JMB tv wont turn on MP3618-V50 burnt wire
  • wayneb
    • Oct 2015
    • 15
    • England
    Hello i have a JMB 50/204I-GB-5B-FHKUP-UK, apparently it made a bang and they could smell burning. Stand by light comes on but when you press power goes off then comes back on again.
    I assumed it was a cap on the power supply as ive repaired 2 tvs by doing this before with help from this forum.
    As you can see i found a burnt wire and all caps look fine.
    Ive found some replacement boards on ebay but wanted to know if i could repair it myself for cheaper?
  • R_J
    • 9588
    Re: JMB tv wont turn on MP3618-V50 burnt wire
    It looks like the transformer lead had a bad solder connection to the board, and it was arcing, remove the board and check the solder connections to the transformer, You might get lucky and all that is needed id to resolder the connections
    Clean any black carbon and provide clear pictures of the other side of the board
    Also check Q15 and R137,R138,R77,R78 as they might be damaged
    • wayneb
      • Oct 2015
      • 15
      • England
      thanks RJ i took the power supply off and as you say the solder was all burnt off and wire was loose. I cleaned carbon off, soldered tried it and tv is working
      • R_J
        • 9588
        Good to here, Its usually a good idea to resolder all the transformer connections and any components that are attached to heatsinks, they can also loosen over time.
        • electomech-fixer
          First post -Intel NUC 10i5 -BXNUC10i5FNH not powering on -IC burnt- request for IC details/datasheet
          by electomech-fixer
          I came across this very active forum with knowledgeable folks on electronic circuits and components, while google searching for the details of my burnt IC marked 7603 in Intel NUC board. I joined this forum today and this is my first post here.
          I recently got an Intel NUC 10i5 and had installed Linux Mint and was using it for about a month when it died suddenly and did not power up after that.(Power Adaptor is ok). When I opened the NUC , there was a burnt IC marked 7603 (and ILCB in second line). I am unable to find the details/datasheet of this IC. I will be grateful if...
          09-15-2025, 01:42 AM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • robante15
          Acer Aspire 4520 won't turn on after reboot
          by robante15
          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
          If I remove the...
          04-06-2024, 06:50 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
