Samsung UE43J5500AK picture issue
  • fuus
    • 123
    • England
    Evening all,
    I've had this Samsung TV thrust upon me and I wonder if you guys could point me in the right direction.
    Here's a photo of the issue. Is it likely to be a TCON issue? Here in the UK I can likely pick a new one up for £20 so I'd be tempted to do that rather than attempt a repair. I'll be disassembling it tomorrow to check the TCON part number if it's needed.
    Any help / comment / pointers appreciated. I'm always keen to learn.
    Cheers, Fuus
  • bman4
    • Jul 2015
    • 210
    • canada
    Re: Samsung UE43J5500AK picture issue
    Tcon , dirty connections , liquid damage, compnent failure on driver boards, mainboard . could get expensive and lengthy .
    I rember seeing a tv like this and it was bad components on driver boards. He still repaied the tv !
    • fuus
      • 123
      • England
      Not exactly the news I wanted but there we are!
      So just to confirm almost certainly not a damaged panel? As if that's dead I might as well give up now
      • fuus
        • 123
        • England
        So I've been doing some more fiddling this morning to try and narrow down the issue. My electrical skills aren't the best, but I've been approaching it from more of a logical stand point...
        1) When the TV starts up the picture issues aren't present immediately:
        but by about 5 seconds later the defect has appeared
        2) There is one line of pixels on the screen that seems to be receiving the wrong data? See how you can see part of the N in No twice? Could this relate to panel tab issues?
        3) When I unplug half the screen from the TCON it looks like this. It appears the colour on the unplugged half isn't uniform. Could this mean it's a panel tab issue? Hopefully not, but if so I'd appreciate some links to guides / similar threads
        4) If my TCON does need to be replaced, which serial number do I need to match?
        Any pointers or guidance gratefully recieved
        Cheers, Fuus
        • Charleyd
          • Aug 2016
          • 42
          I believe that since part of the picture (the top) is correct, the Main Board and T-Con are good. I expect that the problem is with the panel, but repairable for FREE, so do not despair! The first step is to run the TV with one of the flat ribbon cables that go between the T-Con and the bottom panel edge boards disconnected. First try with the left one disconnected, and then with the right one disconnected. The results of this will lead you to the next step. Be very careful and post resulting pictures of the screen.
          • Charleyd
            • Aug 2016
            • 42
            I must have been composing my post at the same time as you. Need to try with the other side disconnected.
            • fuus
              • 123
              • England
              Cheers Charleyd, will swap the cables over now!
              • fuus
                • 123
                • England
                Unplugged cables swapped. Basically a mirror image
                Note the smart hub menu thing was just minimising itself, that's the reason it's half of screen
                • Charleyd
                  • Aug 2016
                  • 42
                  I cannot say that see a clear indication of a problem with the side tabs. I looked on eBay for T-Cons, and I do see a T-Con that I believe is a match in the UK for cheap.
                  • fuus
                    • 123
                    • England
                    So you think the next step is to replace the TCON to rule it out?
                    This one perhaps? Which model number is it I need to match?
                    Thank you
                    https://www.ebay.co.uk/itm/T-CON-LVD...frcectupt=true
                    • Charleyd
                      • Aug 2016
                      • 42
                      I'm no expert, but that would be my next step, and not too costly to try. The T-Con was bman4's first suggestion. The link you have looks good to me.
                      • fuus
                        • 123
                        • England
                        Ok, if there's no disagreement before tomorrow I'll get one ordered and see how I get on. Cheers Charleyd and bman4!
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4456
                          • Italy - Milan
                          NO! Don't buy... it's surely bad panel. First your "half tcon disconneted" test it's useless unless you decide to put a video input on the tv (lol, it's so difficult?)
                          From the tcon image i see that your is a panel almost surely without side tabs, i'm fighting with at least the same situation, different tv brand, same panel brand, the side tab strip down it's not possible, you can diminishing much the defect down to an at least not so bad visible tv, but for the ones that needs the perfection, i haven't found the answer already at now..
                          • fuus
                            • 123
                            • England
                            Hi Davi,
                            What is the method for diminishing the defect?
                            I will take some pictures with a video input tomorrow, sorry for my mistake.
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4456
                              • Italy - Milan
                              Since from your tests i suspect wrong gate drivers on both sides, i need the better test to evaluate.. if confirmed both you can't do anything to save it. At maximum you can sell the boards..
                              • bman4
                                • Jul 2015
                                • 210
                                • canada
                                Actually this looks like my.samsung and it was a side driver tab. it would shut the pic off eventually . i hope.you have side drivers they might be built in the bottom.ones . feel.the frame for excessive heat,this will tell whaT driver is shot and what side to.cut. you can possibly.use a thermal camera or temp.gun to.find the heat. Idk if they all sort hot tho
                                • fuus
                                  • 123
                                  • England
                                  The model is a 5 series. I suspect other 5 series models will have very similar characteristics to reduce development costs on the smart features and the like
                                  • fuus
                                    • 123
                                    • England
                                    Good afternoon all! (or morning for those the other side of the pond!)
                                    Please find attached pictures of half the TCON detached with video playing. As you can see the issue still prevails.
                                    Any further advice appreciated.
                                    Cheers
                                      • 12272
                                      • U.S.
                                      Only way I know to confirm a bad tab bond is strip it down and apply a little pressure to tab bonds, see if it clears up if it does a shim might work.
                                        • 12272
                                        • U.S.
                                        Demonstration with a sony. https://www.youtube.com/watch?v=vCExlSnG4yY
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • Kjell
                                          Samsung Series 9 - BIOS issue
                                          by Kjell
                                          After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
                                          Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
                                          08-01-2025, 09:15 AM
                                          09-07-2024, 05:50 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • x_orange90_x
                                          TCL 50S535 bad tcon or panel issue?
                                          by x_orange90_x
                                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                                          03-29-2025, 11:02 PM
