Troubleshooting Philips 55 LED TV(horizontal lines and discolouring)
  • keweik
    • Nov 2018
    • 4
    • norway
    The TV is a Philips 55pfl5527t/12 where i issue is horisontal lines with weird colours. I've tries to factory reset, hard reset and software update. Did also clean the ribbons connected to the TCON unit. Should i just change the hole TCON?
    • 12332
    • U.S.
    Re: Troubleshooting Philips 55 LED TV(horizontal lines and discolouring)
    Looks like panel failure.
    • SLK001
      • May 2014
      • 264
      I would say that it does look like a panel failure EXCEPT that the horizontal lines do not run entirely across the screen. This MAY be just a TCON failure and I would say that you might be able to save this unit with a new TCON. There is also the possibility of problems with the panel PCBs that the TCON connects to (shorted component, bad cap, etc). To access the panel PCBs, you have to remove the panel bezel.
        • 12332
        • U.S.
        Agree good plan of action, it may be a candidate for a tab bond shim if it's a tab bond problem, i.e. if tcon isn't at fault.
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4544
          • Italy - Milan
          No way, it's a bad gate driver's problem, so bad panel.
          • CapLeaker
            Leaking Member
            • 8352
            I think so too.
            • rtstorm
              Philips 55PUS7303 LCD lines
              by rtstorm
              Hello, I have this 55" Philips TV that suddenly has these vertical lines on the LCD panel. I have checked the T-con board and I noticed some caps have 40Ohm I don't know if this is normal. These caps have 1.2V on them. I mark them on the photo with a silver pen. The T-con board has 1.2V, 12V, 25V, etc. Does anyone have any idea what could it be?
              i try to disconect one ribon cable and the problem is the same, one side is white other side have the lines (the same is in other way)
              T-con model: 55T32-C0L
              Main Board: 715G8579-M0F-B01-005T
              03-28-2024, 02:55 PM
            • howardc64
              by howardc64
              07-24-2025, 05:17 PM
            • grandad99
              philips 58PUS8105/12 horizontal lines
              by grandad99
              hi all and hoping i could get some help please.
              my philips 58PUS8105/12 has started acting weird.
              its getting these lines across it and sometimes a strange black half circle sometimes appears on the right hand side edge of the screen,the screen is cool to the touch all the way around except where you get to that black halfcircle about the size of a smartie right on the bezel edge of the screen,its quite hot.
              tv prob 3 years old and only used on weekends for a few hours so not done much.
              i popped the back off and cleaned the ribbon contacts all to no...
              08-01-2023, 10:37 AM
            • advant
              by advant
              02-03-2020, 12:25 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
