Blue Screen On A RCA RLDED4633A-D TV
  • kodiac
    • Jul 2010
    • 116
    Please help with a blue screen on a RCA RLDED4633A-D TV
    I have 5v standby
    I have 12v supply
    When the TV is turned on I only get a blue screen
    The Power Button is working normally for on/off control
    All other Control buttons have no control
    Thank You
    • 12268
    • U.S.
    Re: Blue Screen On A RCA RLDED4633A-D TV
    Can you throw up some good clear pics. of all the individual boards and one of how they are all connected?
    • Andrew F. Ali
      • Jan 2014
      • 2450
      • Trinidad & Tobago
      Main Bd. issue. Probably a firmware update/reload would be required.
      • kodiac
        • Jul 2010
        • 116
        Thank You sirs.
        Would you have a link to the firmware update for this RCA RLDED4633A-D TV.
        The processors on both the Main Board and the T-Con are very hot.
        I installed heatsinks on both processors but still getting a blue screen.
        Thank You
        • kodiac
          • Jul 2010
          • 116
          The second T-Con Board
            So did you verify that you do have 12VDC at both ends of the SMD fuse on the T-CON with ref to GND?
            You also have many Voltage test points on that T-CON board that you need to check, I.E. VCC_1.8V, VCC_3.3, and on and on.
            • kodiac
              • Jul 2010
              • 116
              Yes sir I did check the T-CON board voltages for 1.8v, 3.3v.
              I will confirm that.
              Did not check for 12vDC on the T-CON SMD fuse.
              I would like to know if the splash screen firmware is programmed into the Eeprom?
              Would a firmware update be available for this TV?
                • 12268
                • U.S.
                Found this don't seem to be a firmware there for download, maybe contact them, tell them you need the firmware. http://www.rcatelecanada.com/product/rlded4633a-d
                • kodiac
                  • Jul 2010
                  • 116
                  Thank You Sir
                  • kodiac
                    • Jul 2010
                    • 116
                    "So did you verify that you do have 12VDC at both ends of the SMD fuse on the T-CON with ref to GND?
                    You also have many Voltage test points on that T-CON board that you need to check, I.E. VCC_1.8V, VCC_3.3, and on and on."
                    Yes there is 12VDC at both ends of the SMD fuse on the T-CON.
                    There is approx. 1.27 v on the each of input connectors testpoints.
                    There is 0 v on each of the output connectors testpoints.
                    I need to verify the Vcc 1.8v, 3.3v voltages.
                    • Ryan.man
                      by Ryan.man
                      02-04-2025, 12:23 PM
                    • reformatt
                      by reformatt
                      07-31-2025, 08:37 PM
                    • gbbradshaw
                      Samsung 65" UE65TU7000KXXU VER:02/UTU7000 TV Blue screen
                      by gbbradshaw
                      Hi.
                      I have the Samsung TV Model: UE65TU7000KXXU VER:02/UTU7000 which has developed the following issue: blue screen while the sound it's still working. This happened after the screen developed some horizontal lines at first and then the next day suddenly turned into blue background. the screen was not damaged or anything. I can't access the menu. I have taken the tv to a local tech to have a look and he said that he thinks that it might be the pcb board as the back-lights are working and the sound aswell . I was hoping maybe you can guide me if I should buy the pcb board or not? Thanks
                      02-22-2023, 01:31 AM
                    • siuras676
                      Dell XPS Plus 9320 blue screen and rebooting
                      by siuras676
                      I have a Dell XPS 9320 in for repair, and the machine has a strange issue.
                      First, a bit of history: the laptop came in after liquid damage and was completely dead. I've repaired all the broken traces, replaced the damaged components, and it now powers on.
                      However, it's now showing a Windows blue screen related to hardware (as seen in the picture), along with another Dell error I've never seen before.
                      Has anyone encountered this issue on a Dell machine before and could point me in the right direction? I've checked the power rails around...
                      04-07-2025, 12:10 PM
                    • Abdulrhman Alabsi
                      Dell precision 7530 blue screen
                      by Abdulrhman Alabsi
                      I have problem in my laptop, When I try to enter to windows it showes me blue screen, I changed hard driver and ram but it did the samthing...please give me the solution of it
                      02-09-2025, 10:39 AM
