Philips 20PF4121/58 power inverter board problem
  • JohnNovak
    • Nov 2018
    • 72
    • Slovenia
    Re: Philips 20PF4121/58 power inverter board problem
    Originally posted by R_J
    Check the diodes in the secondary and see if any are shorted. If you disconnect the plug to the main board does the 3.3 volts stay constant?
    There is a small elec. cap. in the primary, you could try replacing it. (near u100 opto)
    Sorry i overlook this advice.
    I disconnect also main board (small signal board).
    There is option to manual power up the board to connect pin ST.BY to +3.3V
    and load outputs with 12 ohm resistors.
    This info is from service manual.
    There is no power up also.
    I also check main board with external power +3.3V and 12V.
    I got green led normally, looks the main board is working.
    • R_J
      • Jun 2012
      • 9608
      Is it posible to provide the voltages that you get on U101? maybe there is a clue somewhere.
      As a caution and to prevent sorting pins, measure the voltage on a component connected to the pin IE: for pin 8 measure on R122
      • JohnNovak
        • Nov 2018
        • 72
        • Slovenia
        Is it safe to disconnect the board from chassis and connect to 230V?
        I never do this.
        I do not understand where to measure?
        The voltage between hot gnd and pin8 i think.
        • R_J
          • Jun 2012
          • 9608
          Yes you can disconnect the board, and work on it off the chassis. you may not get the 12 volts but you should get a good 3.3 volts
          When checking voltages on the primary (or HOT) side, be carefull and always use the (-) of the main filter cap as ground.
          Also check the voltage on the fet drain, it should be close to 350 volts
          • JohnNovak
            • Nov 2018
            • 72
            • Slovenia
            Main filter cap voltage = 321V
            MOSFET drain voltage variable from 321V to 329V.
            IC pin8 voltage at R122 variable from 309V to 314V.
            • R_J
              • Jun 2012
              • 9608
              ok , thats a start, now the other voltages in U101
              • JohnNovak
                • Nov 2018
                • 72
                • Slovenia
                #27
                PIN1= 9.2V to 10.2V
                PIN2= 0V
                PIN3= 0V
                PIN4= 0.80V to 1.37V
                PIN5= 0V
                PIN6= 0.21V to 0.50V
                PIN7= 0V
                PIN8= 309V to 314V
                If i check basic schematic of IC TEA1532A then PIN7 have no output to
                MOSFET gate.
                • R_J
                  • Jun 2012
                  • 9608
                  Thats what it looks like but the only real way to tell would be with a scope to see if there is a pulse there.
                  What is the resistance measured on pin 7 to pin 2 or(hot ground)?
                  also measure the resistance between pin 7 and the fet gate
                  • JohnNovak
                    • Nov 2018
                    • 72
                    • Slovenia
                    #29
                    The resistance between PIN7 and HOT GND is infinite,
                    measured with digital ohm meter 20M ohm range, negative probe to gnd, positive probe to PIN7.
                    The resistance between PIN7 and MOSFET gate is 15ohm, resistor R143=15R0 is OK.
                    The only resistance i found which is not clear is R145=12C, from EIA smd marking table should be 13k ohm.
                    If i measure this resistor show 2k ohm.
                    • R_J
                      • Jun 2012
                      • 9608
                      I keep going back to these voltages
                      Output DC voltages are:
                      +10V output = not stable = 2.8V to 3.4V goes up and down
                      +3.3 output = 0.88V to 0.94V
                      +12V output = 0.28V
                      This tells me that the circuit is trying to work,
                      the 10v is 3v about 1/3
                      the 3.3v is 1v about 1/3
                      the voltage on CE108 is likely being being charged to about 1/3 which would be around 7-9v but the startup circuit is already charging it to 9v so it is being masked.
                      the 12v is 0.3 about zero, this I would think should be about 4v... something must be killing it
                      • JohnNovak
                        • Nov 2018
                        • 72
                        • Slovenia
                        #31
                        R J do you have the same power board or you have schematic diagram for this pcb?
                        • R_J
                          • Jun 2012
                          • 9608
                          No I do not have either, I am using your pictures. I have repaired a lot of smps over the years
                          • JohnNovak
                            • Nov 2018
                            • 72
                            • Slovenia
                            #33
                            I found suspect part which is connected to st.by
                            line and which turn on 12V power.
