Dead digihome tv
  • Jay morris
    • Nov 2018
    • 19
    • England
    Dead digihome tv
    Hi all. I have a problem with a digihome TV and wantvto fix it model:49278fhddled. Under the panel there is also another model number VES49undl-2D-N02. My problem is the set seems dead with no picture,sound or standby light.
    The power supply board has been replaced vestel 17ips71 but still same issues as above.
    The power cord cable and fuse are ok and there is power getting to the board.
    Im just learning electronics so be easy on me lol
    If the power board is ok could the main av board be at fault pn 17mb82s 23289383 and cause the no power symptom?
    Thanks jay
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Dead digihome tv
    sounds like could be a firmware issue if you do get a replacement mainboard make sure it matches the lcd panel used in your tv. Have a search on this forum and youtube look for 17mb2s core update.
    • Jay morris
      • Nov 2018
      • 19
      • England
      Thanks for the reply. So if I were to replace the av board with exact board will i still need to update firmware?
      • vinceroger69
        • Mar 2012
        • 6714
        No it should be fine have a look on ebay etc post the links and we could confirm if it looks the correct board, have you tested your new power supply we have seen instances replacement boards are faulty too.
        • Jay morris
          • Nov 2018
          • 19
          • England
          If the firmware is the issue is there anyway to sort the issue with a dead tv?
          • Jay morris
            • Nov 2018
            • 19
            • England
            Ok I have found this board on eBay dies this look ok?
            https://rover.ebay.com/rover/0/0/0?m...2F264011643487
            • Jay morris
              • Nov 2018
              • 19
              • England
              I have only gone as far as inspecting the board for bad caps, loose components or damage. The board is receiving power as I can hear a dim buzz from the transformer.
              As far as testing goes what should I be looking out for?
              • vinceroger69
                • Mar 2012
                • 6714
                have you got a multi meter if so we can find the schematics and get you to check some voltages
                • vinceroger69
                  • Mar 2012
                  • 6714
                  yes thats also a really good price too, just make sure they accept returns if faulty on arrival
                  • Jay morris
                    • Nov 2018
                    • 19
                    • England
                    Yes I have a multimeter. What should I test?
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      tv plugged in and turned on multi meter set on dc volts black probe on metal tv chassis can you check the voltages on all these pins thanks and please be careful as dealing with mains voltage on the hot side of the psu (you are only testing low voltages though doing these tests)
                      • Jay morris
                        • Nov 2018
                        • 19
                        • England
                        Ok I will check tomorrow and get back to u
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          Thanks, my guess the psu will be ok and it is a mainboard at fault.
                          • Jay morris
                            • Nov 2018
                            • 19
                            • England
                            Ok The confusing part is matching the diagram up ro the connector and the board has no marks to say which pin is which. I can only assume that cn3 diagram matches the 20 pin holes on the board cn3. Am I right reading this diagram refers to looking at the back of the board? Pin 20 top left pin and bottom left pin 2.
                            • Jay morris
                              • Nov 2018
                              • 19
                              • England
                              Ok I've tested the pins with the board off the tv with no av board connected and mains powered.
                              These are the pins with voltage
                              Pin 7 2 or 3 v
                              Pin11 11or 12v
                              Pin 12 11 or 12v
                              Pin 13 11 or 12v
                              Pin 14 11 or 12v
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                usually looking from top of board what i do is too put the red probe tip down the side of each of wire im testing the voltage on going into the connector block, the probe will touch a metal connector on the end of the wire and allow a reading to be taken, Their are also few revisions of the schematics for that psu board number, can you upload a picture of your psu used in your tv thanks.
                                • Jay morris
                                  • Nov 2018
                                  • 19
                                  • England
                                  Thanks for reply. I've also included the cn3 connector pins aswell in the pic.
                                  • Jay morris
                                    • Nov 2018
                                    • 19
                                    • England
                                    Pic of The board
                                    • Jay morris
                                      • Nov 2018
                                      • 19
                                      • England
                                      More pics
                                      • vinceroger69
                                        • Mar 2012
                                        • 6714
                                        side mounted connectors are always a pain too test, maybe easier too test voltages on mainboard end? the bottom center white connector where does that go too? can you post a picture of the back of the tv with all the boards connected together
                                        • k370
                                          Yoga3 Pro-1370 Board NM-A321 DEAD no power at all
                                          by k370
                                          I have a NM-A321 board that is dead, with no power at all.
                                          When I received the laptop, the +5VPMIC line was shorted. Removing the PU3 (ISL95905) solved the short, so I ordered and replaced the ISL.
                                          With the new ISL, the short is gone, but still no voltages at all. I measured the following rails:
                                          • +3VALW
                                          • +5VAUX
                                          • 1.2VSUS_PWRGD
                                          • 3VALW_PGD
                                          • 1.05VAUX_PWRGD
                                          Additionally, the ISL95906 (PU3) is not getting any voltage on the VIN rail.
                                          The only place on the board where I find any voltage is on the first MOSFETs, specifically:...
                                          09-23-2024, 11:57 AM
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • corrize
                                          Nikon D5 – dead, power board issue ?
                                          by corrize
                                          Hello, the DSLR has heavyly fallen. It is dead : no sign of life and display nothing.
                                          When it worked, it always displayed a card present state on LCD display, even when the battery is empty it display a empty battery symbol.
                                          I found a dead fuse, I replaced it and a mosfet burnt, I changed it and another fuse burned. Nothing burned after. And I can't find any short circuit anywhere, it's weird.
                                          Now, I try to understand how it works.
                                          There is two boards (the little one on pictures has no component) : the first is a « power board » : managing...
                                          04-03-2023, 09:13 AM
                                        • Asraf Atb
                                          by Asraf Atb
                                          01-27-2025, 05:02 PM
