LG 55LB6000 flickering screen
  • sputnikoff
    • Feb 2016
    • 203
    • canada
    Got a Lg 55LB6000 in today.Screen was flickering and when removed back could see lamps were issue.Did a tear down and found the top two rows were not illuminating.Apparently they are 6 volt leds cool white.Got 1 shorted and 2 burnt out.Where is good source for these leds?Any one know specs on these leds?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 55LB6000 flickering screen
    There would be ID Nos. on the LED strips when you tear down the Panel.
    • sintv
      • Feb 2015
      • 37
      • scotland
      I get my leds from Ebay chinese sellers. Good prices and havent had any issues. Search for LG smd led
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        There are 3V and 6V LEDs. I think the LGs use the 6V SMD LEDs. I prefer however to replace all the strips with new ones as I don't like to goin a Panel more than once, especially those 55inchers
        • sputnikoff
          • Feb 2016
          • 203
          • canada
          yes ordered 50 6 vdc lg leds.gonna order strips from shop jimmy just in case.
          • neilc6
            • Nov 2015
            • 1550
            The thick lenses appear to use the 6V LEDs and the thinner lenses with 3 black dots use 3V LEDs. I did a full strip replacement on a 32" LG with the thicker lenses and popped off almost every lens since they were difficult to remove with the double sided tape.
            • Andrew F. Ali
              • Jan 2014
              • 2450
              • Trinidad & Tobago
              That's right the thicker lens are the 6V and the thinner lens with the 3 dots are the 3V LEDs.
              • sordids999
                • May 2013
                • 2152
                • uk
                Off topic here I'm reluctant to do these led repairs due to even heating up the led strip which is stuck down they nearly all fall of so my question is which way do they go back on because many times I have put these back on and ended up with a halo effect on the screen
                • neilc6
                  • Nov 2015
                  • 1550
                  You may get halos if the lens isnt perfectly centered, or not level or sitting too high. Can also be caused by the strip not sitting flat against the chassis. I scrape down the black nubs on the 3V lenses with an exacto knife before gluing down. Also better to swap repaired strips to the edges instead of middle of the screen if you can.
                  • Ado02
                    Lenovo Thinkpad X1 Gen 10 - Flickering Screen
                    by Ado02
                    We recently replaced the OLED screen on a Lenovo ThinkPad X1 Gen 10. After about a month, the replacement screen began to flicker. Initially, updating the IntelĀ® IrisĀ® Xe graphics driver resolved the issue for about a week. However, when the problem recurred, updating the driver again had no effect.
                    The flickering only occurs once the system reaches the Windows login screen. Interestingly, if we disable the Intel GPU driver or connect the laptop to an external monitor, the flickering stops. We have tried installing two different replacement screens,...
                    12-16-2024, 02:33 PM
                  • Ryan.man
                    by Ryan.man
                    02-04-2025, 12:23 PM
                  • survivalbloke
                    HP ENVY HP 13-aq1013dx - screen flickering black if using touchpad or external mouse
                    by survivalbloke
                    SN: 8CG0213H8W
                    ProdID 3C311UA
                    This device came in due to the screen flickering if you use the touchpad or external mouse. It will flicker black when this occurs. If you use the touchscreen, the behavior does not appear. Also, if connected to external monitor, the external monitor is not affected by the flickering. I did a good amount of research on this, and concluded that it is due to the display driver. HP does not offer Windows 11 drivers for this model so I got the replacement drivers direct from Intel. I installed them and the problem...
                    05-08-2025, 12:21 PM
                  • smic717394
                    by smic717394
                    07-25-2024, 10:16 AM
                  • RetroComputingGrotto
                    LG 42LN540V LED Backlight Flickering After Replacement When Connecting The Screen
                    by RetroComputingGrotto
                    This TV has been on the wall in our reception area for around 10 years and the other day the backlight failed. You could see a feint picture so we knew the screen was OK. I took the TV apart to get to the failed backlight and inject voltage in to each half of the LED strips to identify which ones had failed and 4 needed replacing. I ordered a set off of Amazon and they arrived the next day.
                    On fitting the new LED strips I plugged in the TV was blinded by the light!!
                    It was only when I partially put it all back together (including the screen) that...
                    10-23-2024, 04:17 AM
