Polaroid p50up2038a menu lock
  • comptek
    • Aug 2013
    • 606
    Hi guys, a bit of a weird one here, vestal 17mb130s in this Polaroid 50”smart tv,
    Shop I do work for said it has a lock code on the menu so I can't even do the “4725” combo... meaning tv is on you press menu and pin code comes up
    Any ideas guys....
    Thank you
    Gary
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Polaroid p50up2038a menu lock
    ignore wrong thread
    • comptek
      • Aug 2013
      • 606
      Any ideas at all or does no one know ?
      • ducky29
        • Dec 2015
        • 370
        • Europe
        Did you try 4725 when pin comes up?
        • vinceroger69
          • Mar 2012
          • 6714
          on some polaroids i have read that you can set up a pin too protect anyone messing with the menu settings i guess this is what your seeing? im not sure if reloading the firmware would solve this? maybe try and get a user manual for the tv and see if there is a default factory pin too bypass the menu code try the basics like 0000 etc
          • comptek
            • Aug 2013
            • 606
            Yes I did I thought that would of done it thanks anyway
            • comptek
              • Aug 2013
              • 606
              Did that too Vince 0000 4725 1234 then anything I could think of for a good 40 mins ☹️ Thank you for your idea
              • petehall347
                • Jan 2015
                • 4426
                • United Kingdom
                post the model number of the unit and service./user manual ..
                i think there should be a service menu that over rides everything .
                • comptek
                  • Aug 2013
                  • 606
                  Hi Pete the model number is as shown in the title and all they seem to mention is the “0000” method and that does not work thanks though
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    im sure ive read that polaroid are made by umc maybe give them a call UK Technical Support Line 0871 2000 463
                    or try polaroidtv@digitalsupportdesk.com www.polaroid.com
                    • ducky29
                      • Dec 2015
                      • 370
                      • Europe
                      This set is made from vestel so its imported from turkey and not made by umc
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        thanks handy to know
                        • Diah
                          • Feb 2013
                          • 6357
                          easy way to solve this issue and many other like edit, use this tool attached.
                          connect tv with LAN and remark the IP address from your router
                          open the tool and select enable Telent/FTP and then write the IP Address
                          click on enable FTP, it will do the job for you at port 22, look on the log of the tool it will show you the info.
                          then open any ftp client, i prefer always FileZilla Client ,
                          log in and browser etc, users. also you can copy in your case your board mb130--- mb130_swprofile.bin , mb130_langprofile.bin , mb130_hwprofile.bin
                          all these can be edit with the same tool, dont do any things elles if you dont know, just upload here or make screen shoot to folder etc... users... to tell you where the lock file to delete it or rename it.
                          • comptek
                            • Aug 2013
                            • 606
                            yes defo Vestel 17mb130s mainboard in it but nice thinking Vince thank you
                            • comptek
                              • Aug 2013
                              • 606
                              ok thank you i will give it a shot when i go to the shop Diah, i thought i could of just flashed the core firmware or something lolol
                              • ducky29
                                • Dec 2015
                                • 370
                                • Europe
                                If you cant find the firmware for free I can get it for you for 10$
                                • legacy3010
                                  • Jan 2020
                                  • 8
                                  • United Kingdom
                                  Hope you have solved this issue by now but it sounds like it's in Hotel / store mode which stops you from changing settings. Updating the software does a factory reset so you can follow these instructions and hopefully it will work for you. I have attached the firmware for 17mb130 v3.62.73. https://files.fm/u/v7556rnj
                                  SOFTWARE UPDATE
                                  MAIN SOFTWARE UPDATE
                                  In MB98 project, please follow software update procedure:
                                  1. mb130_en.bin, mb130_RomBoot.bin, mb130_PM51.bin and usb_auto_update_G10.txt documents should
                                  be copied directly inside of a flash memory (not in a folder).
