BN44-00503A Repair Kit
  • PCallegari
    • Sep 2015
    • 5
    Hello, I have the power board from a un50es6100fxzc tv. I found a blown rectifier diode DP808 and transistor CP819 along with a blown fuse
    I can order the diode but have no specs on the transister.
    The repair kits at Shop Jimmy dont have the diode and do not list spec for transistor
    Anybody know where I could get the part number
  • PCallegari
    • Sep 2015
    • 5
    Re: BN44-00503A Repair Kit
    Wait, I made a mistake. I jumped to conclusions when I saw the colour around the diode assuming it was faulty. It ends up the diode is good. The discoloration is from the cap blowing out the side. I am going to order the kit from Shop Jimmy.
      That is snubber cap for that PFC diode, more likely to be 220pf 2KV ceramic disk.
      It is common failure, I doubt that the kit will come with that cap.
      • iugasilviu
        • Apr 2020
        Reviving this thread after a while, but... did replacing the CP819 and the fuse fix the problem, or did you find anything else blown? I have the same exact issue and ordered these two and I don't want any other surprises.
        • InsertCoin
          Relay Satronic MMI 810.1 bad diode & Transistor
          by InsertCoin
          Hello and happy new year ,
          my Analog Combustion Machine Honeywell gone bad and I don't know what type of diode is utilized.
          There is no mark around the body of the diode. The Schematics are general referred only, without any electronics components and values.
          The two contacts (2),(5) of the Relay Coil need 48 Volts DC to begin operating. Between these two contacts in series is the bad diode and near of contact (5) is the bad pnp (bc856b) Transistor that can be easily replaced.
          I have made a diagram of the PCB and some measurements along some...
          01-16-2024, 05:47 AM
        • harp
          what is function of diode over power transistor?
          by harp
          I see on some schematic a diode over power transistor, and dont know is in it some trick to carry current, or what is the point?...
          08-13-2025, 06:18 PM
        • asr
          Finding replacement diode iPad Pro 3rd gen A1701
          by asr
          Hello, I am looking for help to replace a damaged diode. The tristar was replaced and a diode was damaged in the process. I have a picture of the diode but dont have an exact donor. I mostly have macbooks for donors and only a few ipad and iphone boards. Diode part number: DSF01S30SCAP
          Im not sure where to find the ipad board number. Anybody have an idea where else this diode is used on other boards? Thanks....
          07-09-2024, 06:24 PM
        • unimatrix93
          TV backlight zener diode
          by unimatrix93
          Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
          So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
          Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
          The led strips has 9 6V leds.
          02-10-2025, 12:13 PM
        • Baste
          MBR3045CT and SR3045LCT Schottky diode testing help.
          by Baste
          Hello experts,
          Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
          Aneng ST182 Meter.
          Diode mode.
          MBR3045CT:
          Diode mode
          Pin 2-1 - 0.150v
          Pin 2-3 - 0.150v ...
          10-21-2025, 06:14 AM
