • 12331
      • U.S.
      #42
      If you get it to work again, do a factory reset and a firmware update/replace, sometimes the firmware gets borked up, could be from wrong voltages a power spike etc. might not be the problem but it's pretty easy to do, when set is working that is.
      • sualeh
        • Oct 2020
        • South Korea
        #43
        Thankyou for the reply.
        it never gave me a chance to think about updating/resetting the firmware. Is it possible that cap in the power board is culprit, that provides voltage to MP2363DN as its input voltage is flashing too.
        Would it be wise to replace the main board with a universal board?
        • nomoresonys
          • 12331
          • U.S.
          #44
          Well it's not the easiest thing to do, I would do more testing first, to try to narrow down the issue if possible.
          • nomoresonys
            • 12331
            • U.S.
            #45
            Try cooling or heating the eeprom, see if anything changes, like if it stays on longer, then maybe it's at fault, one easy test to try.
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4543
              • Italy - Milan
              #46
              Check or change D102 and if not enough also D100
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
              • m1ch43lzm
                by m1ch43lzm
                05-12-2025, 08:37 PM
              • ohren
                Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
                by ohren
                I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
                I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
                The models launched in 2018 and 2019 respectively....
                09-08-2023, 05:24 PM
              • C152Heavy
                Samsung LN46C630K1F – Intermittent Backlight, BN44-00341B Power Board
                by C152Heavy
                Summary for TL-DR readers:
                • Backlight is intermittent, may come on with TV boot or not. No flickering, never fails during TV on.
                • Have obtained Samsung schematic & service documents - Can upload if helpful.
                • Have read ALL applicable threads
                • C1818 and CP820 replaced as low hanging fruit
                • CN802 data taken for normal and failed BL operation. SUMMARY: Pin 2 - 5vDet = 3.52 @normal, 0.0 @BL fail. Pin 6 - EPWM = 1.631 @normal, 1.058 @BL fail.
                • VCC pin (18) of PFC...
                01-11-2023, 02:53 PM
                09-07-2024, 05:50 AM
