Microscope for SMD soldering.
  • pocketwatch62
    • 74
    • US
    Hi Everyone,
    Just looking for hints on smd soldering microscopes. If allowed, Can i ask what
    make and model you all would recommend?
  • DXseekerMO
    • Feb 2018
    • 1119
    • US
    Re: Microscope for SMD soldering.
    Try re-posting this question here:
    https://www.badcaps.net/forum/forumdisplay.php?f=33
    I've posted questions about equipment here and I get good replies. This is the TV repair part of the site.
    Have a Merry Christmas
    They call me......."threadkiller"
    • R_J
      • Jun 2012
      • 9625
      Put this into the search above "soldering microscopes"
      • pocketwatch62
        • 74
        • US
        Thanks Guys,
        I will do that.
        Merry Christmas
        • chegueva
          My Andonstar ADSM201 Microscope Review
          by chegueva
          Hi everyone. i'v started learning electronics before the corona hit so that's not very long time ago. but anyways i started with only a multi-meter then i started getting into micro-soldering and soldering in general, got myself hot air station a bench Power-supply and last but not least a microscope.
          About the microscope at first i just wanted to get those 15 usd USB digital microscopes to try but some people talked me outta of it and i decided to go for something better but not professional as i'm just starting out.
          So i had a choice between a binocular & camera , i wanted...
          08-14-2020, 11:08 AM
        • Ady2017
          SMD fuse soldering advice please
          by Ady2017
          Hi all. I need to replace an SMD fuse on my camcorder and this is the first time I have had to do any SMD soldering so your advice would be appreciated. Below is a picture of the board that I am working on and I have highlighted the fuse that needs to be replaced. I managed to zoom in to take this picture but the fuse is really tiny and is sandwiched between other components so this is going to be a new milestone for me. I appreciate that I am going to have to buy a new soldering iron if you could advice on what I need please. I was thinking about putting a big soldering iron across the whole...
          11-07-2025, 12:03 PM
        • Azurain
          Elitebook 840 G5 Bios Chip Soldering Question
          by Azurain
          I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
          Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
          04-14-2023, 06:58 PM
        • lcdcaps1
          INSKAM Microscope USB port issue
          by lcdcaps1
          Hi
          All
          Does anyone have a INSKAM 7 inch LCD digital microscope
          I have a weird issue on the one I have where the USB port does not output enough power because when I connect a USB light or the ring light the light output is always really dim
          The ring light when connected to the microscope USB port is at the lowest brightness and turning the brightness knob makes no difference
          I have tried different cables and different USB power adapters
          I have confirmed there is nothing wrong with the ring light and the other USB light by plugging them into another...
          04-18-2025, 04:16 AM
        • Peter_1402
          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
          by Peter_1402
          Hi Everyone,
          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
          1. Soldering iron works great
          2. There is a burnt mark on the hot air gun handle.
          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
          Reed switch tested ok with a magnet.
          From the above test, I can conclude...
          07-12-2025, 11:50 AM
