LG 60pb560v plasma tv no picture
  • vivalabam88
    • Mar 2018
    • 19
    Re: LG 60pb560v plasma tv no picture
    i have found something strange,
    when i only connect the bottom one i get the snowy picture look ok to me.
    but when i only connect the top one i get a weird half snowy picture with a littlebit color in it. Made a picture of it verry weird
    ill post a picture with it.
    • Biruslapio
      • Nov 2013
      • 552
      • Brasil
      Now that there's a photo I say it is a Z-sus failure, take out your Z board and look for shorts, I'm sure something is defective there.
      If you keep the TV on long enough these black splotches will clear and only the dancing pixels will remain.
      Even though does some test pattern display on the TV or it shuts down so fast you can't determine?
      Any other member that can provide insight is also helpful.
      At the solder side of sustain board there are some 5 pin optocouplers(photo) that function as gate drivers for the transistors,if the transistors themselves are good then maybe these ICs failed.
      How to test them: There can't be any shorts between red circled pins, and none between the yellow(approx 1V forward voltage and if reversed Open).
      If you find the board for cheap then maybe replace it,but first gotta make sure that is the problem.
      • vivalabam88
        • Mar 2018
        • 19
        I'm going to measure that straight away. Thank you for your good explanation of how to do it.
        I can't determine a test picture because it goes off very fast just a sec or so and then goes black.
        • vivalabam88
          • Mar 2018
          • 19
          measured some things there are a few ic that go to zero, i dont know if this is normal. so i made pictures of them.
          also the transistors i have a question about. the ones that have a red circle around them. one is measuring both ways a value of 500 and the other measures one way but not the other way.
          • Biruslapio
            • Nov 2013
            • 552
            • Brasil
            If these 421 and 505 are volts,like 0.505V it is good,if is OHMs then they are bad.
            It is hard for me to determine without having TV at hands, could you record a video of the screen when you power on the TV with both buffer boards?
            What happens if you disconnect the panel connectors to Z-SUS?
            Z-SUS has a +16V test point close to Z-bias, is it good?
            • vivalabam88
              • Mar 2018
              • 19
              hello hope everyone had a good christmas :-).
              that are indeed OHMS so that means they are bad. but in the first two pictures if those read 0 is that bad too? the first two pictures are of the same component.
              i m going to do the rest what you have said but it can take a moment for me to reply.
              • Biruslapio
                • Nov 2013
                • 552
                • Brasil
                #27
                You have to not only look if it's 0 OHM, but also if the pins are connected to the same PCB trace, in the second picture that component has not the same pinout as the optocoupler, and they seem to be connected to the same plane, 0 OHM is ok there, but if you have a short at that optocoupler that is bad.
                The "disconnect z-sus from panel" is model specific if that will work or not, LGs usually don't start in that condition
                And now to begin desoldering those IGBTs that measure low OHMs and replacing them, sometimes they are in parallel and is harder to know which one is problematic, the first one from the third picture is bad, if the opto is also bad you will need a scrap Z or Y board from another same gen LG to fully fix this one, working Z-sus boards are cheap.
                • vivalabam88
                  • Mar 2018
                  • 19
                  hi all,
                  didnt got any further with the tv.
                  didnt ordered other boards.
                  the pictures i made where from the ysus board.
                  so i have to measure the zsus board.
                  • Biruslapio
                    • Nov 2013
                    • 552
                    • Brasil
                    #29
                    Hi, did you come around to measuring both y and z boards? The picture seemed like a z-sustain issue, so i tought your findings were about that board, if it's Y then you have to decide wether to desolder and replace the IGBTs or buy a replacement board, I would desolder them anyway and measure their resistance off the board make sure they are the fault.
                    • vivalabam88
                      • Mar 2018
                      • 19
                      hello again sorry for the late reply.
                      i m going to start over again because it is confusing right now . I have made pictures firstly of the z-sus board. can you help me to determine if it is good or bad?
                      how to measure and what to measure.
                      • Biruslapio
                        • Nov 2013
                        • 552
                        • Brasil
                        #31
                        You have to measure resistance between all pins of the IGBTs, MOSFETs and diodes,these are screwed at heatsinks and on solder side SMD ones. Anything under 9k OHMs is worth noting.
                        Do this with Y and Z boards.
                        • thuss
                          • Jul 2012
                          • 317
                          #32
                          Originally posted by Biruslapio
                          You'll be taking out the Y-SUS and measuring between the pins of these circles on the images.
                          YSUS
                          Top side - if the resistors are open that's a sign that something else failed.
                          Bottom side - I circled IGBTs,MOSFETs and their driver ICs,if you find a short on any of them that's one problem.
                          ZSUS board i coudn't find any decent pics of bottom,so i circled what you should measure on the solder side of the board, under these heatsinks are the pins of the transistor and diodes.
                          Hi Biruslapio
                          Just need some advice - On ic403, ic442,ic443. The outer two legs are (on the three leg side)are beeping continuously??. But on Ic400 top left leg reads/beeps continously with leg opposite side of ic. I was going to change them over but I am not totally completely convinced they are faulty, have you got any suggestions? Thanks (I dont know what the part numbers are)
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • ohren
                            by ohren
                            09-08-2023, 05:24 PM
                          • korben_dallas
                            Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
                            by korben_dallas
                            Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
                            I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
                            I'm new to soldering but the only feasible way to fix this issue is to do something myself.
                            MY QUESTION:
                            I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
                            02-14-2024, 12:23 AM
                          • mferna14
                            Logic Board 820-00840-A Missing EDP_BKLT_EN
                            by mferna14
                            Hi dear friends., I am working on a Apple MacBook Pro A1708 , Logic Board 820-00840-A that has no backlight. The logic board powers on fine, but no display. After Checking on the backlight driver chip, I found that the EDP_BKL_EN is missing. And this Power Enable comes from the PCH. So does this means this Logic board cannot be repaired & brought back to life again? The resistance from GRD to the test point of EDP_BKL_EN is around is 0.66M ohms. R8442 (0ohms) is ok. Any suggestion/Tip if any would really appreciate. ​
                            07-10-2024, 05:18 PM
