Philips 20PF4121/58 power inverter board problem
  • JohnNovak
    • Nov 2018
    • 72
    • Slovenia
    #61
    Re: Philips 20PF4121/58 power inverter board problem
    Today i check again all outputs, looks OK.
    • R_J
      • Jun 2012
      • 9624
      I found a hand drawn schematic for a DAC-12m018, maybe it will help, I suspect if the voltage is only slightly higher, the problem could be around the reference ic tl431 that controls the optocoupler. it's that circuit that does the regulation. I don't know how accurate this drawing is.
      • JohnNovak
        • Nov 2018
        • 72
        • Slovenia
        #63
        Thanks.
        I will check again resistors in that area.
        There was electric shock here which destroy TL431, maybe i did not check good before.
        I found some issue or maybe is not?
        When i use scart input and i power OFF TV and power ON again there is no backlight back. I must disconnect power cable to get backlight operation.
        When TV is on channel mode backlight works OK.
        • JohnNovak
          • Nov 2018
          • 72
          • Slovenia
          #64
          R_J.
          I check resistor all OK.
          I have no idea how to fix DC output to 14.5V.
          I think TL431 have nothing with 12V output.
          Can we check what is possible issue with buttons on TV?
          TV have basic buttons on the top.
          Power, vol -, vol +, MENU, P-, P+.
          Some buttons not respond correctly.
          This issue was present before and still make problem.
          • R_J
            • Jun 2012
            • 9624
            The output voltage is monitored on the secondary and controls the primary ic, the only way it can do this is via the optocoupler to maintain isolation between the primary and secondary
            There might be a zener diode that has changed value? It could be that they monitor the +10 volt line for the feedback and not the +12v
            The fault with the buttons is likely the tac switches, they can develope some resistance across the contacts and change how the functions operate.
            for example when CH- is pushed it shorts r3319 (1K1) to ground, if the menu button is pushed it shorts r3324 (2k0) to ground.
            Now it the CH- button sw develops 1k of resistance, it will act like the menu is being pushed.
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • Destroyer-Br
              [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
              by Destroyer-Br
              I'm working on an Acer Nitro 5 unit with the following specs:
              • Motherboard: LA-J871P Rev: 1B
              • Model: Acer AN515-55-59MT
              • S/N: NHQ7JAL00403906A973400
              • SNID: 03902728734
              Initial Issue
              The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
              After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
              04-17-2025, 08:18 PM
            • spantor
              Activate power board Philips 40PFH40009/88 tv
              by spantor
              Hello partners.
              Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
              The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
              02-11-2024, 05:07 PM
            • Dani_2024
              by Dani_2024
              10-28-2024, 05:06 PM
              After all of...
              07-13-2024, 08:14 PM
