Philips 20PF4121/58 power inverter board problem
  • JohnNovak
    • Nov 2018
    • 72
    • Slovenia
    #41
    Re: Philips 20PF4121/58 power inverter board problem
    As a professional tech do you have any idea for RMK25 transistor?
    • R_J
      • Jun 2012
      • 9623
      Is that rmk25 or rkm25 it could be a RK7002 or maybe 2n7002k
      To u-processor IC7011.
      There is 1.8V voltage to processor, and where is this voltage on power board?
      That microprocessor operates from 3.3v standby from the power supply
      The 1.8v comes from 7955 regulator ic, Its input voltage is.... +3V3STBY
      • JohnNovak
        • Nov 2018
        • 72
        • Slovenia
        #43
        The transistor mark is RKM25 and looks RK7002 will be good replacement.
        RKM25 has diode inside between D and S like RK7002B.
        I also agree with you that must be st.by voltage +3.3V.
        At the moment that is all i have.
        I must check if this transistor have any affect to power up or st.by voltage.
        • R_J
          • Jun 2012
          • 9623
          Are you saying that you DO have the 3.3 volts standby voltage???
          Output DC voltages are:
          +10V output = not stable = 2.8V to 3.4V goes up and down
          +3.3 output = 0.88V to 0.94V+12V output = 0.28V
          • JohnNovak
            • Nov 2018
            • 72
            • Slovenia
            #45
            No i say i agree with you that this voltage must be there.
            There is no.
            • R_J
              • Jun 2012
              • 9623
              Ok good I thought I missed something, Can you trace back the +12 volts? Is it the supply that connects to the small fuse that supplies the BL inverter section?
              It does seem that the +12volt line is loading down the rest of the power supply
              • JohnNovak
                • Nov 2018
                • 72
                • Slovenia
                #47
                I mark with red lines.
                • JohnNovak
                  • Nov 2018
                  • 72
                  • Slovenia
                  #48
                  I check all loads are high, no shorts or heavy loads.
                  +12V fuses are OK.
                  What can be wrong here?
                  • JohnNovak
                    • Nov 2018
                    • 72
                    • Slovenia
                    #49
                    Happy New Year to all.
                    • JohnNovak
                      • Nov 2018
                      • 72
                      • Slovenia
                      #50
                      R J.
                      I need your help, i think i found the problem.
                      I found faulty SMD transistor with SMD mark T3GU, position Q105.
                      Ther are 2 transistors on this board, measuring the second good transistor Q111 with analog ohm meter
                      shows PNP darlington type.
                      Now i search replacement for this transistor.
                      • R_J
                        • Jun 2012
                        • 9623
                        I can't be sure, might be a TL431BCDBZR
                        Found this site that mentions them also http://monitor.net.ru/forum/philips-...fo-231989.html
                        • JohnNovak
                          • Nov 2018
                          • 72
                          • Slovenia
                          #52
                          Hi.
                          I finally found the fault and now big problem to decode this part.
                          I check TL431 readings with ohm meter, not even close to good T3GU.
                          The silkscreen show Q for transistor, for voltage reference should be U or something.
                          And TL431 have 431 mark.
                          • R_J
                            • Jun 2012
                            • 9623
                            This pdf shows the T3GU marking for a sot23-3 on page 36
                            The other site I linked to also mentioned that part as being a Precision Programmable Reference
                            You might need to draw out the circuit for that area to see how it is used
                            Usually that area of the secondary near the optocoupler, can have a 3 pin reference, they may have been lazy and labeled it Q
                            Does one of the leads go to ground? which one? Also was the original one shorted?
                            Do the letters look like this picture?
                            • JohnNovak
                              • Nov 2018
                              • 72
                              • Slovenia
                              #54
                              It looks the same to me like on the picture.
                              I make some photo but very hard to make good quality picture.
                              I have 10ohm readings at Q105, pin 1 and pin3 in both direction so i desolder out this part,
                              looks is damaged.
                              Pin3 goes to gnd, yes. Looks we have voltage reference here.
                              Q105 have pin3 to gnd, Q111 have no grounded pin.
                              I put pin out on the picture, should be correct?
                              • JohnNovak
                                • Nov 2018
                                • 72
                                • Slovenia
                                #55
                                Let we take a look one detail about TL431, if you have any new outside of pcb board,
                                if you measure with analog ohm meter x1 from pin3 to pin1 do you have any resistance readings like normal diode and from pin1 to pin3 no resistance?
                                • JohnNovak
                                  • Nov 2018
                                  • 72
                                  • Slovenia
                                  #56
                                  R J, i have some good news.
                                  Today i replace Q105 with TL431 i got power up with DC outputs:
                                  +10V = 12.42V ???
                                  +3.3V = 3.51V is OK
                                  +12V = 15.36V should be 14.4V ??
                                  I'm a little worried about +12V and +10V high outputs.
                                  I will replace Q111 and Q105 with new TL431 and then will see what outputs will be.
                                  TV works normal.
                                  • R_J
                                    • Jun 2012
                                    • 9623
                                    Thats good , its almost there, Check the reference resistors, make sure they are not damage as in changed value
                                    • JohnNovak
                                      • Nov 2018
                                      • 72
                                      • Slovenia
                                      #58
                                      Hi again, R_J.
                                      I finally receive new TL431.
                                      I replace both Q111 and Q105.
                                      DC outputs exactly the same, so one was faulty, one was good.
                                      All resistors shows original value.
                                      Still worry about high +12V output which is 15.36V.
                                      This is more than 10% which is allowed by factory, 13.2V will be normal.
                                      TV works normal, is it safe to run with so high +12V output?
                                      • R_J
                                        • Jun 2012
                                        • 9623
                                        I checked the schematic for the tv and on page 29 it shows +12VSW coming from the power supply, but on ic7930 the VCC is shown as 14V4 so 15volts might be ok.
                                        Does the +12vsw turn off when the tv is turned off? if not the fet that is used to switch it might be bad.
                                        • JohnNovak
                                          • Nov 2018
                                          • 72
                                          • Slovenia
                                          #60
                                          Thanks for reply.
                                          I measure DC outputs when TV is turn off.
                                          +10V = 12.35V
                                          +3.3V = 3.57V
                                          +12V = 3.57V
                                          So the only voltage which goes down is +12V.
                                          Switch FET=Q112
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Destroyer-Br
                                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                            by Destroyer-Br
                                            I'm working on an Acer Nitro 5 unit with the following specs:
                                            • Motherboard: LA-J871P Rev: 1B
                                            • Model: Acer AN515-55-59MT
                                            • S/N: NHQ7JAL00403906A973400
                                            • SNID: 03902728734
                                            Initial Issue
                                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                            04-17-2025, 08:18 PM
                                          • spantor
                                            Activate power board Philips 40PFH40009/88 tv
                                            by spantor
                                            Hello partners.
                                            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                            02-11-2024, 05:07 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
