Epson EH-TW5200 projector doesn't turn on
  • frankie31
    • Dec 2013
    • 27
    • FRANCE
    Dear all,
    I have an Epson EH-TW5200 projector that doesn't turn on.
    I checked the main fuse near the 230V power outlet : it is OK.
    https://ibb.co/rw82xbm
    I followed the cable and I checked the voltage on this connector it is still OK.
    https://ibb.co/mSzkxhb
    I've checked individual voltages on this connector coming from the power supply : I always have 0V on each pin...
    https://ibb.co/qJpgtp3
    After looking for the service manual on the net, I only found some pictures of the whole board.
    https://ibb.co/SdHZnYJ
    I suspect the main power supply to be dead. What is your opinion please ?
    Thank you for you help, best regards.
  • nomoresonys
    • 12330
    • U.S.
    Re: Epson EH-TW5200 projector doesn't turn on
    Projector is new beast for me, could possibly be an issue with the Ballast unit? heres a good picture of one, could be hard without a repair manual. https://www.ebay.com/itm/Epson-Balla...2NV:rk:59:pf:0
    • nomoresonys
      • 12330
      • U.S.
      Wonder if you wold have access to a repair manual if you became a "partner" there at epson? looks like its free to join. https://neon.epson-europe.com/gb/en/...oginurl=/gb/en
      • narf
        Epson EB-U42 projector / Caps with 0.7 ohms ?!
        by narf
        hi all,
        first of all: i'm a (motivated) newbie, so please forgive me any stupid question i may or may not ask
        i'm currently repairing a projector: Epson EB-U42 that doesn't start (no lights, nothing).
        what i've found so far:
        - the PSU does its job and supplies 12V to the mainboard via the connector.
        - shortly thereafter, there is a mosfet (TS420-600B) where i can test 12V on the one side (in the data sheet this side is called Anode), Gate 0V, Kathode shorted to ground
        - not far away, there's the first cap with a resistance of 0.7 ohms....
        07-02-2024, 03:53 PM
      • karlox
        Request for EEPROM Firmware Backup – Epson PowerLite S18+
        by karlox
        I have an Epson PowerLite S18+ projector in the workshop showing signs of a firmware fault. I’ve checked all voltage lines and signal paths, and everything seems within normal range.
        Here’s the issue: when the power cable is connected, the power LED immediately turns blue even though the projector doesn’t start. When powered on, the fans run but the lamp never ignites. After a few minutes, both the temperature and lamp indicators turn red.
        I’m attaching the backup I read from the IC in case it’s useful for analysis or comparison.
        If anyone...
        10-16-2025, 07:48 PM
      • platinumsteel
        Epson VS250 Projector Lamp Not Working.
        by platinumsteel
        Hi guys gooday i have a Epson VS250 Projector that turns on and is also being recognized and detected by the computer when i plug the hdmi cable.The only issue the projector lamp is not working .Are these lamps repairable ? Or i should just forget repairing the lamp and just buy a replacement. Thanks...
        04-09-2023, 04:03 PM
      • pajdek
        Lenovo Y700-17ISK turn on and off
        by pajdek
        Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
        09-20-2023, 02:49 AM
        Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation P Specification for Upgrade or Repair
        This specification for the Lenovo ThinkPad P51s + ThinkPad Stack Mobile Projector Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P51s + ThinkPad Stack Mobile Projector boardview and P51s + ThinkPad Stack Mobile Projector schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
        09-06-2024, 06:11 AM