                                  2. Insert flash memory to the TV when TV is powered off.
                                  3. While pushing the OK button in remote control, power on and wait. TV will power-up itself.
                                  4. If First Time Installation screen comes, it means software update procedure is successful.
                                  Service Manuel
                                  https://cdn.badcaps-static.com/pdfs/...68ac836543.pdf
                                  • mm0bef
                                    • Mar 2021
                                    • United Kingdom
                                    SOFTWARE UPDATE
                                    Service Manuel
                                    Hi do you still have the mb130_en.bin, mb130_RomBoot.bin, mb130_PM51.bin and usb_auto_update_G10.txt files. ive got them on a usb but i think they are corrupted.
                                      LCD LED TV Service Menu Codes
                                      ALL LCD LED TV SERVICE MENU CODES
                                      Service Menu Code with Board Name
                                      China Universal Board / Jumper Board Service Menu Code
                                      Changhong Ruba Service Menu Code
                                      Ecostar LED TV Service Menu Code
                                      Orient LED TV Service Menu Code
                                      Haier LED TV Service Menu Code
                                      TCL LED TV Service Menu Code
                                      Samsung LED TV Service Menu Code
                                      LG LED TV Service Menu Code
                                      Videocon LED TV Service Menu Code
                                      Supra LED TV Service Menu Code
                                      Toshiba LED TV Service Menu Code
                                      Symphony LED TV Service Menu Code
                                      Veste/ LED TV Service Menu Code...
                                      10-31-2024, 03:58 AM
                                    • envym
                                      MacBook Pro 2018 with Activation Lock
                                      by envym
                                      Hi everyone!
                                      I have a 2018 MacBook Pro (with Sequoia OS) that I've been using for years with no problem. I recently received an M2 MacBook Pro so I'm mostly using it and not the 2018 one, but since a friend of mine needs a computer, I thought I could restore my 2018 and give it brand-new-like to my friend.
                                      I tried using the built-in tool to restore the MacBook (Settings > General > Transfer or restore > Delete) but it got stuck when trying to remove the Find Device configuration (it asked me for the password for my old Apple ID -now I use the same account but...
                                      06-27-2025, 08:54 AM
                                    • ArtMov
                                      [HELP] Asus g732lv ami bios overclocking lock reseting after reboot
                                      by ArtMov
                                      Hi guys, i have a problem , my bios resets disabled overclocking lock setting to enable after reboot, please tell me which function can be responsible for restoring the stock config for this option, loading parameters from nvram and so on, like bios ,protection, from asus. My bios made me angry) Set default parameter to disable in amibcp 5 , doesn't help(
                                      1. I made overclocking lock disabled the default in amibcp
                                      2. I changed the varoffset to the wrong one, but it led to the programmer, it was very tedious and nervous, I really regretted it, my chip is on the back of the...
                                      03-31-2023, 01:30 PM
                                    • stormanimal83
                                      Nintendo Switch picofly installed cause parental lock how to get Master Key for restoring OFW
                                      by stormanimal83
                                      i bought a use console from ebay fixed it and it has parental lock. seller wasn´t helpful and nintendo either cause they don´t support used devices as they told me per mail. thanks for the bad support here in germany. was totally upset as i read the answer to my mail from 1 week ago.... there was no other way to get rid of that code rather than modding the console cause i didn´t even had the device id as it´s a patched V1 and for getting masterkey on salthax there is the need to type in the device id which was unknown in this case... i did a mistake. after the repair i entered my wlan and...
                                      08-04-2024, 01:47 AM
                                    • Retro140
                                      Unnlock Menu for 2007 DU-27FB32C comerrcial CRT TV
                                      by Retro140
                                      So I was referred here when I made this poste over on AVForums: https://www.avsforum.com/threads/loc...lg-tv.3257234/
                                      To summarize, this is a commercial TV and I can't get a menu of any kind. I know the overlay is working because when I change channel, adjust volume, turn on sleep timer I do see text. But I have not ever seen the user menu nor the installers menu. I've tried a bunch of remotes(more info on the AVF post) and tried every button...
                                      06-18-2023, 06:13 PM
