PN60F8500 Bad Power Board Shutting Off
  • p1zaul
    • Oct 2018
    I purchased a PN64F8500 used with an issue where it would not turn on and replaced three caps on the Y-Board and it was fixed and been working ever since.
    Few months later I see a PN60F8500 for sale on CL with a note saying it does not work, so figure the same easy fix and I'll have a new TV.
    The issue is slightly different, the TV will power on but after around 5 minutes or so it will power itself off and not turn back on.
    After opening up the back I notice the boards are completely different and those three caps from the 64 inch do not even exist on the 60 inch model.
    I have looked on various forums online and seems that this is an issue with the power board itself. The board is model BN44-00602A. I have replaced the main 4 large capacitors but still have same issue. Has anyone else had this issue? I have also read it is possible it is chopper transistor failing short circuit or the bridge rectifier failing short circuit. I am not even really sure what those components are. Is there a way to easily check the remaining caps on the power board to single out any that may be damaged?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8325
    Re: PN60F8500 Bad Power Board Shutting Off
    could be also the main board doing that. Maybe run the TV with the back off and put a fan behind, in order to cool it. See what happens.
    • R_J
      • Jun 2012
      • 9588
      If something was shorting it would stay shorted and likely blow the main fuse, Remove the power supply and inspect and resolder the transformer rivit connections and also resolder any components that are mounted to heatsinks.
      • p1zaul
        • Oct 2018
        would it actually turn on if the solder was failing?
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          Yes it would and might shut down suddenly whilst working. Hence RJ suggested: 'Remove the power supply and inspect and resolder the transformer rivit connections and also resolder any components that are mounted to heatsinks.'
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • notallbad
            TCL 55RP620K power board issue
            by notallbad
            Originally the tv arrived with dimmed backlights (not failed leds) but everything else worked ok. Adjusting backlight in menu did nothing but voltage changed on dimming control pins,
            0% p_dim at 1.65v and a_dim at 1v
            50% p_dim at 3.3v and a_dim at 1.65v
            100% p_dim at 3.3v and a_dim at 2.88v
            Changed backlight leds anyway as always like to have complete peace of mind they wont fail shortly after selling the tv. No change as expected!
            Leds are 2 rows of 15 6v leds.
            On inspection of the power board found diode MBR3200 shorted so replaced with...
            07-12-2025, 05:45 AM
          • Dani_2024
            by Dani_2024
            10-28-2024, 05:06 PM
            After all of...
            07-13-2024, 08:14 PM
