Macbook Air A2681 logic board, find this part
  • PizzaMan
    • May 2025
    • 5
    I am trying to find this part on the logic board. See pictures below. It might be CR812, not sure. Any help would be appreciated. And where could I find the part?
  • mon2
    • Dec 2019
    • 14980
    Agree. Looks to me to be CR812. A part that will not be missed if it is not replaced but you should be able to find a replacement on Digikey / Mouser / Arrow.
    • PizzaMan
      • May 2025
      • 5
      Cap was shorted. I just removed it for now. Laptop fired right up. Thanks
      • korben_dallas
        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
        by korben_dallas
        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
        MY QUESTION:
        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
        02-14-2024, 12:23 AM
      • tony359
        2007 Macbook logic board fault
        by tony359
        Good day all,
        I got a 2007 MacBook from a friend. The fan was not working so it was overheating.
        Once the fan was swapped, I installed an OS and it worked fine.
        The board had quite a few corroded spots so I removed it, touched those spots with a soldering iron, washed the board in PCB cleaning fluid (I've done that many times), rinsed it with distilled water, dried it etc.
        Unfortunately it doesn't work anymore. It does turn on, fan spins, power LED turns on. But no picture.
        If I see that right, I have missed VCORE on L7100 (page 59)....
        01-23-2025, 06:59 AM
      • defdjamel
        Solder won’t melt on MacBook 2021 logic board – need advice
        by defdjamel
        I’m trying to remove a component from a 2021 MacBook logic board, but I’m having trouble.
        https://www.electronicsdatasheets.co...s/tlv70733pdqn
        I’m using hot air at 480 °C with full airflow and good flux, but the solder paste is not melting.
        I know there’s a lot of thermal dissipation from the board, and I suspect the copper planes are absorbing most of the heat.
        Do you have any tips for this kind of board? Would a preheater help?
        Thanks in advance!
        09-05-2025, 08:56 PM
      • ledbylight
        M1 A2337 Macbook - No Display, likely due to logic board
        by ledbylight
        Hi all!
        This is my first post and also one of my first "deep dives" into electronic repair. I'm used to doing basic tasks with computers, like SSD/CPU replacement, thermal past re-application, etc. So here's the story...
        I have a MacBook Air M1 that I bought to repair (I know, I'm weird; though I'm a CompSci major and want to learn more , and it will not display anything on the internal display. I have verified that there's no backlight, as I booted the laptop and shined a flashlight on it and there's no display; it does completely boot up, and shows fine on an external...
        11-04-2024, 06:36 PM
      • devsigner
        identify capacitor for MacBook Pro with rare logic board 820-02037-06
        by devsigner
        Hi
        While messing around with my MacBook Pro, I stupidly pinged off a very small surface mounted component that I’m now trying to identify.
        resistance tests show a rising resistance value, indicating a capacitor.
        The laptop boots up and runs, however I'm choosing not to use it until I get it fixed.
        i can’t see any markings on the capacitor at 10x magnification using a professional jewler's loop.
        It seems like there's some damage to the capacitor - one side doesn't have "shiny bits" - can you tell I don't do this for a living!...
        11-28-2025, 01:39 PM
