Vizio D650i-B2
  • 6of1
    • Sep 2013
    • 43
    Re: Vizio D650i-B2
    Maybe buy a replacement board, about 10-25 bucks.
    that might be the easiest solution but cant find any in stock.
      Re: Vizio D650i-B2
      It is probably commonly failed board. Take the board to repair shop to see if they can remove the cap then.
      • nomoresonys
        • 12306
        • U.S.
        Re: Vizio D650i-B2
        • nomoresonys
          • 12306
          • U.S.
          Re: Vizio D650i-B2
          • 6of1
            • Sep 2013
            • 43
            Re: Vizio D650i-B2
            One there, best price I've seen, coming from over seas tho. https://www.ebay.com/itm/Vizio-Contr...-/222834790313
            Ty, but that is the power button, iR board looks like the one bud attached. I will look outside the US, it is a small item shipping I hope wouldn't be too painful.
            I am also going to call the only repair shop in town and see what they can do.
            Good suggestions!
            • nomoresonys
              • 12306
              • U.S.
              #26
              Re: Vizio D650i-B2
              Oops, was looking for ir, then that one somehow got in there.
              • nomoresonys
                • 12306
                • U.S.
                #27
                Re: Vizio D650i-B2
                One there, I didn't see out of stock anywhere on the page but didn't push buy button or anything. https://tvpartdepot.com/products/viz...ir-sensor.html
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • SS454
                  vizio e650i-a2 backlight flashes then turns off
                  by SS454
                  vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                  panel: au optronics T650HVN05.4
                  72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                  link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                  Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                  https://www.shopjimmy.com/vizio-56-0...-power-supply/
                  Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                  08-20-2020, 03:57 PM
                • mrtek
                  Vizio M65-C1
                  by mrtek
                  Hi.
                  picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
                  When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
                  This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
                  07-14-2025, 07:28 PM
                • howardc64
                  Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                  by howardc64
                  Failure Symptom
                  No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                  Where is the short?
                  Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                  Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                  05-27-2025, 02:56 PM
                • howardc64
                  Vizio SmartCast TV software bug that looks like hardware
                  by howardc64
                  Bug looks like hardware so thought I posted it here. Exact same behavior on 2 different model 4K Vizio TVs running their SmartCast smarttv software. After launching youtube app, press vizio button on remote to return to the smarttv menu, once in awhile, a column of bad pixels will show for few seconds on the left hand side.
                  It seems the vizio software is reinitializing hardware when returning to the smarttv menu. In general, SmartCast software isn't very good. Also will randomly (relatively infrequent) get no network connection when on wifi and require reboot....
                  11-16-2024, 05:17 PM
