46es8000 vert lines
  • Brucetafer
    • Jun 2018
    • 133
    46es8000 vert lines
    Just got this out of a dumpster and wanted to see if its savable... I fixed the power supply and everything works great except for the lines...
  • Nick's Tvs
    • Jan 2014
    • 621
    Re: 46es8000 vert lines
    Looks like a failure which is most likely because it was tossed into the dumpster. You do however have on your hands a valuable main board. Those things go for a good $100 on eBay. I would either keep it for a future repair or put that main board for sale online.
    • petehall347
      • Jan 2015
      • 4450
      • United Kingdom
      at least re seat the ribbon cables before giving up on it
      • Brucetafer
        • Jun 2018
        • 133
        awesome, thanks.. ill give it a shot.
        • howardc64
          by howardc64
          07-24-2025, 05:17 PM
        • Stanley1843
          by Stanley1843
          06-29-2024, 11:54 AM
        • jeyoung12
          Samsung QN50Q60t lines on screen
          by jeyoung12
          Hi all
          I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
          My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
          This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
          It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
          So....i don't know what end of the C ribbon to work with...
          02-26-2024, 10:38 AM
        • pni
          LG 49uf695v vertical coloured lines
          by pni
          Hi guys…I need your help. My cousin ask me to fix her tv. The tv when I went to pick up showed 3 horizontal black line. So I know it was a bad panel issue but I could try to fix with the tape method so I said her I could fix easy. When I come back to home, I turned on the tv and now the tv show vertical line colored….and the problem is that I unplug the ldvs cable, first the right side then the left side I still have the lines. The lines never disappear. When the right side is plug in I don’t have nothing on the screen only this vertical lines, when the right side is unplugged I have picture...
          11-14-2025, 03:15 AM
        • Rubenlily
          Samsung QE50Q67TAU - horizontal lines
          by Rubenlily
          First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
          I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
          I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
          I'm no expert but I've done the tape...
          08-16-2023, 01:12 PM