                            The mark is RKM25 can not found any info.
                            What can replace this transistor?
                            Position Q100 on the picture.
                            • JohnNovak
                              • Nov 2018
                              • 72
                              • Slovenia
                              #34
                              This LCD have 3 power options.
                              NO LED is power off with power button on TV.
                              RED LED is on st.by position when you use remote to power off.
                              GREEN LED is power on TV.
                              So maybe if this voltage is missing (Q100 faulty) the power board stay in power off position.
                              • R_J
                                • Jun 2012
                                • 9608
                                power off (no led) means the tv is unpluged. You need standby or nothing works.
                                • JohnNovak
                                  • Nov 2018
                                  • 72
                                  • Slovenia
                                  #36
                                  No there is this option here.
                                  I also never see power off TV with no led.
                                  This model have this position when you press
                                  power button on TV for about 3 seconds the LED is switched off.
                                  When electric shock was occur this TV was off but 230V line
                                  cable was connected.
                                  • R_J
                                    • Jun 2012
                                    • 9608
                                    Is that switch connected to the a/c mains in? does that switch have 3 positions?
                                    How do you expect the microprocessor to work and know that the power button is pressed if there is no voltage to operate it????
                                    • JohnNovak
                                      • Nov 2018
                                      • 72
                                      • Slovenia
                                      #38
                                      There is no any on/off switch on this TV.
                                      The voltages are still present here.
                                      I did not design this TV.
                                      I have also Samsung pc monitor with no any 230V switch
                                      and to turn off i press power button for 2 seconds and led is off.
                                      • R_J
                                        • Jun 2012
                                        • 9608
                                        What do you think that power button is connected to?
                                        On a computer monitor the power button turns the monitor for off to on and the led will come on (pick a color) IF the video signal is removed, or the computer turned off, the monitor will go into standby (usually indicated by flashing led or yellow led)
                                        This has nothing to do with the STANDBY voltage that is needed for the micro on the main board to work, when the power button is pressed the micro sends a signal to turn on the main part of the power supply.
                                        • JohnNovak
                                          • Nov 2018
                                          • 72
                                          • Slovenia
                                          #40
                                          To u-processor IC7011.
                                          There is 1.8V voltage to processor, and where is this voltage on power board?
                                          • Tynan Dill
                                            by Tynan Dill
                                            Assuming...
                                            11-22-2024, 01:46 PM
                                          • Destroyer-Br
                                            [HELP] Acer AN515-55 (LA-J871P Rev: 1B) – Board won't power on after GPU investigation – Suspecting Super I/O or PCH
                                            by Destroyer-Br
                                            I'm working on an Acer Nitro 5 unit with the following specs:
                                            • Motherboard: LA-J871P Rev: 1B
                                            • Model: Acer AN515-55-59MT
                                            • S/N: NHQ7JAL00403906A973400
                                            • SNID: 03902728734
                                            Initial Issue
                                            The laptop initially presented graphic issues and driver failure (Code 43) for the GPU.
                                            After preventive maintenance (cleaning, thermal paste, etc.), it powered on normally. We disassembled it again to inspect the GPU, reassembled...
                                            04-17-2025, 08:18 PM
                                          • spantor
                                            Activate power board Philips 40PFH40009/88 tv
                                            by spantor
                                            Hello partners.
                                            Could someone tell me how to make this Philips TV source work without the mainboard being connected? The model of the board is EAX65423701 (2.1) and the model of the Philips TV is 40PFH40009/88.
                                            The TV is dead, there is no standby light, however there is a voltage of 12v on the pins ( included 12v VAU ) and 3.2v on the PS-ON pin (see photo) when the power board is connected to the main board. If I disconnect both boards I only get 8 volts on 12v pins. I would like to rule out a fault in the main board by making it work, but so far no one has been able to tell...
                                            02-11-2024, 05:07 PM
                                          • Dani_2024
                                            by Dani_2024
                                            10-28-2024, 05:06 PM
                                            After all of...
                                            07-13-2024, 08:14 PM
