Samsung UE46B6000VW
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Samsung UE46B6000VW
    Hi all looking for some help on the above set i'm trying to repair.
    Tv powers on and has sound but no video or OSD, just a white glow from the backlight.
    Had a look around >
    Checked fuse on Tcon all fine here.
    Checked all cables
    Gave the PSU a good Visual.
    Thanks in advance
    s>
  • ducky29
    • Dec 2015
    • 370
    • Europe
    Re: Samsung UE46B6000VW
    Can you see a picture/ menus if you shine a flashlight at the screen?
    • vinceroger69
      • Mar 2012
      • 6714
      did you also check voltage too the tcon fuse?
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        Backlights are on so don't think they are at fault here - ducky29
        • StephenU
          • Dec 2013
          • 230
          • United Kingdom
          Didn't check it - D'oh
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Vdd, Von, Voff, Vcom, Vgl and Vgh are voltages to start with.
            • StephenU
              • Dec 2013
              • 230
              • United Kingdom
              I've had a look at the silkscreen on the board but can seem to see the TP's you are referring too.
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                Hmmm...I seem to not be able to find them too. They may be on the panel Bds that the FFCs go to. However, your problem is either T-CON or Panel. With my experience I would tend towards T-CON as these T-CON Bds. are noted for failure.
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4330
                  • Italy - Milan
                  Hi, test theese points in Volt.
                  • StephenU
                    • Dec 2013
                    • 230
                    • United Kingdom
                    Great thanks Davi.P will do it tonight.
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      I have numbered up the test points and attached a pic here are the results I got.
                      1 - 3.31v
                      2 - 12.58v
                      3 - 1.12v
                      4 - 2.47v
                      5 - 1.816v
                      6 - 3.288v
                      7 - 1.064v
                      8 - 2.512v
                      9 - 12.67v
                      10 - 12.67v
                      11 - 12.67v
                      12 - 2.472v
                      TIA.
                      S.
                      • Davi.p
                        Hobbist Tech
                        • Sep 2009
                        • 4330
                        • Italy - Milan
                        It lacks of the Avdd signal, Check in diode mode across C_DP1 and its anode to ground. Check this point two again after disconnecting one at a time of the tcon output cables.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          Thanks Davi.p, i will check these are let you know the results.
                          RE: with reference to "C_DP1 and its anode to ground" - Just the normal Black Probe on chassis ground and Red Probe to anode of Diode C_DP1?
                          S.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4330
                            • Italy - Milan
                            when in diode mode you have to check between the indicated points in one way and reverse..
                            • StephenU
                              • Dec 2013
                              • 230
                              • United Kingdom
                              Do I need to have the set powered on or take these measurements with set off?
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                set powered off when testing in diode mode
                                • StephenU
                                  • Dec 2013
                                  • 230
                                  • United Kingdom
                                  Cheers vince, just going to post findings now.
                                  So here's what I got -
                                  TV off and both tcon outputs plugged in.
                                  Red probe on Anode - Black on Cathode = 0.177v
                                  Black probe Anode - Red Probe Cathode = O/C
                                  BP Chassis RP Anode of C_DP1 = 1.43v
                                  BP Chassis RP Cathode of C_DP1 = O/C
                                  RP Chassis GND - RP Anode of C_DP1 = 0.54v
                                  RP Chassis GND - BP Cathode of C_DP1 = 0.65v
                                  RP Chassis GND BP (Test Point 2) = 0.65v - Same value measured with 1 tcon output ribbon at a time.
                                  Hopefully I've took the readings correctly.
                                  TIA All
                                  S.
                                  (RP - Red Probe)
                                  (BP - Black Probe)
                                  (O/C - Open CCT)
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4330
                                    • Italy - Milan
                                    Hopefully I’ve took the readings correctly.
                                    Not all well, i told to test point 2 again in VOLT...
                                    For the test on the DP1 anode to the GND it seems OK, maybe there is not a a signal to the near TPS65161 that enables AVDD. In the image under i have squared two test zones, one you can test if C_RP41 is connected to C_CP11 near it, then if you can test in volt RP21 and RP41 respect to GND.
                                    • StephenU
                                      • Dec 2013
                                      • 230
                                      • United Kingdom
                                      “Check this point two again after disconnecting one at a time of the tcon output cables.”
                                      Tv turned on to take this measurement?
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4330
                                        • Italy - Milan
                                        :-P ... As a hobbyist repairer you have to get some lessons... all voltage testing are made obviously with AC plug in and tv on.
                                        • triplefour
                                          Samsung UN55ES7003 has blown fuse on TCON and short to ground.
                                          by triplefour
                                          Samsung UN55ES7003
                                          made house call.
                                          red power led comes on, blinks twice, no display, no backlight, relay clicks, repeat.
                                          psu has self test feature.
                                          disconnected from mainboard.
                                          determined PSU ok BL ok.
                                          suspect mainboard.
                                          disconnecting tcon has no change on operation.
                                          markings on mainboard:
                                          BN97-06531P 0151
                                          BN94-06123R
                                          found and ordered replacement on ebay https://www.ebay.com/itm/394077328633
                                          for 54$
                                          second house call:
                                          with replacement mainboard, tv turns on, has sound,...
                                          07-13-2022, 03:53 PM
                                          09-07-2024, 05:50 AM
                                        • Chrissygizmo
                                          Samsung ue55hu8500t tcon board fuse blowing
                                          by Chrissygizmo
                                          Hi , I've got a Samsung UE55HU8500T that has sound but no picture, I've had it open and done a quick check of voltages etc, I found that the F2 fuse on the tcon board had blown (T-CON BOARD VD_STV5565EU22BC6LV0.3 -) so I replaced it with a similar value fuse but still nothing, ten I noticed the replacement fuse had blown too . I would appreciate any help with this. Thank you in advance...
                                          04-28-2021, 11:15 PM
                                          09-06-2024, 11:40 PM
