BN41-01795A short, no led no start
  • disorder
    • Sep 2015
    • 156
    • france
    hello,
    i need some help from the team
    i have a samsung tv led with bn41-01795A motherboard
    the tv not start, no red light, no reaction on start up button
    i have tested the voltage on SMPS : all 13v; 5v 3.3v and so...
    on th emotherboard some mesures seems ok : 3.3v 5v 1.6v
    but i have strictly nothing at the IR/On board : neither 3.3v, key 1 or 2 or LED
    IC202 and ic1201 are hot.
    i find two caps that are shorted : c205 near ic201 and c1215 near ic1201
    i test with isoprpylic acid and power supply but nothing very sure about this two guys.
    have you already have same issues here ?
    i will try to remove them but not sure it will work.
    thank you
  • disorder
    • Sep 2015
    • 156
    • france
    Re: BN41-01795A short, no led no start
    this was not that, i have remove this two caps, ic201 ic1362 and it is the same
    i have short on pin8 of ic1362 too
      You will get a lot more help if you provide good clear pictures of the boards and the P/N as printed on the IC so you can look up the spec sheet to find out what the IC's are.
      • disorder
        • Sep 2015
        • 156
        • france
        hello,
        i have found the guilty guy : it is wt61p805 weltrend chip.
        inside short of 3.3v main power
        damned
        i found this item on ebay or aliexpress but i think it needs to be flashed, no ?
        someone know where i can buy one ?
        thank you
        • geokyri
          electronist
          • Nov 2012
          "disorder", how did you solve the tv set ... ?
          • DynaxSC
            Extreme High Current & Low Voltage Short Killer ??
            by DynaxSC
            Hi Folks
            I'm looking for a extreme high current short killer solution for a reasonable cost.
            I have an LGA1700 motherboard (ASUS PRIME Z790-P WiFi) where I exchanged the LGA socket already 3 times, and every time after the socket exchange I get a short of power supply lines VCORE (V variable) and VCCIN_AUX (1.8V).
            After taking off the socket, the shorts dissappear again.
            The soldermask on the socket is already partially demaged from the heat, so I have reconstructed the soldermask by manually painting the missing soldermask parts with a very small top of a...
            10-15-2024, 10:13 AM
          • Stephen
            MacBook Pro 14" A2442 Short on PPBUS_AON but no short present when injecting voltage!
            by Stephen
            I check PPBUS_AON and there is a short present on the line, the computer shows a short when testing for short to ground, so when I inject voltage into the line, I get 0AMPS so no short is showing up. I have replaced a blown cap on this board that exploded and tested for the short and it is now removed. Any suggestions? I tested voltage at the line when the fuses are connected and I am getting 1.2 Volts at the line.
            02-06-2025, 12:03 PM
          • adelfr2009
            HP Victus 15-fb dag3pamb8d0 Short on VCORE – How to Confirm CPU Fault?
            by adelfr2009
            I have a laptop HP Victus 15-fb with motherboard DAG3PRMB8D0, CPU Ryzen 7535HS, and GPU RTX 2050. The laptop has a power issue: it does not turn on at all, and there is no light on the DC jack.
            After inspection, I found that an NMOS near the charger input had a short. I replaced it, but the short remained on the 19V line. I checked the charging circuit and it was fine, but the short appears after the current sense resistor near the charger. The charger does not pass current when connected, so I inject 3V–4V after the sense resistor. No component gets hot, except the CPU which becomes...
            09-28-2025, 10:21 PM
          • Victor Moreira Silva
            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
            by Victor Moreira Silva
            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
            Well, my decice specs are the following:
            Model: Acer Nitro 5 AN517-54-55T5
            CPU: Intel Core i5-11400H
            GPU: NVIDIA GeForce GTX 1650
            Motherboard: GH51G LA-L181P Rev:1c
            The symptom:
            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
            05-26-2025, 10:49 AM
          • aaronkatrini
            Help me find the short circuit on this WORKING Nvidia GTX1650
            by aaronkatrini
            Recently picked up this GTX1650 at a local flea market for a low price and wanted to use it on my secondary PC. I first tested the card and saw the fan spin for a split second and then nothing. Immediately I thought of a short circuit. Disassembled and found a shorted SMD capacitor, injected voltage into it (1V/4A) and two Mosfets got hot immediately (QN3103 & QN3107). Desoldered these Mosfets and the card turned back to life.
            Bought replacements from Aliexpress and replaced them afterwards. Tried the card but still the saw the fan spin for a split second...
            04-18-2024, 03:15 PM
