What type of fuse is this?
  • petehall347
    • Jan 2015
    • 4427
    • United Kingdom
    Re: What type of fuse is this?
    build yourself a DBT .
    saves on fuses .
      Check the RESISTANCE reading between the two legs (+ and - legs) of any one of the three main filter caps (3 large caps laying on its side), report the reading.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        saves on fuses .
        I don't know what that is.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          That wouldn’t cause blown fuses would it?
          • petehall347
            • Jan 2015
            • 4427
            • United Kingdom
            shorted main caps would blow the fuse
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              #26
              this is basically it .
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                #27
                Getting ~46k ohms on the filter caps.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #28
                  I’ve seen the light bulb setup on here before. Never bothere with it because I don’t bother with fixing TVs anymore.
                  People around here list 32” cracked led/lcds for $20 or more claiming it’s a cheap fix.
                  I will pick up the occasional plasma, since they are discontinued. In the last year, I’ve picked up 3 plasmas counting this one.
                  2 Panasonic’s with the usual sc board issue, which I’ve finally gotten enough guts to fix myself.
                  This is the only non panny I picked up only because the Samsung 8500 series is supposed to be nice.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #29
                    Now the reading on the filter caps has changed. ~11M ohms.
                    • petehall347
                      • Jan 2015
                      • 4427
                      • United Kingdom
                      #30
                      did you test all diodes for short ?
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #31
                        Yes, none of them are shorted unless there are some under the cage by the power inlet. I can’t really see what’s in there.
                        It’s almost 2am for you Pete. Don’t you sleep?
                          I am looking for shorted load which will be connected in parallel with the filter caps.
                          So now you need to test the resistance between the two inner legs of the Bridge rectifier.
                          I need to get good clear high res straight shot pictures of the whole top and bottom side of that power supply board, right now I cannot read the P/N of that power supply board.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            Sorry bud, just got this. I’ll get better pictures tomorrow. The board number is bn44-00619a.
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #34
                              This is the best picture I can get with my phone.
                              Which is the bridge rectifier?
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #35
                                The parts in the 15 piece repair kit are: DS808, DS810, QS802C, QS804C, RS819, RS833, RS827, RS835, DS813, DS807, DS809, DS814, FS801S, RS854 and RS855.
                                  dont waste money on special fuses . get some 12 amp fuse wire but watch for fire it is sure to blow again . or solder to a regular time delay fuse
                                  Really do not do this.
                                  The fuse has a case to absorb the arc and prevent a fire.
                                  Use a real fuse and don't burn down the house if it blows unnoticed.
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    #37
                                    I thought you were leaving badcaps Tom?
                                    Anyway, I wouldn’t do that.
                                    Some of those components I listed are too small for me to replace even with my magnifiers on.
                                      Anyway, I wouldn't do that.
                                      I'm not leaving Badcaps, I'm just not active on here that often due to job and other commitments.
                                      • jetadm123
                                        • 2169
                                        #39
                                        That kit only applies if QS802C and QS804C are shorted.
                                        Possibly something under that metal cage at the AC inlet is shorted. Maybe a varistor?
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #40
                                          I guess I can remove it and check.
                                            Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                            This specification for the Acer TravelMate X514-51T-50DY+ USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51T-50DY+ USB Type-C Dock boardview and X514-51T-50DY+ USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-06-2024, 09:10 PM
                                            Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                            This specification for the Acer TravelMate X514-51-54PC+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-54PC+USB Type-C Dock boardview and X514-51-54PC+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook X5 Specification for Upgrade or Repair
                                            This specification for the Acer TravelMate X514-51-59AD+USB Type-C Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X514-51-59AD+USB Type-C Dock boardview and X514-51-59AD+USB Type-C Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                          • electronx
                                            Questions About USB 3.2 Gen 2x2 and USB4 Designs: Type-A vs Type-C, MUX Requirem
                                            by electronx
                                            I’m currently learning about the USB protocol and designing a project, but I’ve encountered a few questions that I couldn’t find clear answers to. I’d really appreciate your input!
                                            1. USB 3.2 Gen 2×2 with SuperSpeed Type-A Connector
                                            According to the USB 3.2 specification, it states that USB 3.2 Gen 2×2 can support a SuperSpeed Type-A connector. This raises a question:
                                            If we use a SuperSpeed Type-A connector, the system would only utilize 1 lane for data transfer, leaving 1 lane from the host unused. Is this configuration valid,...
                                            06-26-2025, 03:27 AM
