Where does this part go ? (TC-P50S1)
  • boydsc
    • Jul 2018
    • 10
    • US
    Hello all , I got this Panasonic TC-P50S1 tv in a few pieces from someone. I don't know where this part goes. I think it goes somewhere on the A board.
    Also where would be the best place to find or repair the SC board ? (TNPA4782)
    Thankyou
  • brucetv
    • May 2015
    • 281
    • united states
    Re: Where does this part go ? (TC-P50S1)
    That is the shield that covers the S board. You can usually get the repair kits that comes with all the rebuild components at www.shopjimmy.com and if you have soldering skills you can rebuild it yourself. If you don't just take the kit and the board to any tv repair shop. One hour of labor should do it. The S board is down on the bottom middle covering power switch assembly.
    • brucetv
      • May 2015
      • 281
      • united states
      https://www.shopjimmy.com/catalogsea...sonic+TC-P50S1
      • boydsc
        • Jul 2018
        • 10
        • US
        ok great thankyou. I have a 0 ohm reading across the 2 pins on plug sc2. That is a short correct ? Which parts usually go bad in that case ? I can solder things like the transistors but the tiny diodes or ic chips I would probably screw up.
        • brucetv
          • May 2015
          • 281
          • united states
          Hope this helps. It's the service manual with troubleshooting tools
          • boydsc
            • Jul 2018
            • 10
            • US
            awesome thanks bruce
