Samsung TV Flickering on start up
  • Newnies
    • Oct 2018
    • 4
    Hi all. I am 'the new guy' to this site. I stumble across this site awhile back while looking for some information on an Samsung TV. Really enjoyed reading everyone's input; which helped me repair that TV.
    Now, I have a Samsung TV model- LN32D403E4DXZA version SP01 that had a bad power board among other issues. Power board's circuit from the main cap to the back light inverter blew and the board was damaged beyond repair. I got a replacement board (BN44-00438a) that failed while still testing the TV. I used the attached schematics (2 different schematic for this board. The board is a mix of both of them) to determine that the transistor located at QM854 was bad. After replacing it, the power board worked again.
    Now, when the TV starts up, the back light flashes for about 20 seconds then stays on steady. The center 'weak or no signal' (I have no input attached) is somewhat bright, but dims in stages over the next 30 seconds. I reset the TV and updated the software, but this flickering and dimming still occurs. I don't have the ECO setting on. I am guessing it is the main board, but the high FET reading on my power board is lower than I think it should be.
    I have searched your forums for information on this TV but came up short. I would love anyone's input on what the problem could be. If you know which component on the board might be an issue, please tell me that too.
    Thanks in advanced for all your help!
    We all love readings so here is what I have:
    Power Board: (BN44-00438A)
    Main Cap- 384.5-385.5V back light flickering / 387v when back light steady
    CN1801 pinout: Back light flickering Back light steady
    Pin 1 - High Fet - 187.8-191V 185V
    Pin 3 - Low Fet 187-192V 185V
    Pin 9 - OVP .10-.06V .004V
    Pin 10 - CNT-PRT 12.4V 12.4V
    Pin 11 - VCC 12.6V 12.6V
    Pin 12 - LD 11.3V 11.3V
    U1801 (Sem2106) chip
    Pin 14- VCC - 12.2V
    Pin 13 - N2 - .515V
    Pin 12 - N1 - .681V
    CN802 pinout
    Pin 1,3,5,7 - B13V - 12.61V
    Pin 11,13 -B5V - 5.23V
    Pin 2 - P_Dim - .8V
    Pin 4 -NC
    Pin 6 - BLU_ON - 104-107mV
    Pin 12 - A5V - 5.22V
    Pin 14 - PS_ON - 3.5V
    Pin 8,9,10 GND
    Inverter Board (SST320-4UA01) (LJ97-03461A) Attached pic Shop Jimmy
    Transformer:
    Primary - 1.6 ohms
    Secondary - .94 Kohms
    IC U001 (BA10358 Dual GND Sense Op Amp) Pinout
    Pin 1 - Out -1.2mV
    Pin 2 - -In1 - 6.75V
    Pin 3 - +In1 -.95V
    Pin 4 - VEE - 0
    Pin 5 +In2 - 6.28V
    Pin 6 - -In2 - 1.5mV
    Pin 7 - Out2 - 11.28V
    Pin 8 - Vcc - 12.55V
    • 12328
    • U.S.
    Re: Samsung TV Flickering on start up
    Pin 6 - BLU_ON - 104-107mV Don't look good too low.
    • Newnies
      • Oct 2018
      • 4
      Would you happen to know what the voltage of Pin 6 should be?
        • 12328
        • U.S.
        You're checking with tv plugged in power button off which is standby, then you hit power button and get that reading too, they can vary but usually you need 2.5+volts which comes from the mainboard, which turns backlights on, at 107 mv seems too low to turn m on.
          • 12328
          • U.S.
          https://www.shopjimmy.com/samsung-bn...upply-unit.htm picture of powersupply
            • 12328
            • U.S.
            I would unplug powersupply from mainboard and do the jump with resistor to see if that voltage comes up, on this one I think you need to jump ps on with 5 volt standby and blu-on, better double check with one of the pros tho, to be sure.
            • Newnies
              • Oct 2018
              • 4
              Thank you for all the information. I re checked Pin 6 (Blu_on) and got 5.1V. My mistake.
              On CN 1801, Pin 1 (High Fet) should it be higher than 185V?
                • 12328
                • U.S.
                I think it says high 280 on your board map/legend, seems low?
                • ohren
                  by ohren
                  09-08-2023, 05:24 PM
                  09-07-2024, 05:50 AM
                • Nicktronic
                  Samsung Power Supply Board BN44-00874F
                  by Nicktronic
                  Hey everyone,
                  This power supply board is hard to find but there are repair kits available. This board had a blown fuse, FP801S, blown PFC MOSFET, QP802CS and ceramic cap, CP809. I replaced them with parts I already had and tested the rest of the parts that would've come in the repair kit and they were fine. I powered the board up on the bench expecting, in typical Samsung power supply board fashion, to see all my output voltages but, nothing. 0 volts on CNL801, CNM801 and CNT801. The only thing I have is 170vdc on the filter caps. No standby voltage either.
                  Anybody...
                  03-17-2025, 06:20 AM
                • Asraf Atb
                  by Asraf Atb
                  01-27-2025, 05:02 PM
                • valvashon
                  Samsung UN65KU6290F PS board blows fuses
                  by valvashon
                  Samsung UN65KU6290F (May 2017); received from local Buy Nothing group. Was listed as "just went dead" and they wanted it gone. I brought it home, didn't notice anything visually wrong with the power supply board, looked up the cost of a new one and that's about as far as it went. Family was tired of tripping on the foot of the set so I decided to dig in and repair or toss.
                  Can't believe that I didn't check it earlier but I found the main 8 amp fuse blown. Jumped across it with a 10 amp blade style fuse and you can see that it literally exploded inside the second I plugged...
                  11-27-2023, 01:09 PM
