Toshiba 40L3433DG - very hot Q301 on PSU board
  • Sebenicz
    • Nov 2018
    • 11
    • Poland
    Sorry for my english.
    Toshiba 40L3433DG, Vestel 17IPS20R6.
    TV not working, only led blinking. I find shorted Q301 on psu. I change it to similar. I don't find any other damage. Now works fine, picture are very good, but Q301 is extremely very hot.
    Where look for other damage?
  • TechGeek
    Computer Geek
    • Jan 2015
    • 2254
    Re: Toshiba 40L3433DG - very hot Q301 on PSU board
    Can you check the temperature it's running at? If so, post it here. Also, can you post the manufacturer/part number of the replacement Q301 item?
    Permanently Retired Systems:
    Kooky and Kool Systems
    sigpic
    • Sebenicz
      • Nov 2018
      • 11
      • Poland
      I don't know what exactly temperature is, but I can't touch this. Original was FQP7N80C and now is STP20NM60.
      Also I add pictures before repair.
      • TechGeek
        Computer Geek
        • Jan 2015
        • 2254
        Try to get something like a temperature measuring 'gun' or a thermocouple or something like that. The replacement device is rated for a max of 150C operating temperature.
        Also, do you have another FQP7N80C you could try?
        sigpic
        • Sebenicz
          • Nov 2018
          • 11
          • Poland
          Q301 is very hot because other damage is.
          • Sebenicz
            • Nov 2018
            • 11
            • Poland
            Voltage on C105 is 390V.
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              That's good. That means that the voltage booster circuit is working. If this circuit wasn't working, then the TV wouldn't work.
              sigpic
              • Sebenicz
                • Nov 2018
                • 11
                • Poland
                But why Q301 is very hot?
                • TechGeek
                  Computer Geek
                  • Jan 2015
                  • 2254
                  Well, I can think of a couple reasons:
                  1) The replacement part is different, and thus will run hotter
                  2) The original part operated hot in the first place
                  I think it's more of reason 2, because it has a heatsink on it to help dissipate heat. Could you try adding a fan to blow some air onto that heatsink?
                  sigpic
                  • Sebenicz
                    • Nov 2018
                    • 11
                    • Poland
                    1) no.
                    2) the original part is damage because is damage in other place.
                    • ducky29
                      • Dec 2015
                      • 369
                      • Europe
                      1) no.
                      Check the pm that I sent you!
                      • gabiz_ro
                        • Mar 2011
                        • 171
                        • Romania
                        A big heatsink will help.
                        You may see there is enough room for bigger one.
                        Encountered few times same problem,MOSFET short on G-S,replaced with original but very hot in short time.
                        So I remove old heatsink and replace with one that fit in that area.
                        After few hours of working heatsink was at ~45-50 °C
                        On PCB there is footprint for bigger heatsink but they use a little very small one.
                          Check the gate resistor and gate pulldown resistor are not damaged. If the MOSFET failed these can be damaged causing poor performance of the new MOSFET.
                          • Sebenicz
                            • Nov 2018
                            • 11
                            • Poland
                            Gate resistors are good.
                            • Sebenicz
                              • Nov 2018
                              • 11
                              • Poland
                              Vcc on U300 (NCP1380D) is 18,3V.
                              Vgs is max 3,5V.
                              Voltage drop on R320 (0,47R) is max 0,08V.
                              Any ideas? :/
                              • R_J
                                • 9633
                                Does this power supply use D512 and D513? They might be shorted, you would need to remove R320 to check them.
                                I see the schematic is marked wrong for the value of R320 (56K) not likely
                                • Sebenicz
                                  • Nov 2018
                                  • 11
                                  • Poland
                                  D512 and D513 is not use in this psu.
                                  • Andrew F. Ali
                                    • Jan 2014
                                    • 2450
                                    • Trinidad & Tobago
                                    Look for even the smallest leak on any associated semiconductors in the Transistor circuitry.Even the replacement could be leaky, though rare it could happen. Let replacing the original heatsink with a bigger one.
                                    • R_J
                                      • 9633
                                      It could be that the replacement fet is the problem, your replacement has a Rds(on) of 0.29Ω the original was Rds(on) of 1.9Ω which might change the circuit operation enough to run hot.
                                      • m1ch43lzm
                                        by m1ch43lzm
                                        05-12-2025, 08:37 PM
                                      • rounin
                                        MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
                                        by rounin
                                        Device Information
                                        • Model: MacBook Pro 14” M1 Pro (A2442)
                                        • Logic board number: 820-02443-05
                                        Original Issue
                                        The device suffered liquid damage, causing a short circuit on the logic board.
                                        Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
                                        Work Performed
                                        Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
                                        Current Status
                                        • When powered on, the screen shows support.apple.com/mac/restore....
                                        10-20-2025, 11:15 PM
                                      • howardc64
                                        by howardc64
                                        07-24-2025, 05:17 PM
                                        09-06-2024, 05:27 AM
